5 Pages V  < 1 2 3 4 5 >
> Not getting fuel 3sgte, Getting fuel to filter, no error codes, no fuel on spark plugs, not st
post Jul 16, 2006 - 8:58 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
you're getting closer
relay works so you can move down the circuit.
Doc should be able to guide you from here, you're on the right track
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jul 16, 2006 - 11:00 PM
jcbass7
Joined Apr 20, '06
From Florida
i'm going to have to buy more fuses and test it tommorrow to see when exactly the fuse blows, etc.
ill be around mid-day tommorrow working on the car
sent you a pm with my #
post Jul 17, 2006 - 8:34 AM
jcbass7
Joined Apr 20, '06
From Florida
ok here is the update...
the 15amp fuse blows everytime the key is put to the"on" position
thats basically it
now i just need to find out why it is frying
post Jul 17, 2006 - 6:17 PM
jcbass7
Joined Apr 20, '06
From Florida
OK with tweaks help i have made progress (for anyone who wants to know: here is the update)
the 15 amp fuse blowing was due to either a short or something with the boost controller (stock thing) anyway i broke it a while back and just pushed the broken peice back on and should have left it unplugged.
That was creating the issue,
now i crank the engine and recieve these two error codes if i am not mistaken
14 and 22
whicch are
14 - IGN No "IGF" signal to ECU 8-11 times Check Igniter, ignition coil
22 - WTR Open or short in Water Temp Sensor Check Water Temp Sensor
I am assuming that the 14 code is why the engine won't fire?
This post has been edited by jcbass7: Jul 17, 2006 - 6:24 PM
post Jul 17, 2006 - 7:55 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Hmm this is odd.
Yes, code 14 will cause the engine to not start. Double-check that you have power at the ignitor and the coil. I take it you're not getting any spark, right?
The water temp sensor is a little wierd too. Is it plugged in right? Here's a copy of the pinout for the 3SGTE engine:
It appears my server is down right now, it should be up before long. Anyway, check for continuity (low resistance) between the brown wire at the coolant temp sensor (it's the one towards the end of the upper radiator hose housing) and ground, then between the red wire and the red wire at pin THW at the ECU.
Also check for continuity between IGT at the ignitor (white) and IGT at the ECU, along with IGF (black/yellow) and IGF at the ECU.
Lastly, what year is the ECU you are running, what is the part number, and does which year set in the above pinout does your harness match?
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Jul 17, 2006 - 8:03 PM
check your harness plug that goes to the ignitor.
i had this same issue after my swap, and so did another guy who was just doing a 5sfe-5sfe swap. the problem is that the harness plug is not making good contact at one of the connectors. i think on mine it was the blue and white wire. also, doubble check that you are getting power from the main black and orange wire that feeds the coil.
Edit: it also gave me code 14
This post has been edited by lagos: Jul 17, 2006 - 8:20 PM
post Jul 17, 2006 - 8:33 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(lagos @ Jul 17, 2006 - 6:03 PM) [snapback]457427[/snapback]
Same here - that was my plug mistake on my swap. (it'll try to start for a couple cranks, then nothing)
Tweak has some good places to debug there, so you'll figure this out soon enough.
-Charlie
PS. I told you to leave the turbo VSV unplugged until after the motor started! laugh.gif
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Jul 17, 2006 - 9:25 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(phattyduck @ Jul 17, 2006 - 8:33 PM) [snapback]457435[/snapback]
-Charlie
oh boy, atleast im learning a lot!
I'll try all of those things above^^ tommorrow morning when the sun comes up wink.gif
post Jul 18, 2006 - 10:44 AM
jcbass7
Joined Apr 20, '06
From Florida
I'm going to have to draw a diagram of this.. my ecu plugs do not match either set-ep.. well let me explain
the 16 pin connecter matches the plug on the bottom diagram (91-alltrac) well the colors don't all match but the layout does.
the 22 pin is missing the 13 spot and the 4 spot wires
the 26 pin..
has wires in the
1 2 3 4 5 6 X X 9 10 11 12 13
14 X X 17 18 X 20 X X 23 24 25 26
the ecu should be froma 93 all trac JDM
here are the numbers
3SGT
89661-2B280
175000-4812
post Jul 18, 2006 - 10:54 AM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(lagos @ Jul 17, 2006 - 8:03 PM) [snapback]457427[/snapback]
I am getting power at the black and orange wire
post Jul 18, 2006 - 1:52 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Your ECU is definitely form a 92-93 celica.
Looking at some of your older posts it looks like you didn't buy a clip.
What are the part numbers for your ignitor and coil? They are not the same between 90/91 and 92/93 and may be the cause of your code 14.
