> turbo problem
post Jul 20, 2006 - 10:29 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well ok guy..my turbo spins freely at idle but when i drive the car the turbo seems as if it gets suck or something.no boost what so ever...even with a boost controller there..it doesn't seem to boost..but it spins freely at ilde thought..any thoughts???
post Jul 20, 2006 - 12:23 PM
CilverSeliST205
Joined Nov 3, '05
From Chicago Suburbs
QUOTE(RUNNIN-LOW @ Jul 20, 2006 - 10:29 AM) [snapback]458545[/snapback]
Check for boost leaks, vaccum lines/leaks or maybe WG sticking open ?
A boost gauge is a nice device to have on a turbo car and it also helps with diagnosis of boost problems smile.gif
QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback]
i dont drive fast, i just fly low
post Jul 20, 2006 - 4:44 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Get a boost gauge on there and see what it's doing. But if you're getting no boost, it sounds like the wastegate is stuck open, or is somehow being bypassed.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Jul 20, 2006 - 11:06 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well the turbo spools up fine at free rev...but then when you drive the car it seems as if the turbo is just getting suck no clue why..it sound like a fan..not a regular turbo spool up..
post Jul 20, 2006 - 11:10 PM
burneeed
Joined Dec 18, '05
From BANNED
Get a boost gauge.... CHeck and see if you have any boost leaks... it could be anything... I meen sometimes when you have a problem tvsv starts and only lets the 3sgte.... which is what Im assuming you have boost till 5psi.. I meen theres so many possibilties of problems.... go to advance buy the sunpro boost gauge its only 20 bux!
BANNED!
post Jul 21, 2006 - 12:03 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
i have all thatstuff..like boost controller ,gauge, super afc, timer..all that good old stuff..oh yeah only pulling one pound..sad huh...turbo is in great condition not sure why not boosting..no boost leaks either...
post Jul 21, 2006 - 6:31 AM
Dr_Tweak
Joined Mar 31, '04
Are you using a CT26? What manifold and downpipe? Is the wastegate set up correctly?
-Doc
post Jul 22, 2006 - 1:37 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
yes its the ct26 turbo....stock st185 manifold and down pipe untill i get my st205 back from the tunner shop..yes the wastegate was what i thought too..but its not.. i fingure its the turbo..thats f*cked up..i thinks it the bearings or something..the turbo spools up but when you drive its just makes a fan sound it doesn't even sound like a turbo spool..not sure..but just went a borrowed a ct20b for a buddy untill i get my td06 from the shop...
post Jul 22, 2006 - 1:59 AM
burneeed
Joined Dec 18, '05
From BANNED
Jdm ceramic turbos always break... I wish I had a local buddy I could just "borrow" a ct20b off of... sounds like you have some great friends!
BANNED!
post Jul 22, 2006 - 2:08 AM
check your intercooler piping. it probably came loose and you have a boost leak.
post Jul 22, 2006 - 10:42 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well i just got news from the buddy that took the ct26... hes says that the front fin screw was on too tight..so at free rev the finns turned...but under pressure the bearings would spin but the fins wouldn't..weid huh...also he said he took it apart and found out that who ever rebuild it put something in backwards..so the fan noise was cause the turbo was blowing air back wards...now im just worry about my motor...yeah and my buddy are great..
Lo-Fi Version Time is now: February 23rd, 2025 - 1:10 PM
