5 Pages V  « < 2 3 4 5 >
> Not getting fuel 3sgte, Getting fuel to filter, no error codes, no fuel on spark plugs, not st
post Jul 20, 2006 - 9:06 AM
jcbass7
Joined Apr 20, '06
From Florida
Ok well i cleared the codes and 12 went away now its just a constant code 22.
can i run a new wire for the red wire to THW to see if it cures code 22?
i can't test to see if she will start since the starter is not grounded or what not so im either going to have to think of something genius to get that part hooked back up, buy a new starter or use the ST185 starter.
but for right now im on my way to sears to buy a digital multimeter and gooood saudering iron to attempt to band-aid my starter's ground
post Jul 20, 2006 - 3:33 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(jcbass7 @ Jul 20, 2006 - 7:06 AM) [snapback]458528[/snapback]
The starter is grounded through the transmission. The main wire (thick) is the power to the starter, the smaller wire is the power to the solenoid that allows the starter to work. You can check if you are getting power at the smaller wire when you are cranking the car (though, if the starter turns the motor, this isn't your problem).
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Jul 20, 2006 - 4:39 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(phattyduck @ Jul 20, 2006 - 3:33 PM) [snapback]458649[/snapback]
-Charlie
ok then it wasn't ground,
the smaller wire snapped completly off.
i replaced the whole starter with the one from the ST185 AWD tranny and it works fine
I am only getting code 22 now,
but she still won't start
QUOTE(Dr_Tweak @ Jul 19, 2006 - 6:51 PM) [snapback]458304[/snapback]
Off the top of the starter? No, that shouldn't have anything to do with it...
-Doc
Nope it turned out to be the power to the soleniod, as pointed out above.
only error i get now is 22, still no starting
post Jul 20, 2006 - 4:47 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Okay so now it's cranking, but you have no start, and only code 22?
Run a new wire from the red wire at the sensor to the right wire on the ECU, then try again. That may prevent your engine from starting.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Jul 20, 2006 - 4:50 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(Dr_Tweak @ Jul 20, 2006 - 4:47 PM) [snapback]458694[/snapback]
-Doc
ok so i'm basically running a new wire for the red on off of the temp sensor?
ill be back in ten min to let you know how it works
post Jul 20, 2006 - 4:59 PM
jcbass7
Joined Apr 20, '06
From Florida
ok ran a new wire and still getting code 22 (cleared it, etc.)
post Jul 20, 2006 - 5:06 PM
Dr_Tweak
Joined Mar 31, '04
Is it plugged in? Does the brown wire have continuity to ground?
-Doc
post Jul 20, 2006 - 5:10 PM
jcbass7
Joined Apr 20, '06
From Florida
ill check, brb one sec
ok im not incredibly sure i do this right, but with the ohm meter set on 200 (not 200k, just plain old 200) with a digital multi meter the brown wire reads around 60 ohms when grounded
post Jul 20, 2006 - 5:12 PM
Dr_Tweak
Joined Mar 31, '04
Run a wire from the brown wire to a good ground and try it again.
-Doc
post Jul 20, 2006 - 5:24 PM
jcbass7
Joined Apr 20, '06
From Florida
ok i ran the ground, and now after clearing the codes if i try to read codes i get a fast constant blinking
i'm assuming that means there are no engine codes?
still won't start just cranks and cranks
my exhaust is not hooked up, could this cause any back pressure issues, etc?
post Jul 20, 2006 - 5:28 PM
Dr_Tweak
Joined Mar 31, '04
Okay, DO you have spark?
post Jul 20, 2006 - 5:46 PM
jcbass7
Joined Apr 20, '06
From Florida
Yes i do, i even got shocked checking it.
I tested the lead going to the distributer and that had plenty of spark when touched to a ground
the guy i got this all from put platinum spark plugs in it, and i know people here don't like those but those shouldn't cause a problem right?
post Jul 20, 2006 - 5:51 PM
Dr_Tweak
Joined Mar 31, '04
No, should be fine. Is your fuel pump running when you jumper +B and FP? (Key on)
Are you sure the plug wires are in the right order?
If that all is good, then crank the engine for like 10 seconds and then pull out a couple of your plugs. Do they have fuel on them? Do they smell of fuel?
-Doc
This post has been edited by Dr_Tweak: Jul 20, 2006 - 5:52 PM
post Jul 22, 2006 - 6:32 PM
jcbass7
Joined Apr 20, '06
From Florida
ok i beleive the wires are in the right order, 1-3-4-2?
but anywho, i cranked away for a little while and then pulled the plug that was accessable without moving the intercooler and it was dry as a desert. couldn't smell fuel or anything.
When i put the key to on, i hear the fuel pump wine on etc.
i'm going to crack the top of the fuel filter to see if fuel is getting there,
what else should i do?
post Jul 22, 2006 - 6:48 PM
jcbass7
Joined Apr 20, '06
From Florida
ok i AM getting fuel at the top of the fuel filter, so this means the issue is between the fuel filter and the cylinders right?
either my fuel rail is crap, or my injectors all need to be cleaned and tested..
Tell me otherwise if i am wrong..
thanks guys
post Jul 22, 2006 - 7:15 PM
jcbass7
Joined Apr 20, '06
From Florida
ok so i ran the codes for the fun of it...
now im getting code 24 and 31!
EDIT: my stupidity strikes again, after reading what those codes were i soon realized that my airflow metere must be unplugged and sure enough it was
Codes are gone now
This post has been edited by jcbass7: Jul 22, 2006 - 7:23 PM
post Jul 22, 2006 - 8:44 PM
you do realize that the firing order has nothing to do with how the plug wires should be hooked up, right? standing in front of the motor, you should have them hooked up as 1-2-3-4.
the afm must be pluged in, and all the inake piping must be on there air tight. if its not then the car will not run.
do you have any pics of your angine bay. maybe we can spot something you forgot to hook up.
post Jul 22, 2006 - 8:53 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(lagos @ Jul 22, 2006 - 8:44 PM) [snapback]459649[/snapback]
Yes, i realize this, i was talking more about the distributer and how it spins counter clockwise and the cylinders need to be hooked up 1-3-4-2
The AFM is plugged in properly and the intake secure, that was just a minor issue of me forgetting to have it plugged in,
my problem now is that i am getting no fuel on the plugs after cranking for a while
i think its either my fuel rail or injectors either something is clogged or the injectors are not squirting...?
post Jul 22, 2006 - 10:20 PM
do you have your fuel injector resistor pack hooked up and bolted down?
do you hear the fuel pump come on? do you feel fuel running throught the lines when u put your hand on them while trying to start the car?
post Jul 23, 2006 - 8:24 AM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(lagos @ Jul 22, 2006 - 10:20 PM) [snapback]459681[/snapback]
hooked up = yes
bolted down = no
fuel pump come on = yes
fuel in the lines = yes i cracked the fuel filter and it spills out from there
38 User(s) are reading this topic (38 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 24th, 2025 - 11:35 AM
