3sgte Oil question (i know its been covered), I just want opinions for my situation |
Jul 10, 2006 - 5:20 PM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
Im gonna try to put in at ct20b turbo in today and was wondering what kind of oil i should use in my 3sgte. Its got roughly about 73,000 miles on it. I plan on running it on 8psi daily and 13psi racing. Any suggestions? Also, i dont want to run synthetic because of its high mileage. So what brand? weight? and quantity? thanks guys : )
Jul 10, 2006 - 5:22 PM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
i just used castrol 10W 40 on mine, but a few other people i know run 10W 30, both are fine. oh and i used like 4 quarts.
This post has been edited by MaskedMan: Jul 10, 2006 - 5:23 PM -------------------- |
Jul 10, 2006 - 6:19 PM |
Enthusiast Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
First off, 73k miles is *not* high mileage for a Toyota motor. Synthetic should be fine.
What does the turbo have to do with what oil you are running? I'm wondering about the rest of the story here... -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Jul 10, 2006 - 6:25 PM |
hmm yeah 73k isn't high at all. I got like 98k now and still running strong, and my alltrac has 160k, and well.. it tries.
Jul 10, 2006 - 7:45 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
I use mobile 1 full synthetic and mobile one filters.
Jul 10, 2006 - 8:04 PM |
Enthusiast Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) |
Synthetic ftw!......I change my oil so much it seems like... Damn turbo cars always using so much oil.
-------------------- BANNED!
Jul 10, 2006 - 8:10 PM |
alright sounds good, thanks guys
Jul 10, 2006 - 8:56 PM |
QUOTE(phattyduck @ Jul 10, 2006 - 11:19 PM) [snapback]454231[/snapback] First off, 73k miles is *not* high mileage for a Toyota motor. Synthetic should be fine. What does the turbo have to do with what oil you are running? I'm wondering about the rest of the story here... -Charlie Not sure if it did or didnt, thats why i was throwing it out there. I will be running higher boost than stock so i dont want an oil that wont keep the shaft lubed. thats why i wanted a thicker oil as opposed to synthetic. |
Jul 10, 2006 - 9:03 PM |
QUOTE I plan on running it on 8psi daily i reserve the right to confiscate this turbo, unless you run it where it was ment to be run. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 10, 2006 - 9:15 PM |
QUOTE(lagos @ Jul 11, 2006 - 2:03 AM) [snapback]454287[/snapback] QUOTE I plan on running it on 8psi daily i reserve the right to confiscate this turbo, unless you run it where it was ment to be run. I have a turboxs dual stage boost controller, 13 psi is just a flick of the switch away with gas prices the way they are, for a to b drives 8psi should be enough. Unless its late at night and freeways clear than thats a different story. Edit:13psi not 14 (just yet) This post has been edited by eggman40: Jul 10, 2006 - 9:16 PM |
Jul 10, 2006 - 9:18 PM |
i would do 13daily and 16 race on the turbo.
Jul 10, 2006 - 9:25 PM |
give him time....lol
Jul 10, 2006 - 10:52 PM |
QUOTE(jgreening @ Jul 11, 2006 - 2:25 AM) [snapback]454309[/snapback] give him time....lol You guys are so persuasive I guess im still a little traumatized after breaking my last turbo This post has been edited by eggman40: Jul 10, 2006 - 10:52 PM |
Jul 11, 2006 - 12:49 PM |
BTW, I switched to synthetic last night. Although the weight of authority suggests that the cleaning agents in synthetic oil can break down sludge build-up that may be preventing a leak, I have read a number of posts from people with over 100k on their engines who have had no problems switching. I was paranoid about it but made the switch anyway. There is no doubt that a good synthetic oil is MUCH better for your engine longevity.
Jul 11, 2006 - 12:59 PM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Running 0w30 Castrol Full Synth. No Oil Consumption till this day (2000 miles) so I think everything is okay.
-------------------- JDM Powerplant installed, BPU coming very soon!
Lo-Fi Version | Time is now: December 3rd, 2024 - 5:05 AM |
