Enthusiast ![]() ![]() Joined Aug 14, '04 From Toledo, Ohio Currently Offline Reputation: 0 (0%) ![]() |
is that an ATS TB inlet? looks nice. i ordered one last week!
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) ![]() |
QUOTE(gtfc115 @ Jul 9, 2006 - 2:22 PM) [snapback]453714[/snapback] is that an ATS TB inlet? looks nice. i ordered one last week! Yup, I ordered that and the GM Knock Sensor Conversion for Doc to install. Along with the healthy dose of goodies that he's putting in the car.......should be really niiiiiiice. ![]() -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) ![]() |
Fastbird, I have a question for you. Sent you PM regarding the old motor.
![]() -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Enthusiast ![]() ![]() ![]() Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) ![]() |
I wish I had that much fun when i did my swap... Makes me want to do another one.
-------------------- BANNED!
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) ![]() |
QUOTE(j0e_p3t @ Jul 6, 2006 - 4:53 PM) [snapback]452603[/snapback] i wish i knew someone like you in my area that can do that for me. I did my own and helped chahn do his ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) ![]() |
![]() ![]() -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) ![]() |
wheres the blow off valve?
and thats exactly how i routed my IC piping, i suppose great minds think alike? ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) ![]() |
![]() ![]() ![]() ![]() -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
QUOTE(brianforster @ Jul 13, 2006 - 12:36 AM) [snapback]455322[/snapback] wheres the blow off valve? and thats exactly how i routed my IC piping, i suppose great minds think alike? ![]() I guess it depends on how you routed the rest of it. From the clocked turbo, I make a compound 45* back towards the engine (to straighten it out from the turbo) and towards the passenger side, then a 45* makes it level towards the passenger side of the radiator. A 3" hole is drilled in the sheet metal between the a/c lines and the radiator, and the piping makes two 90* turns through that hole and into the inlet of the intercooler. Then out of the intercooler, it makes a series of three 45* turns to move around the driver's side foglight and back into the engine compartment, then another two 45* turns up to where it comes into view in the above pic. One 90* to make the turn and then a final 45* into the inlet ![]() -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
QUOTE(Dr_Tweak @ Jul 12, 2006 - 11:46 PM) [snapback]455411[/snapback] QUOTE(brianforster @ Jul 13, 2006 - 12:36 AM) [snapback]455322[/snapback] wheres the blow off valve? and thats exactly how i routed my IC piping, i suppose great minds think alike? ![]() I guess it depends on how you routed the rest of it. From the clocked turbo, I make a compound 45* back towards the engine (to straighten it out from the turbo) and towards the passenger side, then a 45* makes it level towards the passenger side of the radiator. A 3" hole is drilled in the sheet metal between the a/c lines and the radiator, and the piping makes two 90* turns through that hole and into the inlet of the intercooler. Then out of the intercooler, it makes a series of three 45* turns to move around the driver's side foglight and back into the engine compartment, then another two 45* turns up to where it comes into view in the above pic. One 90* to make the turn and then a final 45* into the inlet ![]() -Doc did you ever try going from the turbo to the driver side and from the throttle body, to the passenges side? seems more simple, because there isint that much room down there next to the 3in piping and radiator fans, dont you think ? This post has been edited by lagos: Jul 12, 2006 - 11:03 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
I have thought about that, and I've seen it done a number of times. I don't really like the way it looks, personally, and it "seems" like it would pick up more heat from being directly next to the downpipe on the way up and over the manifold on the throttle body side. That said, in the past I used to go on about avoiding running the piping near the hot exhaust parts, but real world experience has taught me that EVERYTHING under the hood gets extremly hot and the routing of the piping make a very marginal, if any, difference. Since then I've aimed more for going with the most direct route with the fewest bends... so that route you mentioned could be something that I may very will try out in the future.
