![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
How To Adjust Your Door Line ---------------------------------- Tools used: ![]() ![]() Intro ------- This How-To will explain how to adjust your door line. Not all Celica's are like this, only some are. My car was in a previous front-end collision and brought back in running condition, however it seems like the door hinges have slightly shifted causing the door line to stick out from the rest of the rear quarter-panel. I'm sure there are some celi owners who have this issue as well. This may also help keep the cabin insulated.. last winter, i thought my heater wasn't functioning well when now i realise that this crack has been letting out all the heat. also, for those living in hotter climates, this will even help keep the cool inside when the A/C is on. This has been bugging the HELL outta me because the subwoofer in the door makes the window and all the inner door parts rattle and it's SO annoying! With the door pushed in and lined up, the window seals up with the weather seal and the door tightens keeping it from making that horrible vibrating rattle sound. Also doing this makes the car look much sleeker too! ![]() ![]() Procedures ----------- 1. Using the screwdriver, remove the two screws holding the door striker in. This may take A LOT of torque so you may want to add WD-40, use mechanic gloves with lots of grip, or even use a torch to heat it up (this helps loosen it a bit). Be sure not to mess up the screw, or else you won't be able to unsrew it. Luckily, I did it on the first try ![]() ![]() 2. You'll need the pliers or anything else with a pointed tip to push on the metal plate inside. In case you're wondering, the threading for the striker screws is on a separate plate of metal and not actually on the door pillar. This is great (thank you toyota engineers!) and allows the door striker to be slightly adjusted. Although, adjusting the metal plate inside will take EVEN MORE force than removing the screws in step 1. Make sure you push on the flat side of the plate and NOT on the threading, if you ruin the threading you obviously won't be able to put the screw back in. ![]() ![]() Here's how it looks after being adjusted: ![]() Don't even bother removing the interior rear quarter panel because there's too much metal and you won't have enough room to work in anyway. ![]() 3. Be sure not to move it too far as it may loosen or soften the welds. So after moving it a couple of millimeters, reattach the striker back on and close the door to see how much more it would need to be adjusted. It's all basically 'Trial and Error' for this step. ![]() 4. Once you think you have it adjusted right, you're pretty much finished. ![]() Total Time: 15-20 mins Before and After -------------------- ![]() ![]() This post has been edited by azian_advanced: Jan 29, 2010 - 9:34 AM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
very nice idea i never thought about moving that....normally you would adjust the hinges inside the fender....a+
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 25, '06 From Hong Kong Currently Offline Reputation: 256 (100%) ![]() |
Good learn! Thanks!
![]() Enthusiast ![]() ![]() ![]() Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(playr158 @ Jun 26, 2006 - 12:20 PM) [snapback]449084[/snapback] very nice idea i never thought about moving that....normally you would adjust the hinges inside the fender....a+ actually that will usually WORSEN the alignment. the striker on the other hand you could even loosen and give it a few well place hits with a hammer...and if the door is hanging low you might want to check the bushings..easy $10 fix -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
![]() good reason to adjust at fender ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) ![]() |
Just did it on my drivers side. My dad said that its adjustable i beleive.
oh come on lambo doors don't count lol..the first thing to try though is the striker becuase it is way easier to adjust it than the hinges
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 1, '04 Currently Offline Reputation: 1 (100%) ![]() |
oh this is awesome!
![]() When I bought my car it had a rebuilt title cuz some idiot got it T-boned and totaled it... My driver's side door is slightly off, but this is awesome... I'm gonna show my dad this and we'll see what happens ![]() This post has been edited by CelicaBuddy: Jun 26, 2006 - 8:42 PM -------------------- ![]() 2003 Nissan Murano SE |
so that's what it's called, a striker... hmm, never knew that.
Enthusiast ![]() Joined Apr 12, '05 Currently Offline Reputation: 0 (0%) ![]() |
Wow im gonna go get on that right now. I had to pull the door-open wire cause it kept going off since my passenger side door doesnt sit flush enough
Lo-Fi Version | Time is now: February 19th, 2025 - 10:13 PM |
