> 2000-2005 celica's
post Jul 18, 2006 - 5:28 PM
rayneezy23
Joined Jun 25, '06
From Bremerton, Washington
does the new body celica engines fit in our celicas
post Jul 18, 2006 - 5:40 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
not without a whole lot of custom work.
Kawi Love
post Jul 18, 2006 - 5:48 PM
QUOTE(rayneezy23 @ Jul 18, 2006 - 6:28 PM) [snapback]457890[/snapback]
can it fit? yes.
would you really wanna bother, when the 3s is the easier, better, swap? no, IMO.
post Jul 18, 2006 - 5:50 PM
sinner96ST
Joined May 15, '03
From Aurora IL
you could swap one in, but the cost of a 2zz-ge clip isn't cheap, not to mention all the custom fabrication that would have to be done. in the end, you would be disappointed and broke.
you would be better off just buying a 2000 GT-S.
post Jul 18, 2006 - 5:54 PM
rayneezy23
Joined Jun 25, '06
the 3s is a more easier swap
post Jul 18, 2006 - 6:03 PM
sinner96ST
Joined May 15, '03
From Aurora IL
QUOTE(rayneezy23 @ Jul 18, 2006 - 3:54 PM) [snapback]457906[/snapback]
yes.
post Jul 18, 2006 - 6:11 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
When I got together with a toyota tech to put in my Coilovers he informed me that the 7th Gen 6sp tranny can bolt up with little modification.... not quite the full engine but...
**** Photobucket
post Jul 18, 2006 - 6:50 PM
Trae
Joined Mar 20, '06
From martin tn
QUOTE(95CelicaST @ Jul 18, 2006 - 6:11 PM) [snapback]457913[/snapback]
st or gt
post Jul 18, 2006 - 7:13 PM
sinner96ST
Joined May 15, '03
From Aurora IL
anything is possible, the motor is small enough to fit in to the bay.
custom fabrication, lots of hours of wiring, and you'll be at 180hp with VVTL-i.
but, the 3sgte is a better platform to build off of than the 2zz-ge. if you own an ST, you'd basically be gaining another 80hp and 20-30ft lb of torque.
with the 3s you have tons more potential, higher stock HP, and less work to get it to run right due to all the knowledge + this board to go from.
so it really isn't a feasible engine swap.
post Jul 18, 2006 - 7:20 PM
pandakid
Joined Feb 12, '06
From Fresno CA
if you live in c.a. you can't put a 3s in it but you can put a GT-S motor and you will be able to pass smog. its not easy for me to put a 3s. frown.gif frown.gif
post Jul 18, 2006 - 7:41 PM
95CelicaST
Joined Feb 5, '05
st or gt
I have to believe he meant ST, as that is what he was standing there looking at. I know axels have to be fabbed, but I would have to get more info.
**** Photobucket
post Jul 18, 2006 - 8:55 PM
Rayme
Joined Feb 18, '06
From NB, Canada
If someone would do it, it would result in a "fast car", whatever people say!
-Rémy
02 SiR, 08 250R
post Jul 18, 2006 - 9:04 PM
1900WattCelica
Joined Jul 7, '04
From Germantown, WI
This is the second sticky in the Engine forum:
Celica Engine Swaps
The sixth generation Celica has various options for engine swaps. All of the feasible engine swaps that can be done to a sixth generation Celica are listed on this page. First, I'll start out with a couple of engines that people always ask about that cannot be swapped into a Celica easily.
Non-Feasible Swaps
1. 2JZ-GTE - This is the engine that resides in the '93-'98 Toyota Supra Twin Turbo. There is absolutely no way that this engine can be swapped into a sixth generation Celica easily or cheaply or legally, plus, the 3S-GTE swap(keep reading...it's down below) is so much better. For more on this, please read Charlie's excellent post below.
2. 2ZZ-GE - This is the engine that resides in the seventh generation Toyota Celica, Toyota Matrix, and the Pontiac Vibe. This engine swap is not feasible for many reasons. One reason is that you would need to change your motor mounts, change your transmission, and you would need to modify lots of other things that wouldn't need to be modified with other swaps. Another reason is that this engine is expensive. It's a pretty new engine, and chances are that you won't be able to find one in good condition in a junkyard, and if you do, it will cost you a lot of money(Much more than any of the feasible swaps listed below.) One more reason that this engine swap would not be reasonable to do is that this engine is not very powerful. Sure, it has 180 horsepower at the crank, but it really lacks low end torque. Why not just save thousands of dollars and swap in an engine that has more horsepower and more torque?