I personally think that the most ideal route of all would be to use a top-flow intercooler with the inlet and outlet both on the driver's side, and route both pipes on the driver's side of the engine bay, with a clocked turbo (of course ![]() -Doc This post has been edited by Dr_Tweak: Jul 12, 2006 - 11:18 PM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
QUOTE I have thought about that, and I've seen it done a number of times. I don't really like the way it looks, personally, and it "seems" like it would pick up more heat from being directly next to the downpipe on the way up and over the manifold on the throttle body side. That said, in the past I used to go on about avoiding running the piping near the hot exhaust parts, but real world experience has taught me that EVERYTHING under the hood gets extremly hot and the routing of the piping make a very marginal, if any, differince. Since then I've aimed more for going with the most direct route with the fewest bends... so that route you mentioned could be something that I'll try out in the future. id like to see it done someday. if i ever clock my turbo ,thats the route i plan to take. all you have to do is heat wrap the piping that goes to the throttle body over any hot exhaust stuff. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(Dr_Tweak @ Jul 12, 2006 - 11:14 PM) [snapback]455429[/snapback] routing of the piping (to avoid heat sources) make a very marginal, if any, difference. Since then I've aimed more for going with the most direct route with the fewest bends... I agree. Glad you came around to the dark side Doc! ![]() clocking the turbo thread By the way, the install looks great. Keep up the good work. I hope you have adjusted your prices upward so that you are getting fairly compensated for your experience doing these swaps. People who have not gone through a swap themselves (or folks, like me, who have gone through one with a shop that left alot of unresolved issues) do not truly appreciate the value of a turn-key install by an experienced and skilled craftsman. Jay -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
QUOTE(jgreening @ Jul 13, 2006 - 12:30 AM) [snapback]455444[/snapback] By the way, the install looks great. Keep up the good work. I hope you have adjusted your prices upward so that you are getting fairly compensated for your experience doing these swaps. People who have not gone through a swap themselves (or folks, like me, who have gone through one with a shop that left alot of unresolved issues) do not truly appreciate the value of a turn-key install by an experienced and skilled craftsman. Jay Jay, I can assure you that I do after doing my own work on one of my Trans Am's for the past three years diagnosing a mysterious oil consumption and poor vacuum issue. It's actually the reason I went with Doc, because I know for a fact that I could have easily done the motor swap sans wiring harness myself having done a motor swap on an 89 Celica St back in 03. The removal/replacement is the easy part. I didn't want to deal with the finer details this time around. ![]() -------------------- |
Well guys, I don't have any pics for you today, but I finished up things under the hood and started it up for the first time. It cranked right up! I've got a few things to finish up, then installing an SMT6, Greddy Profec S, then getting the exhaust done and finally a dyno tune.
QUOTE(Dr_Tweak @ Jul 13, 2006 - 11:09 PM) [snapback]455883[/snapback] Well guys, I don't have any pics for you today, but I finished up things under the hood and started it up for the first time. It cranked right up! I've got a few things to finish up, then installing an SMT6, Greddy Profec S, then getting the exhaust done and finally a dyno tune. -Doc ![]() ![]() -------------------- |
Yes we are
Enthusiast ![]() ![]() Joined Jun 16, '05 From Daytona Beach, FL Currently Offline Reputation: 0 (50%) ![]() |
thumbs up.. on another monster unleashed.
sigh... i wish i have the spare cash to have the professionals do it. -------------------- Journal for my 3SGTE swap
Posting and asking qns here for my 3SGTE swap Regular on ToyotaTuners, no long on TN Lurker on celictech for my 3SGTE swap Trying to sell stuff on alltrac.net Time will tell that it is a mistake to replace the F-14 Tomcat with the F-18 Super Hornet as the carriers first line of defense. |
you are your own best "professional" . best thing about a swap, is what you learn about your car while doing it.
![]() -------------------- 15PSI - 30MPG - Megasquirt Tuned
Lo-Fi Version | Time is now: February 19th, 2025 - 9:20 PM |
