> Vaccum Issues with swap, diagrams i have are bogus.
post Jun 28, 2006 - 9:29 AM
jcbass7
Joined Apr 20, '06
From Florida
So i have the engine about to drop, but now with the wiring almost out of the way i have some vacuum issues to figure out.. and the diagrams i have are completly useless.
I have three vacuum lines that i am unsure of right now. Two come out of the top of the intake manifold and proceed across the sticker that says toyota... well here is a pic instead:
and the other comes out on the passenger side of the intake manifold near the throttle body heres a pic:
and another pic
it is the one on the left of the two, (the one with the black spiral cover thing)
thanks in advance
Jesse
This post has been edited by jcbass7: Jun 28, 2006 - 9:30 AM
post Jun 28, 2006 - 9:34 AM
the 2 in your 1st pic go to your charcole canister, and/or egr (for USDM motors) . you really dont need them hooked up and can just put vac caps on them.
the other one goes to your map sensor, aka turbo pressure sensor.
post Jun 28, 2006 - 9:36 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
damn you art, i wanted to feel smart for once, i knew the answer too frown.gif
post Jun 28, 2006 - 9:42 AM
With the 2 lines the one closer to the center of the engine is the charcoal cannister.
post Jun 28, 2006 - 3:48 PM
jcbass7
Joined Apr 20, '06
From Florida
ok, i'm going to hook up the charcoal canister and such for the chance i might pass emissions
is the map sensor mounted on the firewall? or under the intake manifold?
thanks guys
PS: the engine is a JDM 1993 all-trac
ohhhh yea in the second picture under where the intercoolel hooks in, there is a fitting hanging there made out of brass maybe or whatever, but i think its my throttle body warmer? well im not sure where to hook it its just dangling right now,
This post has been edited by jcbass7: Jun 28, 2006 - 3:46 PM
post Jun 28, 2006 - 6:11 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(jcbass7 @ Jun 28, 2006 - 1:48 PM) [snapback]450048[/snapback]
thanks guys
Your charcoal canister probably only has one connection on it, so you might still need to just block off one of those connections. I'm not sure which one to block off though... I still haven't figured that one out for my swap.
The MAP sensor is mounted to the firewall. I keeps the sensor from vibrating along w/ the motor.
The fitting there looks like it is for your cold start injector... Don't try to start the motor without that hooked up, or fuel will spray EVERYWHERE! kindasad.gif
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Jun 29, 2006 - 3:36 PM
jcbass7
Joined Apr 20, '06
From Florida
not sure if its the cold start injector or not, but i still can't locate the place to mount that end of it, ill keep searching...
post Jul 3, 2006 - 8:09 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(jcbass7 @ Jun 29, 2006 - 3:36 PM) [snapback]450470[/snapback]
found it. im an idiot. directly under the intake manifold, had to take the throttle body off to get to it, but its all set smile.gif
thanks guys
Lo-Fi Version Time is now: November 24th, 2024 - 7:24 AM