Ignitor part number should be 89621-12050 for the 92/93 3SGTE.
Coil part number should be 90919-02197 for the 92/93 3SGTE.
This post has been edited by WannabeGT4: Jul 18, 2006 - 3:00 PM
post Jul 18, 2006 - 2:14 PM
jcbass7
Joined Apr 20, '06
From Florida
correct i did not buy a clip (mistake) but i actually couldn't pass the deal up on the engine and car i got together
ill go check the ignitor and coil right now
EDIT: those numbers match
so this means i DEFINTALY have a 92-93 all trac motor and parts etc.?
I was told its a 93 and i gues its checking out so far
This post has been edited by jcbass7: Jul 18, 2006 - 2:20 PM
post Jul 18, 2006 - 2:28 PM
Dr_Tweak
Joined Mar 31, '04
Okay, ECU is correct, the are you sure that the 16-pin connector doesn't match the top one in the diagram? Are you looking at the connectors the right way? The two missing pins on the 22-pin plug are fine.
And you still need to do this:
post Jul 18, 2006 - 3:06 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(jcbass7 @ Jul 18, 2006 - 2:14 PM) [snapback]457801[/snapback]
Yup, it's a gen.2 rev.2 3SGTE. The problem must be in the wiring somewhere. Doc should be able to figure it out though.
post Jul 18, 2006 - 10:31 PM
jcbass7
Joined Apr 20, '06
From Florida
how about the 26 pin...
should that have pins in the 23 even though its a 93 ?
Ill check all three plugs and continuity tommorrow morning
thanks guys
JC
post Jul 19, 2006 - 1:31 PM
jcbass7
Joined Apr 20, '06
From Florida
Ok this diagram shows EXACTLY what my wiring looks like going into the ECU
if anyone needs colors for wires ill post that too
Doc you are right i was not noticing the 16th pin missing in the 16 pin connector
Now Doc had me check continuity and here are the results
1. between brown wire and ground = low resistance (close to 0)
2. between red wire and THW at ECU = No reading at all (needle didn't move or show any signs of anything)
3. between white (igniter) and IGT at ECU = low resistance
4. between BK/Yellow (Igniter) and IGF at ECU = low resistance
ok thats basically where i am now
This post has been edited by jcbass7: Jul 19, 2006 - 1:34 PM
post Jul 19, 2006 - 4:05 PM
Dr_Tweak
Joined Mar 31, '04
Okay well the THW is an odd one, there must be a break in the wire somewhere. You'll have to search it out and see where the break is and repair it.
It looks like the IGT and IGF circuts are normal. Check to see if you have a voltage reading between IGT and E1 while cranking the engine. You should get about 1 volt. Also, you should be using a digital multimeter.
Then check for voltage between IGT and a body ground while cranking.
-Doc
post Jul 19, 2006 - 5:58 PM
jcbass7
Joined Apr 20, '06
From Florida
ok so this is a bit weird
i thought i might check the codes again to see if they were still present.
first code 22 constant
then i remember the igniter is unplugged, hook it in and jump the diagnostics again
now i get code 12, and 22
14 dissapeared..
12 from what ive found is a problem with the starter/distrubter?
PS:
if the top electrical connection was severed from the starter, would this give me code 12?
12 - RPM No "G" signal to ECU for 2 sec after crank Starting related, check distributor, starter
post Jul 19, 2006 - 6:06 PM
jcbass7
Joined Apr 20, '06
From Florida
ok well im almost positive code 12 is because the top electrical connection is severed.. or is now, on the starter. When dropping it in my friend broke the connection off of the starter but not completly. now its completly off and im getting code 12. Is there a way to fix it?
it doesn't look very easy to repair, maybe i should buy a new starter.
will the starter off of the st185 awd tranny fit? or how about the one from a manual ST?
I'm also going to assume that since i have code 12, the 14 isn't showing up due to the code 12. once i fix the started 14 will show up again?
post Jul 19, 2006 - 6:51 PM
Dr_Tweak
Joined Mar 31, '04
QUOTE(jcbass7 @ Jul 19, 2006 - 11:06 PM) [snapback]458282[/snapback]
Off the top of the starter? No, that shouldn't have anything to do with it... that code showed up because you forgot to plug in the ignitor. Clear the codes by pulling the EFI fuse for a minute, and run them again. Then attempt to start it again and then run the codes if it doesn't start.
The ST185 starter will work, but the connector is different. The ST one will not.
-Doc
This post has been edited by Dr_Tweak: Jul 19, 2006 - 6:52 PM
Lo-Fi Version Time is now: February 24th, 2025 - 8:34 AM