Feasible Swaps
1. 3S-GTE - This is one of the best engi
nes ever made, and guess what? It drops right in to your Celica, assuming you have a ST202, ST203, or ST204(Which is the USDM GT.) Even if you have a ST(Chassis code AT200), you can still swap this engine into your car. It will just take a bit more work, because you'll need to change motor mounts and your transmission, and a few other things. Why is this engine swap so great? First off, this is the engine used in all of the Celica GT-Fours and All-Tracs; It's made to fit into a Celica! It's also readily available, and often, you can find a ST185(fifth generation Celica All-Trac/GT-Four) front clip(Which is the front half of the car - includes engine, ecu, tranny, accessories, etc.) for around $1,500! The greatest quality about this engine is its power. From the factory, this 2.0 liter, turbocharged engine produces anywhere from 190(USDM ST165 fourth generation Celica) to 254 horsepower(JDM ST246 Toyota Caldina), depending on the generation of the engine. Because of the tuborcharger, this engine has great low-end torque as well, and has a huge power potential. In nearly every Supra that has been built by a tuning company for racing purposes, the powerful 2JZ-GTE engine has been scrapped in favor of a 3S-GTE, due to it's lightness, huge power potential, and it's durability. If you're going to do a swap and you're able to(And willing to do a little more work than other swaps if you've got a ST), this is the engine to swap in to your Celica. Period. This engine will bolt up to any Celica that has a S-series manual transaxle.
Due to request, below are the horsepower figures for some of the 3S-GTE engines:
1st Generation - 190 HP(USDM '87-'89 Celica All-Trac), 187 HP(JDM '87-'89 Celica GT-Four)
2nd Generation - 200 HP(USDM '90-'93 Celica All-Trac, USDM '91-'95 MR2 Turbo), 221 HP(JDM '90-'93 Celica GT-Four, JDM '89-'94 MR2 Turbo), 231 HP(JDM '90-'93 Celica GT-Four RC)
3rd Generation - 239 HP(Non-JDM '94-'99 Celica GT-Four), 241 HP(JDM '95-'99 MR2 Turbo), 251 HP(JDM '94-'98 Celica GT-Four)
4th Generation - 254 HP(JDM ST246 Toyota Caldina GT-Four)
2. 3S-GE - This engine is another engine that comes standard in many Celicas, including the sixth generation Celica ST202 and ST203(Which, sadly, aren't available in the US.) It's the same 2.0 liter block as the 3S-GTE, but rather than being turbocharged, this engine is naturally aspirated, resulting in less power and less torque. This engine is an option for people who have a Celica and want to do a swap, but they don't want or are not allowed to have a turbocharged car. Even without the turbocharger, this engine is still powerful though. It puts out 177 horsepower and 142 lbs. ft. of torque in the earlier models, and the later models have BEAMS VVT-i(Identified by red valve covers and intake manifolds), resulting in 197 horsepower and 152 lb. ft. of torque. Some people may think that they can swap this engine into their car and later turbocharge it, but this is not a great idea. The internal components on this engine and the 3S-GTE are drastically different, so to make this engine turbo-ready, it would require the use of internal engine parts to strengthen the engine. If you want a turbocharged engine, it'd be much, much easier and cost-effective to simply drop in a 3S-GTE in the first place. This engine will bolt up to any transmission that comes on a ST202, ST203, ST204, or ST205 with no problems, though the stock tranny may not be up to the task of handling high horsepower levels if you have a USDM GT(ST204) for example.
3. 4A-GZE - This supercharged, 1.6 liter engine, is used in some first generation Toyota MR2s(Chassis code AW11), and is also used in the AE92('88-'91) and AE101('92-'95) JDM Toyota Corollas. In the oldest versions of the AE92('88 and '89), and the AW11, this engine only produces 145 horsepower. However, in the later versions of the AE92('90 and '91), this engine produces 162 horsepower, and in the AE101 form, this engine produces 167 horsepower. This engine has excellent low end torque, and is generally recommended over the 20 valve 4A-GE for street driving because of this. This engine will swap directly into any Celica with a 7A-FE(USDM ST) because both engines are A-series engines. This engine will bolt right up to your stock USDM ST(AT200) transmission, though the stock tranny may not be able to handle the 4A-GZE's boost very well. It's advised that you simply use the tranny that comes with the 4A-GZE engine.
