Bad Response, slow take off |
Jul 26, 2006 - 10:02 PM |
Enthusiast Joined Oct 3, '05 From Houston, Texas Currently Offline Reputation: 12 (100%) |
Thanks guys this is alot of good info.
QUOTE did you replace your O2 sensors ? No, I didn't I had just cleaned them from the exhaust build up when I installed my header but never cleaned them with gas or anything. Will probably change them later, won't hurt. QUOTE What is your MPG? I really don't know. QUOTE How hard was it to get the two discolored plugs out? If I remember right they came out like normal plugs would. Still waiting on my parts but I'll probably take a look at the distributor tomorrow. |
Jul 27, 2006 - 5:06 AM |
Enthusiast Joined Apr 19, '06 From Long Island, NY Currently Offline Reputation: 13 (100%) |
Cmon bud at this point in time you should figure out your MPG. It will give you a good indication if you need new sensors.
Next time you get gas, reset the trip odometer. Next time you get gas, take your trip odo mileage, and divide that by the amount of gallons you put in the car, then, post up. -------------------- '92 Grey Mitsubishi 3000GT SL - Sold
'96 Black Celica ST 25th Anniversary - Sold '99 Black Mitsubishi 3000GT VR-4 - Sold '04 E250 Work Van - Going soon '08 Grey Dodge Charger Work Car - Ordered |
Jul 31, 2006 - 6:47 PM |
Enthusiast Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
QUOTE(94st_santos @ Jul 2, 2006 - 8:05 PM) [snapback]451356[/snapback] Oh yeah I said I had a stocked out ST but I also have straight through muffler and NGK iridium spark plugs, this is also a reason I'm wondering why I'm losing so much power. I Probably have like 50 hp now LOL. Spark plugs gapped right? Never trust them to be gapped properly out of the box. |
Jul 31, 2006 - 7:58 PM |
QUOTE Spark plugs gapped right? Never trust them to be gapped properly out of the box. I actually thought about that but my problem started before I got my plugs but I think thats drawing into it also since when I was trying to gap them the fine tip only ate into the gapper I had. And I am going to have to replace my distributor, the copper wire from, the pick up coil untangled itself after I had cleaned the inside of the distributor out and turned the car back on. I'll have to give y'all a pic for a better visual. |
Jul 31, 2006 - 9:27 PM |
Here are the pics. I don't think I did all this damage just with compressed air only if they are that sensitive either way it's being replaced, hopefully tomorrow. Maybe it will fix alot of my problems.
Lo-Fi Version | Time is now: November 24th, 2024 - 7:37 AM |
