![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) ![]() |
I went to my local import yard and asked if he had any 4age's and he said the only thing he had was a 4agelc.... Anyone know what this is from or anything else about it?
Oh yeah and i also found a red-top 4age around here for sale and was wondering the same thing about it. All the ad says is "Toyota 4age Redtop engine and C52 Trans Complete Swap" This post has been edited by Celiracer18: Jul 18, 2006 - 3:19 PM -------------------- -Brian
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) ![]() |
4agelc is an old old old old old engine from the 198X MR2s and Corollas
so its not really worth swapping or anything?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) ![]() |
the 4AGELC is an early 4AGE low comp engine found in AW11s and AE86s.
EDIT: there's really no point to swap it in your car. It's not a bad engine, but the HP numbers are about the same as a 7afe anyways. It would be better to swap a 4AGE 20v in (silver top or black top) or you could try and find a 4agze. This post has been edited by MaskedMan: Jul 18, 2006 - 3:57 PM -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) ![]() |
Go for the redtop 4age with c52 swap. But first find out if it comes with an "uncut harness." And im guessing that the engine came out of a ae92 corolla gts. And if its true about the tranny, even better
oh i completely missed the part about the Red top haha.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) ![]() |
I have a 4AGELC in my MR2. It rocks in that car, but it would suck in a Celica.
![]() -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
![]() Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Plantation, FL Currently Offline Reputation: 0 (0%) ![]() |
So how many 4AGE are there?
QUOTE(WH95TE @ Jul 19, 2006 - 2:44 AM) [snapback]458042[/snapback] So how many 4AGE are there? Im guessing 5: *Smallport bluetop 4age *Largeport redtop 4age *20v 4age silvertop *20v 4age blacktop *4agze This post has been edited by netrata: Jul 19, 2006 - 3:08 PM -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Dec 28, '05 From USA Currently Offline Reputation: 0 (0%) ![]() |
i believe the bluetops never came with small ports, they're all bigports. There are two versions of the redtops (bigport, smallport), then we have the 20vs, and dont forget old old 4ages like the one mentioned earlier, but.....if i were you, i'd swap in a 20v or a 3s in my celica
Enthusiast Joined Apr 15, '06 From Plano, Tx Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(netrata @ Jul 19, 2006 - 3:07 PM) [snapback]458216[/snapback] QUOTE(WH95TE @ Jul 19, 2006 - 2:44 AM) [snapback]458042[/snapback] So how many 4AGE are there? Im guessing 5: *Smallport bluetop 4age *Largeport redtop 4age *20v 4age silvertop *20v 4age blacktop *4agze got the redtop and bluetop switched. bluetops are largeport, redtops are smallport -------------------- 1985 Toyota Corolla GT-S AE86
-Largeport 4AGE 9.4:1 CR -264* Cams -TRD 4-2-1 Header -PR 8kg/mm front coilover/KYB AGX shock -TRD 6kg/mm rear spring/TRD 8-way adjust shock |
And all of those can bolt directly onto a 7afe to make it a 7age?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 27, '03 From Nor Cal Currently Offline Reputation: 0 (0%) ![]() |
there were a LOT of different variations, not to mention valve covers on ALL of the 16V's were interchangeable, so telling the engine by the cover is a dumb way to go...
Bluetop = bigport /w small internals (early 84-86.5) Redtop = bigport /w small internals (mid 86.5-87.5) Redtop = bigport /w large internals (later 87.5-90.5) Redtop = smallport /w large internals (later'er 90.5-92) Supercharged bigport /w large internals (88-90.5) Supercharged smallport /w large internals (90.5- mid 90's) Silvertop 20V (early mid 90's) Blacktop 20V (late 90's) -------------------- "It's ok to be naked girl... I'm an artist!"
QUOTE(WH95TE @ Jul 20, 2006 - 4:37 AM) [snapback]458409[/snapback] And all of those can bolt directly onto a 7afe to make it a 7age? yes... if you're ok with having 7 something compression and 40hp... It's not an intake where you can simply bolt-on and go. There's wiring to be done... pistons to be changed... let's just go all out and call it a rebuild. -------------------- "It's ok to be naked girl... I'm an artist!"