*This swap currently in progress by Mynzeyes (John). This will be editted accordingly as to problems/situations show fit. At this time, do this swap at your own risk, as it is NOT a direct bolt up if you use the transmission that comes in the GZE clip (if that's the route you go. smile.gif *
4. 4A-GE(20 valve) - This 20 valve(Five valves per cylinder), 1.6 liter engine is naturally-aspirated, and is found in some JDM Toyota Corollas. It comes in two versions, the first of which is the "Silver Top" version and is found in the AE101 Toyota Corolla, produced from 1992 to 1995. This version is much easier to find, and is identified by a silver valve cover. It is an older engine than the silver top, and is rated to have five less horsepower. Unfortunately, this version of the engine is over-rated, and it's estimated that this engine produces about 10-20 horsepower less than advertised by Toyota. The "Black Top" version of this engine, however, is not over-rated, and it produces right around 165 horsepower at the crank. This version of the engine is identified by a black valve cover, and this version can be found in the AE111 Toyota Corolla. Both engines have advanced and unique features, such as five valves per cylinder(Compared to the traditional four), and four individual throttle bodies(One per cylinder). With only 117 rated lb. ft. of torque, both engines lack the low end torque that the turbocharged and supercharged engines have, and these engines produce most of their power up high in the powerband through the use of variable valve timing(VVT) and the G-series head. Because of this, the 4A-GE is generally used more for race applications due to it's narrow powerband, and the 4A-GZE is generally recommended for street driving, due to its torque that is spread out throughout the entire powerband. This engine will swap directly into any Celica with a 7A-FE(USDM ST) because both engines are A-series engines. This engine will bolt right up to your stock USDM ST(AT200) transmission.
Other Solutions
If you don't wish to swap an engine into your car or are unable to(due to lack of a garage, mean parents, etc.), there are other solutions for you that can help your car go faster.
1. Turboing the 7A-FE or 5S-FE - A few people have turbocharged the 7A-FE(stock engine in the USDM ST) and the 5S-FE(stock engine in the USDM GT), and most have had good results. Burien Toyota makes a kit for the 5S-FE that allows you to run up to 7 psi of boost reliably, and JGS Tools offers many of the parts needed to turbo your 7A-FE and allow you to run around 7 psi of boost, with more information and links to where to get the necessary remaining parts.
2. Turning the 7A-FE into a 7A-GE - The idea of taking the head off of a 4A-GE engine and bolting it to the block of a 7A-FE engine to get more power has been discussed many times, and the conclusion is that it's quite a bit of work to build a hybrid 7A-GE, but it can be done. It involves taking the head off of an older 4A-GE(The blue or red top will be much easier than the 20 valve black top or silver top.) and bolting it to the 7A-FE block, configuring the timing belt(The 4A-GE or 7A-FE belts don't work.), changing or modifying the ecu and wiring(Because the 7A-FE's rev limiter limits power up high and may not work optimally with the 4A-GE intake manifold and injectors), and a few more things. Also, this conversion will not yield a whole lot more torque than the stock 7A-FE. Torque figures will be about the same as stock, though horsepower will increase a bit because of the G series head and higher redline. Club 4AG has lots of information about building a 7A-GE and has comments from people who have done this.
Where to Find Engines / Clips
Below are some companies that you can call to order an engine or front clip or rear clip to do an engine swap. I would call all of these companies, as they don't do much business(if any at all) through email.
Jarco
ToySport
Technical Power Automotive
UsedEngines.com
Venus Auto
Additionally, there are dozens of other engine importers. Searching on Google, this site, or other car websites may yield good results...just do your research before you buy.
I think that's all for now.
Have more info that's not here? PM a mod and we'll edit this post.
post Jul 20, 2006 - 12:18 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(1900WattCelica @ Jul 19, 2006 - 2:04 AM) [snapback]457957[/snapback]
Celica Engine Swaps
Non-Feasible Swaps
Heh... and that's true because someone said so (might as well collect two of each animal species and save the world). IMO... the 2ZZGE is getting cheaper and has proven to be a very good sporty 4 banger with some very very good power potential both n/a and boosted. It'll be a hell of a lot faster than a 20V and as fast if not slightly faster than a 4AGZE... so no... the 'feasible' opinion isn't feasible IMO. The only trick is doing it... cause most people like to talk rather than do.
I think Toyota people here don't like it cause the 2ZZ acts like a Honda VTEC motor... which is *gasp*... taboo. In the end... the 7th gen guys love it... the AutoX guys love it... and hell... 180hp n/a isn't exactly anything to laugh at.
This post has been edited by Kwanza26: Jul 20, 2006 - 12:19 AM
Lo-Fi Version Time is now: November 26th, 2024 - 8:17 PM
