Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) ![]() |
![]() This post has been edited by chacha: Jul 13, 2006 - 2:42 AM |
the CT-27 is an upgraded version of the '26, with a larger TO4E 46trim compressor wheel, and a machined out housing for more flow.
its made basicly to be a alternative to the ct-20b, which you can typicly only find used. i HAVE the ct-27, and my advice would be this. if you can find a KNOWN ct-20b thats in GREAT condition, for under 500, its worth it, otherwise, its just not worth the chance you take buying a used turbo. ct-20b's are basicly unrebuildable in the USA cause you cant get the parts for them. -------------------- Former Team 5SFTE pro member ;)
hmmm..which is better for better power and better efficiency for no turbo lag?
![]() Enthusiast ![]() ![]() Joined Nov 3, '05 From Chicago Suburbs Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(chacha @ Jul 13, 2006 - 12:30 PM) [snapback]455648[/snapback] hmmm..which is better for better power and better efficiency for no turbo lag? ct27 marginally more peak hp ct20b marginally quicker spoolup (only w/ ceramic turbine ?) they are very similar in terms of efficency QUOTE ct-20b's are basicly unrebuildable in the USA cause you cant get the parts for them I have seen few ct20b rebuild kits on ebay for under $100 This post has been edited by CilverSeliST205: Jul 13, 2006 - 1:15 PM -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
QUOTE I have seen few ct20b rebuild kits on ebay for under $100 yes, however, the shaft and compressor wheel/turbine you wont. ![]() -------------------- Former Team 5SFTE pro member ;)
Enthusiast ![]() ![]() ![]() Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) ![]() |
yaahh good luck on the ct20b rebuilt kit. As it was never made in any usdm toyota car.
Between the two turbos from looking at dnyos on mr2oc. The ct27 has more potential than the ct20b. Its the same as the ct26 with a different compressor wheel. I would guess the spool is pretty much the same in both turbos. -------------------- BANNED!
Enthusiast ![]() ![]() ![]() Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
I've had the CT20b. It was better then the ct26 - but thats not saying much.
A friend of mine has the ct27 on his MR2, along with an exhaust, intake, and boost controller. The response was better then the 20b, but I still wasn't very impressed. Must need more supporting upgrades to really get the power from it. I'd say the ct27 has more potential though, and better serviceability. -------------------- Scott
West Michigan |
thanks for all your opinions and wisedom, i am contempt...for now...looking to get both turbo and test it out myself...^_^
Lo-Fi Version | Time is now: February 22nd, 2025 - 12:18 AM |
