KYB Question |
KYB Question |
Jul 9, 2006 - 6:23 PM |
I look on ebay, and KYB's only sell the front inserts but full strut/shocks for the rear. This could be a dumb question but I've never done it but does these inserts fit any strut or only certain kinds of struts can have the shock inserts removed.
Jul 9, 2006 - 9:04 PM |
some celis with sports packages have sealed struts so theres no way of getting the shock out. go to a website that sells the full housing and shock, theres a part number somewhere
Jul 9, 2006 - 9:12 PM |
Enthusiast Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) |
The full strut assembly are for your rears. The fronts are the inserts. You would have to take your stock strut assembly and remove the insert that's in there. Hence "unscrew" it off. I was not able to just easily unscrew mine off. My inserts were sealed on, we had to use a vice to try to unscrew it. When that didn't work we took it to my friends shop and he tapped a hole at the bottom to remove the oil that may have been in the housing, heated the threads where it was sealed with a torch and was able to uncrew it.
That's just what happened with mine. You may be able to unscrew yours out and drop the inserts in. Just make sure you order the right part numbers. You should be able to pull those off tirerack.com. That's where I purchased mine. Hope this helps. -Christee- |
Jul 9, 2006 - 9:21 PM |
Here's what you'd have to do with the front strut assmebly. This is where you'd have to unscrew the shock aka the insert.
Here is one of the KYB inserts. Shown in the middle. Here are the new KYB inserts installed back onto my stock front strut assembly. And finally, here are the new rear KYB strut assembly for your reference. This post has been edited by CelicaQT: Jul 9, 2006 - 9:25 PM |
Jul 10, 2006 - 10:04 AM |
kyb does make front struts and shock inserts...for $20 more id get the whole strut..this needs to be in the stickies because its a pain to search at times.
The part numbers for them are FR: 334378, FL: 334379. front left http://www.importrp.com/product.php?produc...77&cat=0&page=1 front right http://www.importrp.com/product.php?produc...78&cat=0&page=1 This post has been edited by LewFX: Jul 10, 2006 - 10:27 AM -------------------- |
Jul 10, 2006 - 11:13 AM |
Here's the part number link from KYB. I have the "Celica(Exc.All-Trac)(W/ Rebuildable Struts)" parts.
This link will help alot more and confirm the part numbers. They matched with the parts that I ordered from Tire Rack. 94-99 Celica KYB Part Numbers I was under the impression that our models only had inserts for the fronts. I think everyone on this site has the fronts as inserts and rears as full assemblies. Can anyone else concur? -Christee- |
Jul 10, 2006 - 11:22 AM |
that use to be true that the fronts were always inserts until a member found they made sport struts like ours...so now theres full struts and shock inserts. but for $50 at the website its like buying a shock and getting the strut housing free. and looking at the kyb site...the 95-99 models and for "sealed" therefore the full strut.
monroe also makes full struts but i dont recommend them, too bumpy and painful summitracing.com also carries the sealed kybs for 60ea...shipping is 20-25...so both sites are about 120-130 for ground This post has been edited by LewFX: Jul 10, 2006 - 11:44 AM -------------------- |
Jul 13, 2006 - 6:10 PM |
Where can I get a full strut and shocks from a website that is easy to order from. I already kybs for the rear, I only need the fronts. I dont want inserts.
Jul 13, 2006 - 6:42 PM |
read my post above yours please
Jul 13, 2006 - 11:27 PM |
LewFX, I did read your post, and summit only sells the inserts.
Jul 13, 2006 - 11:30 PM |
front left
http://www.importrp.com/product.php?produc...77&cat=0&page=1 front right http://www.importrp.com/product.php?produc...78&cat=0&page=1 http://store.summitracing.com/partdetail.a...15&autoview=sku http://store.summitracing.com/partdetail.a...15&autoview=sku says gas strut, use the part # my friend. -------------------- |
Jul 16, 2006 - 2:47 AM |
I just ordered mine from SummitRacing but like I said they do not have the full strut assembly, just the inserts.
Can I install these inserts using the stock struts. I only ordered the fronts. I already had the full rear struts. Would it be hell to remove sealed struts? What are my options? -------------------- 94 Celica GT
Jul 16, 2006 - 8:15 AM |
the links i gave you are the full struts...look at the part number on the kyb website if you dont believe..
http://www.kyb.com/catalog/index.php?Actio...ID=546&x=32&y=6 the inserts are: http://store.summitracing.com/partdetail.a...15&autoview=sku if you did get the inserts, you options are simple. if you dont have the sports package your front struts wont be sealed therefore you must get non-sealed housings and put the shock inside. if yu dont have sealed then take out old shock and replace. -------------------- |
Jul 16, 2006 - 11:25 AM |
Lew, the part numbers you gave me are correct, but according to summit, they do not have the full strut.
By any chance would you know how to tell if I have non-sealed struts? I haven't really looked at my struts like really good. Could you tell by the model of the car or would you really have to look? Thanks Again!!!!!!!!!! -------------------- 94 Celica GT
Jul 16, 2006 - 3:02 PM |
did you call them? i just showed you the part numbers and i gave you the links to the inserts and the full strut, am i lost or what? take out a front strut and you'll know whether its sealed or not..the nut that covers the shock is either capped over or its removable.
Jul 16, 2006 - 5:25 PM |
lewfx, I did call they said no full struts at summit at all for the 94 celica according to the sales rep. You did give me the right part numbers though. Thanks a lot for the help man, I think I'll check if I can see if they are none sealed. thanks.
Jul 18, 2006 - 8:31 PM |
is this the right part number for the full strut with shock for my 94 celica? I just wanna make sure I get the right part. Thanks.
365092 -------------------- 94 Celica GT
Jul 18, 2006 - 10:25 PM |
Front Right: 334378, Front Left: 334379.
Jul 18, 2006 - 11:26 PM |
Enthusiast Joined Sep 24, '02 From North Carolina Currently Offline Reputation: 1 (100%) |
if summit don't have it, order somewhere else
Lo-Fi Version | Time is now: December 1st, 2024 - 6:55 AM |
