> Fog Lights Wiring Diagram for the 94 - 95 Models, Especially since our years arent endowed with one.
post Jul 17, 2006 - 7:23 PM
LeonStryfe
Joined Mar 28, '06
From Brooklyn, New York
I was wondering if this wiring diagram will work? I know a couple of friends who as well as myself who arent lucky to have the stock fog lights. I just got a pair of fogs as well, but however, I only have the fogs without the wirings. So after reading up on some stuff I was wondering if this wiring diagram will work? Any inputs? If it does, hopely it'll help those who wants to install whatever type of fogs into their car.
As for the relay as reference to you guys, this was given to me by K-ESD who helped me a lot regarding wiring. IPB Image
Please tell me if its wrong so I can correct it. Once I get all inputs I'll try it out and see if it works.
This post has been edited by LeonStryfe: Jul 17, 2006 - 7:30 PM
post Jul 18, 2006 - 6:44 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
this is how i would do it personally..it just seems easier this way.
This post has been edited by MaskedMan: Jul 18, 2006 - 6:47 AM
post Jul 18, 2006 - 10:22 AM
snapshotgt
Joined Oct 12, '05
From Texas
You can also just buy one of those wiring kits from an auto store. Quick and easy.
post Jul 18, 2006 - 2:37 PM
LeonStryfe
Joined Mar 28, '06
The fogs I got are eurolite with halos in em. They have three wires comming out of them. The black is the ground, the white is connected to the fuse and the blue one is supposed to connect to the turn signal.
Fogs
which I got for a hella cheap price. The Halo is supposed to be used for just as is or it can be sync with the turn signal. I was wondering, if I dont conenct the blue wire to anything, would it just light up as is? And if I do connect it to the turn signal, which will then sync with it, which wire do I need to splice for it?
Thanks in advance
post Jul 18, 2006 - 3:17 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
OK, your turn signals should have 3 wires attached to the bulb connector.
1- 12v with parking lights on (GREEN)
2- Ground (-) (WHITE-BLACK)
3- 12v switched for turn signals (GREEN-BLACK=Left) (GREEN-YELLOW=Right)
You are going to want to splice into the first wire. Im guessing the blue wire you mention is for your halos? you would just splice that wire into the GREEN 12v so that your halos will turn on when your sidemarkers and parking lights turn on. If you leave the blue wire unpluged then your fogs should still work, but your halos will not light up.
post Jul 18, 2006 - 4:32 PM
LeonStryfe
Joined Mar 28, '06
Btw, if I decide to sync the halos with the turn signal, would that kill it's life faster? Out of curiosity and thanks again.
post Jul 18, 2006 - 4:35 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
Definitely. Halogens run at a very high temperature, so the cycling would fatigue the filament and it would fail sooner.
post Jul 18, 2006 - 5:31 PM
this is the safest and most accepted way to wire fogs.
post Jul 18, 2006 - 5:33 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
haha thats exactly the same way i have it pictured up there. eccept yours looks alot better haha.
post Jul 18, 2006 - 5:36 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
Just bought a pair of JDM foglights for the 94 st...I think im gonna wire them like batman did ....anyway i was wondering if any one knew where i would be able to get the stock switch that goes above the drivers side air vent.. rolleyes.gif
This post has been edited by Daftboy: Jul 18, 2006 - 5:37 PM
post Jul 18, 2006 - 5:39 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(94GT @ Jul 18, 2006 - 2:35 PM) [snapback]457868[/snapback]
But he doesn't want the FOG lights to blink, he just wants the HALO on the outside to blink, and i think the Halos are lit by LEDs, but that picture was kinda small so i don't know for sure. LEDs barely heat up at all (or so i heard), use very little amount of electricity, and have no problem blinking if you want them to.
QUOTE(Daftboy @ Jul 18, 2006 - 3:36 PM) [snapback]457894[/snapback]
the switch above the drivers side airvent is not for the Front foglights. It is for the rear fog lights. There was a part number in one of these threads i think....
post Jul 18, 2006 - 5:40 PM
QUOTE(Daftboy @ Jul 18, 2006 - 6:36 PM) [snapback]457894[/snapback]
http://www.6gc.net/forums/index.php?showtopic=32806
post Jul 18, 2006 - 5:44 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Well thats the rear fog switch. It would work, but if you want the actual front fog light switch that is located on the head light lever, the part number is 84140-20560
post Jul 18, 2006 - 10:16 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
OR..get one of those remote control wireless fogs wiring kit.....took me no less than 10 minutes to finsih teh job
post Jul 18, 2006 - 10:29 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I just bought some OEM fog lights to replace my PIAA's. Would it be easier/possible for me to just plug the OEM's into the PIAA wiring?
**** Photobucket
post Jul 19, 2006 - 9:43 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
if your PIAAs worked with your current wiring, then your OEM fogs should have no problem =).
Lo-Fi Version Time is now: December 4th, 2024 - 10:18 PM
