> best 1,2,3
post Jun 26, 2006 - 4:54 PM
teamchancery
Joined Jun 25, '06
From miami
I must say this site is very informative and very interesting.I have read some of the transmission posts but i havent gotten a concrete answer.I am from jamaica i currently have a toyota trueno ae110(like a levin) not sure if u are familiar with it.Anyway i have a 3sgte engine from the caldina for my swap and i am a person who prfers bottom to midrange power not so much top end.I have heard conflicting stories that the e153 (3sgte) is best for top end however there was someone in the caribbean who used the v6 camry (e56)transmission he said he didnt like it as the ratios were too short and he made his power in fourth gear.Others in jamaica have done the swap but i cant get a hold of anyone to ask about best transmission.I am wondering since many of you have done this swap which would be a better gearbox for drag racing(please give the code tranny and from which car)As i say i prefer a very quick car not so much high speed plus jamaica is full of mountains and corners so not much highway runs.Which gearbox is best for this
post Jun 27, 2006 - 12:06 AM
pure_dx
Joined Dec 28, '05
From USA
i am very familiar with your trueno, why did you take out the 4age? it has the low the mid range power you're asking of, the 3sgte does pull hard up top if thats what you're looking for. IMO, you'd want something with top end (drag racing) stick with the 3sgte, or if you want to auto x, or play in the moutains like you said, the 4age would be a nice choice, why did you swap in a 3sgte? Your trueno did come with the 20v 4age, did it not?
post Jun 27, 2006 - 12:59 AM
teamchancery
Joined Jun 25, '06
From miami
i wish.No i was not fortunate enought to have a high revving 20valve engine.My version is ae110 which came with a 5afe engine which is a 1500cc dohc engine.Mine is a 1999 .I was considering getting the 20 valve blacktop which came with the 6 speed gearbox but the cost of it was the same as the 3s so i chose 3s as i was looking for 250-300whp with relatively little modifications
post Jun 28, 2006 - 3:52 PM
scothaniel
Joined May 1, '03
From Michigan
I'd say the S series transmission in our GT Celica's and non-turbo MR2's would be a good trans - if you want lots of torque and low-end power. This can be mated to the 3S easily, and can handle a decent amount of power.
Scott
West Michigan
post Jun 28, 2006 - 4:01 PM
arn't trueno's rwd?
This post has been edited by playr158: Jun 28, 2006 - 4:02 PM
post Jun 28, 2006 - 4:16 PM
jdg371
Joined Jun 14, '05
The old trueno's are RWD the new ones 90's and up are FWD I think their AE101s
Theyre the ones that look like the Curren
post Jun 28, 2006 - 11:00 PM
teamchancery
Joined Jun 25, '06
From miami
mine looks jus like this http://www.alljapanesecars.com/viewcr.php3...r=2000&mc=AE110
do the gt boxes come with lsd and are these the s54 transmissions
post Jun 28, 2006 - 11:19 PM
scothaniel
Joined May 1, '03
From Michigan
The US version's didn't have an LSD, but I believe there are aftermarket options available.
Scott
West Michigan
post Jun 29, 2006 - 6:38 AM
Speeder
Joined Apr 29, '04
From Norway
QUOTE(teamchancery @ Jun 29, 2006 - 4:00 AM) [snapback]450212[/snapback]
Hi
The E56 transmission has LSD, it is is some european models of the ST202. The cars that have superstrut suspension, does also have the E56 tranny.
The S54 is the most common, but does NOT have LSD.
Best Regards
Toyota Celica 2.0GT 1995 - 175BHP
- D2Racing coilovers - BlackDiamond brakes - TOYO R881 tires -
post Jun 29, 2006 - 2:04 PM
teamchancery
Joined Jun 25, '06
From miami
thnaks alot for all the help guys.So the consensus is that the gt tranny would be the best bet for what i am looking for?
post Jun 29, 2006 - 4:12 PM
Negative
Joined Apr 28, '04
From Houston, Texas
No that's the easiest option. The best option would be the one from the Celica SSIII Beams 3S-GE - already has LSD and the gearing is supposed to rock. Plus you would not need a hybrid clutch setup since both the motor and the tranny are for 3s as opposed to the 5S tranny which will need a combination 5S-3S clutch setup. However many of the good brands do offer that setup.
