> need help on MAP sensor
post Jul 3, 2006 - 5:26 AM
normality78
Joined Oct 27, '05
all bro's,
recently im having some problem with the map sensor.currently im having a set of 4AGZE injectors on my 7AFTE. Controlling by SAFCII with stock map sensor. found out im running abit rich even i minus all 50% on the fuel map.
so last week, me and my mech gotten a few some stock turbo car map sensor but seems cant be use. its either too hard to get it start (suspect over flood with fuel) or something else. but the problem came after i fit back my stock map sensor.
once i step aggressively at once with more thn 50% throttle, the ecu check light on and there is either a boost cut or fuel cut. should i step on it slowly or smoothly, thn it won't happen. but previously be4 swapping the map sensor, i doesnt face this problem at all. i even tried to reset my ecu but its the same.
may i know did i just killed my map sensor or wat?
post Jul 3, 2006 - 8:08 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I don't think it's the MAP sensor... sounds more like a problem with the SAFC or electronics.
This post has been edited by Kwanza26: Jul 3, 2006 - 8:10 AM
post Jul 4, 2006 - 2:20 AM
normality78
Joined Oct 27, '05
QUOTE(Kwanza26 @ Jul 3, 2006 - 8:08 AM) [snapback]451566[/snapback]
bro, what makes u think it could be AFC fault? coz i didnt even touch the AFC at all
Lo-Fi Version Time is now: November 24th, 2024 - 9:30 AM
