> Boosting Problems at 12psi 2nd gen 3sgte, not fuel cut, no engine light either
post Jul 1, 2006 - 10:01 PM
eggman40
Joined Aug 17, '04
From California
Hello everyone. Today i finished installing my dual stage boost controller. It works really well in the sense that you can toggle between two set psi at the flip of a switch. I left my low boost at 8pounds and it ran fine. Then i started setting the second boost contoller by trial and error. Basicaly make a run, look at what im running then turn it up.
My goal was to have it at 13psi, 9,10,11psi worked fine, but when i got it to boost at 12psi on the freeway, i heard some kind of sputtering of air in the engine bay. Not fuel cut because i remain at 12pounds(and i installed a fcd black box) but the car wants to keep making more boost but it sounds like leaking air from somewhere. Symptoms of a boost leak i know but i have no idea where it might be coming from. Earlier this week i had a bar and plate fmic installed with a hks BOV (atmospheric) and all the couplers feel tight. Any suggestions? has this happened to anyone? thanks ahead of time for any help smile.gif
post Jul 1, 2006 - 11:52 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
QUOTE(eggman40 @ Jul 1, 2006 - 8:01 PM) [snapback]451091[/snapback]
make a boost leak tester, more than likely you have a boost leak.
post Jul 3, 2006 - 2:06 AM
jgreening
Joined Jan 17, '04
From Illinois
Home-made Boost Leak Tester Instructions
post Jul 5, 2006 - 1:33 AM
Silver94CelicaOw...
Joined Oct 13, '02
post Jul 5, 2006 - 3:09 AM
eggman40
Joined Aug 17, '04
From California
QUOTE(Silver94CelicaOwner @ Jul 5, 2006 - 6:33 AM) [snapback]452125[/snapback]
Agreed
post Jul 5, 2006 - 3:41 AM
is it a knock of HKS or a real one?
post Jul 5, 2006 - 10:03 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Change your cap, rotor, plugs, and wires. Your problem will go away.
Go to toyota and buy all the ignition parts.
I will return one day.
Lo-Fi Version Time is now: February 23rd, 2025 - 1:12 AM