post Jun 29, 2006 - 11:54 PM
teamchancery
Joined Jun 25, '06
From miami
QUOTE(Negative @ Jun 29, 2006 - 4:12 PM) [snapback]450480[/snapback]
Really i didnt know that i asked someone wen i was buying the clutch if i should buy for the engine i have cause i didnt get a transmission with the engine.So altho both were from a 3s engine the celica gt gearbox will not bolt up jus like that without that hybrid clutch u speak of
This post has been edited by teamchancery: Jun 29, 2006 - 11:54 PM
post Jun 30, 2006 - 12:17 AM
scothaniel
Joined May 1, '03
From Michigan
The 3SGE trans with LSD is an E56 - the same trans as the V6 Camry mentioned in the first post.
The 5S tranny was mated to the 3SGE ever since the ST162 model. You just need the 3SGE's clutch and flywheel. Most aftermarket companies offer 3SGE clutch upgrades - I dont know why everyone goes the custom route when there an 'off the shelf' option available.
Scott
West Michigan
post Jun 30, 2006 - 12:28 AM
scothaniel
Joined May 1, '03
From Michigan
Check out http://www.megaboost.co.uk/mr2/frames/techinfopage.htm for the gear ratio's of the US S54, JDM S54, and E153. Just for clarification:
US - 1990+ Celica GT, 5SFE Motor = S53 or S54 trans.
JDM - 1994+ Celica, 3SGE Motor = S54 trans (non-LSD)
JDM - 1994+ Celica, 3SGE Motor = E56 trans (LSD)
IIRC, the E56 has nearly identical gearing as the E153 trans.
JDM S54 trans has a different final drive ratio then the US S53/4 trans.
Scott
West Michigan
post Jun 30, 2006 - 12:45 AM
teamchancery
Joined Jun 25, '06
From miami
QUOTE(scothaniel @ Jun 30, 2006 - 12:28 AM) [snapback]450647[/snapback]
i think im finally getting it.ok i bought a 3sgte from a caldina motor(my car is ff) i bought aftermarket clutch and lightweight flywheel for the 3sgte engine.I thought the gt was a 3s motor .So now i have 2 options of gearboxes to buy 2morrow
1st is a jdm 3sge gearbox non lsd.I hear that these had a very good ratio boTtom and mid range power which is what i want(SO SINCE BOTH CAME FROM THE 3S although ONE IS turbo and one is NON TURBO will THE CLUTCH AND FLYWHEELwhich i bought STILL WORK ON IT?)
2nd option is i have found a jdm celica gt4 gearbox however i hear these are better for top end plus its a very heavy gearbox and my car is light and will already be carrying the load of the 3sgte engine
post Jun 30, 2006 - 8:17 AM
Negative
Joined Apr 28, '04
From Houston, Texas
BTW - I have a hood with scoop in my garage for your car. Came off a Supercharged Levin clip we swapped into a 1st gen MR2.
post Jun 30, 2006 - 1:49 PM
scothaniel
Joined May 1, '03
From Michigan
1st is a jdm 3sge gearbox non lsd.I hear that these had a very good ratio boTtom and mid range power which is what i want)
This is the same trans thats on the US market 1990-1998 Celica GT. For the most low-end power, dont get the JDM version.
The 3SGE and 3SGTE clutch and flywheels are not the same. You can either get the 3SGE setup, or the hybrid setup:
http://www.6gc.net/forums/index.php?showtopic=28825
Scott
West Michigan
post Jun 30, 2006 - 2:42 PM
teamchancery
Joined Jun 25, '06
From miami
thanks alot for the info scothaniel really saved me 2day.I bought the gt4 jdm 4wd tranny.We will take of the transfer case and put a plate their or summin like that (so mechanic says)I have seen 2 cars like mine that he did it to and they been running fine for over 2years now.I never knew that could be done before.Really happy now at least now ill have the lsd.Also negative i have a sti hood scoop plus i live in jamaica currently so unless u were going to ship it down but thanx for the offer.Thx again for the help the mechanic shud be getting the car this week.Also quick question i bought a clutch,pressure plate and lightweight flywheel for the 3sgte from gripforce(f1 racing) an ebay store i have heard some good comments on the stores products have any of you ever used their products or know of any experiences
This post has been edited by teamchancery: Jun 30, 2006 - 2:46 PM
Lo-Fi Version Time is now: November 23rd, 2024 - 9:32 PM
