Removing the interior dash components |
Jul 10, 2006 - 11:02 AM |
Enthusiast Joined Jul 6, '06 Currently Offline Reputation: 1 (100%) |
So...i want to paint all teh lil inserts in my car...the door hadles, the air vents, all that stuff.....but im not sure about how to take them off, without damaging anything...are there lil screws somewhere? or do i jsut like prop it off??
-------------------- KB |
Jul 10, 2006 - 12:48 PM |
Enthusiast Joined Aug 27, '05 From Texas Currently Offline Reputation: 0 (0%) |
The ones in the door are held with screws, the center one just pops off... but the clock will be attached. Ive never tried the air vents, but ive never seen screws for em either.
-------------------- I am now a part of the ihavemorethen16gc club! |
Jul 10, 2006 - 1:19 PM |
airvents just pop in and out
Jul 10, 2006 - 9:14 PM |
Enthusiast Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) |
There are clips holding in the passenger side air vent. I'm not sure how to actually unclip it, I just pulled really hard (broke one of the top clips but still goes back in with no problems, sits fine.)
Jul 10, 2006 - 9:21 PM |
how do you remove the pannel w/ the power window buttons and door locks?
Jul 10, 2006 - 9:22 PM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
The center actually has 2 screws in it on the bottom. The piece around the shifter needs to be removed first, this piece is just held in by clips. removing this piece will reveal the 2 screws holding in the center. drivers and passenger side vents just pull out. eccept i was never able to get the passenger side vent out cuase i didn't want to break anything
Jul 10, 2006 - 9:26 PM |
QUOTE(KB-2 @ Jul 10, 2006 - 7:21 PM) [snapback]454302[/snapback] how do you remove the pannel w/ the power window buttons and door locks? you have to remove the door panel for that. First remove all the screws. there should be like 4 or 5 i can think of right now including the one in the interior door handle. Look under the door and around the rear of it. there should be black clips. Push those in and then pop them out. that should be it i think. after you remove that then there should be one screw that needs to be removed to get the panel you are talking about off. -------------------- |
Jul 10, 2006 - 9:38 PM |
ohhh allright thanks alot !
Jul 11, 2006 - 5:48 AM |
QUOTE(MaskedMan @ Jul 11, 2006 - 10:26 AM) [snapback]454310[/snapback] QUOTE(KB-2 @ Jul 10, 2006 - 7:21 PM) [snapback]454302[/snapback] how do you remove the pannel w/ the power window buttons and door locks? you have to remove the door panel for that. First remove all the screws. there should be like 4 or 5 i can think of right now including the one in the interior door handle. Look under the door and around the rear of it. there should be black clips. Push those in and then pop them out. that should be it i think. after you remove that then there should be one screw that needs to be removed to get the panel you are talking about off. What I did was just slip a very thin screwdriver under the side of the panel. Then slide the screwdriver down to the bottom of the panel, and then pop it up from the bottom. |
Jul 11, 2006 - 12:42 PM |
QUOTE What I did was just slip a very thin screwdriver under the side of the panel. Then slide the screwdriver down to the bottom of the panel, and then pop it up from the bottom. x2 -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jul 11, 2006 - 4:47 PM |
oh there's no screw? shoot sorry my bad then, i thought there was...
Lo-Fi Version | Time is now: November 30th, 2024 - 4:07 PM |
