4 Pages V  < 1 2 3 4 >
> Bad Response, slow take off
post Jul 12, 2006 - 5:47 PM
Culpable04
Joined Apr 17, '06
From New Jersey
What happen is there is no leak on the hoses, I change all my hoses and installed a new EGR valve and the problem still there. kindasad.gif
post Jul 12, 2006 - 9:58 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
I got my header today, I'm gonna pick up the gaskets friday and hopefully put it on saturday.
Sorry for bad pic.
post Jul 13, 2006 - 12:39 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
what header is that
post Jul 13, 2006 - 12:52 AM
QUOTE(LewFX @ Jul 13, 2006 - 1:39 AM) [snapback]455492[/snapback]
what header is that
corolla header. He will need to get the pipe extended and have a second 02 flange welded on the b pipe too.
post Jul 13, 2006 - 6:57 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE(94st_santos @ Jul 12, 2006 - 9:58 PM) [snapback]455382[/snapback]
Sorry for bad pic.
what is yours branded and what did the box yours came in say? mine was "Edge Racing Sport", and came with all the gaskets except the one to the cat.
post Jul 13, 2006 - 9:44 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
My header is for the corolla, and I got it from NOPI and it's made by HP Racing.
post Jul 16, 2006 - 11:36 AM
southwest2118
Joined Jan 13, '06
The best way to find a vacuum leak it to spray all the hoses coming off the manifold with brake cleaner.
so how did it turn up?
This post has been edited by southwest2118: Jul 16, 2006 - 11:37 AM
post Jul 19, 2006 - 10:18 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
Well you can definitely feel the difference in the header, from cracked manifold with a 12 yr. old cat. but I am still having problems with the car. I went to the auto parts store today and was going to buy the EGR valve but instead the sells man told me to clean the O2 sensors with gasoline and clean the EGR valve with brake parts cleaner, so I gonna see how that works.
post Jul 19, 2006 - 11:19 PM
Bitter
Joined Mar 11, '06
LOL cleaning the O2 sensors with gas is just so he can sell you new ones LOL
post Jul 19, 2006 - 11:33 PM
LewFX
Joined Jan 28, '05
gas can be used as a cleaner
post Jul 20, 2006 - 12:04 AM
Bitter
Joined Mar 11, '06
QUOTE(LewFX @ Jul 19, 2006 - 11:33 PM) [snapback]458407[/snapback]
not for an O2 sensor, maybe carb/choke spray, but i'd even be iffy on that. if the sensor is so old and worn that its no longer reading proper just replace it. you can get an OEM one online for relatively cheap, no soldering and splicing, just plugs in. i got one from http://sparkplugs.com/ for about $50. yours are a little more, but not TOO bad.
Denso OE identical O2 sensor 234-1053 234-1053 FRONT $77.48
Denso OE identical O2 sensor 234-2052 234-2052 REAR $40.58
post Jul 22, 2006 - 1:47 AM
rev_limit
Joined Nov 7, '05
From Green Bay , Wisconsin
hey dude did you fixedyour car fixed yett ...if not .... will for my car it pick up very slow i have a 5 speed same thing it barly move when you drive it and even if you floor it ... i found out that the disturbitor was sitting wrong you just might need to turn the disturtor to the the right spot ... buy you have to retared the distur. and reset it...
post Jul 25, 2006 - 2:53 PM
Culpable04
Joined Apr 17, '06
From New Jersey
any update ?
I would like to know cause I have the same problem. I already change EGR valve like a month ago and nothing so I'll probably change my O2 sensors this weekend. if there is something I should know or could use, guys PLZ let me know
post Jul 25, 2006 - 10:31 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
Do you mean the timing was off or the actual distributor was on wrong, I was planning on checking the distributor after I changed the EGR sytem.
I orderd the EGR valve + selenoid and the intake gaskets so I can clean the inside of the intake, I'll let y'all know what happens.
post Jul 25, 2006 - 10:43 PM
Culpable04
Joined Apr 17, '06
From New Jersey
did you replace your O2 sensors ?
post Jul 26, 2006 - 9:36 AM
DomGT
Joined Apr 19, '06
From Long Island, NY
What is your MPG?
'92 Grey Mitsubishi 3000GT SL - Sold
'96 Black Celica ST 25th Anniversary - Sold
'99 Black Mitsubishi 3000GT VR-4 - Sold
'04 E250 Work Van - Going soon
'08 Grey Dodge Charger Work Car - Ordered
post Jul 26, 2006 - 10:08 AM
Steevo
Joined Jul 19, '06
From Colorado
How hard was it to get the two discolored plugs out?
I guess they look like they have had exhaust gas blowing by them discoloring them.
Have you changed the fuel filter? It is a bit of a pain, but does make a difference, my wife filled our car up at a station known for dirty gas and we had problems till I changed the filter, ran some Barrymans and reset the ECU.
The timing shouldn't change on the fly, there are two bolts securing the distributor.
post Jul 26, 2006 - 11:03 AM
Bitter
Joined Mar 11, '06
that coloration is NOT caused by exhaust gasses. its case by a small amount of current tracing over the porcelin and atracting oil particles to the paths where they get stuck. it'll clean right off with a little brake cleaner or carb/choke.
post Jul 26, 2006 - 11:28 AM
Steevo
Joined Jul 19, '06
From Colorado
QUOTE(Bitter @ Jul 26, 2006 - 11:03 AM) [snapback]461352[/snapback]
Not that I am doubting, but the discoloration above the threads and around the hex area of the spark plug on two cylinders in due to electrical current?
Even though two are perfectly clean above the threads?
A simple exhaust leak around the plug gasket would cause this, and the fact that he is losing power under throttle, when compression is higer so leak off would be higher. Perhaps it is just oil loss from the tube seals burning on to the hottest part.
post Jul 26, 2006 - 11:54 AM
Bitter
Joined Mar 11, '06
yes, its current tracking. the other 2 may not have had any oil to track or it could be that 2 plugs had a larger gap/looser boot seal
its technical term is a corona stain
http://aftermarket.denso-europe.com/The-sp...0170000011.aspx
http://www.ngkntk.co.uk/technicaltips/coronastain.asp
This post has been edited by Bitter: Jul 26, 2006 - 11:58 AM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 28th, 2024 - 2:35 AM
