> Power Steering Pump
post Jul 21, 2006 - 5:35 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Anyone serviced or replaced on while the motor was in the car?? Ours tossed the belt today and upon further inspection, it's become aparrent that the nut holding the pullen on the shaft is missing and the pulley wobbles around, which is why the belt got thrown.
Anyone have a pic of an assembled power steering pump sitting around or can furnish one for me?
Also, what is the thread/pitch of the bolt that I need for there???
This post has been edited by Fastbird: Jul 21, 2006 - 5:37 PM
post Jul 21, 2006 - 5:52 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
i have mine all tore apart right now, what do you need info on? the nut that holds the wheel or the 2 bolts that mount it to the bracket? i can give some pictures aswell.
(by tore apart its not mounted to the block, belt is off, lines off)
post Jul 21, 2006 - 6:19 PM
QUOTE(Fastbird @ Jul 21, 2006 - 6:35 PM) [snapback]459240[/snapback]
hahaha got to love the post swap bugs.
its easy to work on that pump. you just have to jack up the car and undo all the engine plasitcs.
this will help:
http://www.celicatech.com/imagearchive/bgb...tem%20power.pdf
post Jul 21, 2006 - 7:37 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Yeah, but it's just simple growing pains. I was afraid the motor had to be moved somewhat because it looks VERY inaccessable.
Specifically what I need is the thread size/pitch of the bolt that holds the pulley on. I can only pray that the dowel pin in the schematic that holds the pulley from spinning is still there.
Lagos, thanks for the killer link. That helps a TON!
post Jul 23, 2006 - 3:37 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Got it fixed. The pulley retaining nut simply must have been loose and spun off. The dowel pin was still present, the belt was off but fine. I got lucky and nailed the retaining nut size first try, for future reference it's a M12x1.25 nut.
Getting it on the shaft on the other hand......it was somewhat of a pain to get up there and free the pump enough to get the clearance, but I got-r-done. I'm on the fence whether or not it was good designing or blind luck, but when I tried to take the pump off to lower it and get straight at the shaft, the top bolt that holds the pump to the bracket (the one it pivots on) didn't have the clearance to come all the way out of the bracket, but was EXACTLY the right length to bump up against the frame and pull all the way out of the pump allowing it to come out. Who know?
Thanks for the help guys, it's nice to have power steering again. biggrin.gif
post Jul 23, 2006 - 5:16 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
ill be joining the powersteering club on wednesday when my new hose comes in!
post Jul 23, 2006 - 7:14 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Click here to see my swaps
drtweak@phoenixtuning.com
post Jul 23, 2006 - 8:07 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
haha i had trouble with my power steering as well.. it was so damn hard to get my hands in down there.
Lo-Fi Version Time is now: December 4th, 2024 - 4:52 PM
