> shift light issues
post Jul 20, 2006 - 8:27 PM
Griff
Joined May 25, '06
From South Carolina
ah! someone gave me a gift, a shift light
http://www.cardomain.com/item/ATM5332
and...it takes some rpm module or a huge flippin tach to make it work?
is that right? so another 80 bucks for a module?
i thought it was going to have a few wires, i would connect some power...some ground and one to the tach...and it came with a end that needed to plug into somthing...can anyone point me in the right direction? thanks
post Jul 22, 2006 - 10:06 AM
tufy
Joined Dec 3, '03
From Cyprus
you can connect it directly to ecu. with 3 wires ..power, ground. and ignition rpm wires.. but you need you cars ecu wiring diagram. do you have a cataloge of your shift light?
if not tell me to send you
post Jul 23, 2006 - 10:52 PM
Griff
Joined May 25, '06
From South Carolina
i dont, please send. thanks
so you saying i should cut off the female end of the shift light and it should have 3 wires i can run to those 3 things?
thanks for help
post Jul 24, 2006 - 6:58 AM
tufy
Joined Dec 3, '03
From Cyprus
QUOTE(Griff @ Jul 24, 2006 - 4:52 AM) [snapback]460015[/snapback]
thanks for help
here is wiring or 3sge for şhift light
This post has been edited by tufy: Jul 24, 2006 - 7:00 AM
Lo-Fi Version Time is now: February 23rd, 2025 - 7:52 PM
