So-Cal Car Shop is up July 20th-27th |
Jul 17, 2006 - 10:50 AM |
Enthusiast Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) |
bump for lew.
Jul 18, 2006 - 12:38 AM |
Enthusiast Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) |
will you have the garage sometime after the 11th? if you can do my suspension before the meet, i'd be interested.
This post has been edited by j0e_p3t: Jul 18, 2006 - 12:38 AM -------------------- ss-iii splitters and 404 skirts are on. which means i need to update my sig. |
Jul 18, 2006 - 9:21 AM |
talk to me on the 10th
Jul 18, 2006 - 10:58 AM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
Lew I can't make it on the 20th to 27th! Is there any other dates in Aug you're available?
Jul 18, 2006 - 11:01 AM |
depends what you need done
Jul 18, 2006 - 12:00 PM |
QUOTE(LewFX @ Jul 18, 2006 - 9:01 AM) [snapback]457711[/snapback] depends what you need done Either changing rear shoes, or drum->disc swap if I'm lucky enough to find an old GT in the junk yard. -------------------- |
Jul 18, 2006 - 12:01 PM |
junk yard..i know of 1 in san diego that has the parts
you hard on your ebrake? -------------------- |
Jul 18, 2006 - 12:13 PM |
QUOTE(LewFX @ Jul 18, 2006 - 10:01 AM) [snapback]457735[/snapback] junk yard..i know of 1 in san diego that has the parts you hard on your ebrake? When parked yes Naw my rear drums are making really really nasty squeeky noises when brake is applied. -------------------- |
Jul 18, 2006 - 3:43 PM |
Enthusiast Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
would u be able to fix my problem? my check engine light is on. was diagnosed 2 months ago bout bad map sensor (dunno if thats really the problem??) also REALLY BAD gas mileage. went from 400/tank to less than 200/tank when i put some fuel injector cleaner in there. ands been like that ever since then. went to jiffy lube to do a flush but that didnt help. i have an safc2 on there cuz of turbo, but turbo is off right now and settings are back to stock.
Jul 18, 2006 - 6:08 PM |
Enthusiast Joined Jan 28, '06 From Washington, DC Currently Offline Reputation: 0 (0%) |
Just out of curiosity, how much did it cost you to rent the shop space?
J. |
Jul 18, 2006 - 10:46 PM |
its not a real shop just a nice garage with lots of good tools
Jul 22, 2006 - 9:39 PM |
last bump
Jul 22, 2006 - 10:27 PM |
tools to fix my car? =D
Aug 6, 2006 - 4:20 PM |
i'ma be home in about 4 days... so you think you'll be able to install my springs and struts sometime before the meet? if not its cool, i can probably find some other place. thanks.
Lo-Fi Version | Time is now: November 27th, 2024 - 2:21 PM |
