> Need Help Urgent......, my car is a mess.....
post Jun 15, 2003 - 3:57 AM
nigz
Joined May 18, '03
From Australia
I just bought myself a JVC headunit and in the process of installing it my self, after taking out my old headunit (which was shop installed) i took one look at the factory wiring and thought peice of cake! well........
i am absolutely farked i have no idea what each colour represents! guys im not going back in my car unless someone can help me identify all the wiring colours please please!!!!!!!!!
its an st204.
most important wires i need to know, accesory wire, remote wire, ground wire, battery! basically the major wires used to intstall a headunit. If anyone has the complete list ill be kissing ur ass from here till next year!!!
thanks guys.
post Jun 15, 2003 - 4:21 AM
SiKBOY
Joined Nov 4, '02
From Sydney, Australia
Whats doing fellow Aussie? The black is probably the ground wire. As for the others, get a tester! They cost $1.95 at Supercheap Auto and that will tell you the accessories and constant power. Connect the ground wire last. Most after market car radios use the same colour code for the wires if that helps. Sorry I couldnt give you any more info.
OH! you just missed out on a Celica cruise around the melbourne area. well it was half an EXA cruise and a Celica cruise.
This post has been edited by SiKBOY: Jun 15, 2003 - 4:27 AM
post Jun 15, 2003 - 5:05 AM
KAMiX
Joined Mar 4, '03
I believe what you are looking for is THIS.
Inside that PDF (be warned there are lots of images inside so its a big file) you will find full instructions for installing a cd played/head unit, and more importantly, there is a diagram mapping wires to functions - based on their location on the connector not their colour. Makes it a lot easier to understand all the wires.
I know what you're going through because I had the same drama six months ago. Took me AGES to find that diagram too.
post Jun 15, 2003 - 8:35 AM
nigz
Joined May 18, '03
From Australia
thanks for the quick help guys! much appreciated! i borrowed a current tester from a mate and please correct me if im wrong
Blue and Yellow - battery
Brown - ground
red and black - remote (power antenna)
pink and blue - remote
grey - accesories/ignition
still nothing....... what can it be????????????
post Jun 15, 2003 - 10:30 AM
KAMiX
Joined Mar 4, '03
Doh did u read that post? well as its midnight sunday as you know I couldn't be Farked going outside and pulling my dash apart, since I already knew AudioFreak has answered this question before, I dug it up. Here ya are! get it working tonight man and let me know how it goes biggrin.gif
Power Connections
Constant 12+ Blue/Yellow
Switched 12+ Gray
Ground Brown
Power Antenna Black/Red and Pink/Blue connect both wires to the radio's remote wire.
Illumination Green
Speaker Connections
Front/Right + Light Green
Front/Right - Blue
Front / Left + Pink
Front / Left - Purple
Rear / Right + Red
Rear / Right - White
Rear / Left + Black
Rear / Left - Yellow
post Jun 15, 2003 - 10:33 AM
KAMiX
Joined Mar 4, '03
what do you mean still nothing? no power?
post Jun 15, 2003 - 11:21 AM
nigz
Joined May 18, '03
From Australia
Yeah man, no power to the head unit. i really appreciate u helping me out, im gonna chuck a sickie today and do this shiet.....
theres wires everywhere!!!
post Jun 15, 2003 - 11:59 AM
SiKBOY
Joined Nov 4, '02
check the fuse, It will be in front of your right leg when you are driving if you dont know where it is.
This post has been edited by SiKBOY: Jun 15, 2003 - 12:24 PM
post Jun 15, 2003 - 11:23 PM
nigz
Joined May 18, '03
From Australia
guys thanks for everything, the wiring diagrams were magic!!!! problem was.... the wiring loom/harness for the headunit was not right, I hooked up another headunit to the instructions you guys gave me and it worked, this leaves me with the conclusion that the problem lies in the new JVC headunit. All fuses are still intact. Once again thanks guys, maybe i can return the favour some day!
Nigz
post Jun 15, 2003 - 11:43 PM
KAMiX
Joined Mar 4, '03
Lo-Fi Version Time is now: November 24th, 2024 - 7:21 PM