Oh so theres A LOT more too it lol. I really need to figure out what to do to my car to get some power. Full out swaps like the 3s seem out of the question for me.
QUOTE(Kwanza26 @ Jul 20, 2006 - 12:10 AM) [snapback]458433[/snapback] QUOTE(WH95TE @ Jul 20, 2006 - 4:37 AM) [snapback]458409[/snapback] And all of those can bolt directly onto a 7afe to make it a 7age? yes... if you're ok with having 7 something compression and 40hp... It's not an intake where you can simply bolt-on and go. There's wiring to be done... pistons to be changed... let's just go all out and call it a rebuild. actually. if i remember correctly, bluetop head mated to the 7afe yields ~10:1 compression ratio. but if you really want to build a good motor you might as well match the 4age head by using 4age pistons and get some higher compression This post has been edited by Rexasaurus: Jul 20, 2006 - 1:16 AM -------------------- 1985 Toyota Corolla GT-S AE86
QUOTE(Rexasaurus @ Jul 20, 2006 - 6:15 AM) [snapback]458461[/snapback] actually. if i remember correctly, bluetop head mated to the 7afe yields ~10:1 compression ratio. but if you really want to build a good motor you might as well match the 4age head by using 4age pistons and get some higher compression You remember incorrectly. The 7AFE's stock pistons are dished and yield only 9:5 compression on the narrower, smaller 7AFE combustion chamber... the stock bigport pistons are flat and yield 9:4 compression... so if you put a head designed to make 9:4 compression with flat pistons with pistons that are dished... you make significantly less compression. Easy way to see it... the 7AFE has a much smaller compression surface on the head, so the dishes in the pistons serve also as partial combustion chambers. The 4AGE does this entirely on the head, leaving the pistons flate... so if you put the 4AG head on the 7AFE pistons... you get really low compression... cheddar? -------------------- "It's ok to be naked girl... I'm an artist!"
So along with the head, what else do I need to make a 7age?
$$$$ and lots of it, IHMO its not worth it mang
This post has been edited by pure_dx: Jul 20, 2006 - 4:34 PM |
QUOTE(Kwanza26 @ Jul 20, 2006 - 8:01 AM) [snapback]458516[/snapback] QUOTE(Rexasaurus @ Jul 20, 2006 - 6:15 AM) [snapback]458461[/snapback] actually. if i remember correctly, bluetop head mated to the 7afe yields ~10:1 compression ratio. but if you really want to build a good motor you might as well match the 4age head by using 4age pistons and get some higher compression You remember incorrectly. The 7AFE's stock pistons are dished and yield only 9:5 compression on the narrower, smaller 7AFE combustion chamber... the stock bigport pistons are flat and yield 9:4 compression... so if you put a head designed to make 9:4 compression with flat pistons with pistons that are dished... you make significantly less compression. Easy way to see it... the 7AFE has a much smaller compression surface on the head, so the dishes in the pistons serve also as partial combustion chambers. The 4AGE does this entirely on the head, leaving the pistons flate... so if you put the 4AG head on the 7AFE pistons... you get really low compression... cheddar? according to tech reference on club4ag, it says "All else being done, the engine should have 1800cc and compression ratio of between 9.8 and 11 depending on which piston and 4A-GE head you used." oh, and to add, i've ridden in several 7age powered ae86's, using totally stock 7afe bottom, with a largeport 4age head, didnt seem like it had "7" compression. i would also guess that the headgasket would play a role in that. dont know the stock thickness of the 7afe, but 4age has a 1.2mm stock gasket, and you can go all the way down to a .5mm, giving .7 more compression, then shave the head and get even more. This post has been edited by Rexasaurus: Jul 20, 2006 - 4:59 PM -------------------- 1985 Toyota Corolla GT-S AE86
Lo-Fi Version | Time is now: February 18th, 2025 - 1:41 PM |
