> Broke My Door
post Jul 6, 2006 - 1:55 PM
eyohannie
Joined May 20, '05
From San Diego, California
By accident I opened my door just as it was unlocking, and I messed it up so now I can't open the driver's side door from the outside. ALso, now when I roll my window down it makes a metallic screeching sound. I have no idea what to do, suggestions anyone?
post Jul 6, 2006 - 2:10 PM
the lock thing should be easy to fix if you remove the door panel
(one screw by the inner handle, one under the arm rest and the few around the edge) you will be able to see 90% of the locking arms ect.. you should be able to locate the issue...and while its off you can try and get a look at the area where its screeching
post Jul 7, 2006 - 2:13 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
well the problem prolly is that the metal arm came off the handle. and now the metal arm is hanging and scratching the window as you roll it down, making the sound.
Lo-Fi Version Time is now: January 10th, 2025 - 7:47 AM
