steering wheel removal, how to? |
Jun 17, 2003 - 11:12 PM |
Enthusiast Joined Jun 14, '03 From Michigan Currently Offline Reputation: 0 (0%) |
I want to put a steering wheel off the 7th generation celicas on my 95 gt and was wondering if this is possible or if anyone has done it. Also how do you remove the wheel without deploying the airbag when unhooking it?
Jun 18, 2003 - 9:38 AM |
Enthusiast Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
yup, why don't you search, i wrote a detailed removal about this on another thread. good luck finding an airbag tho.
This post has been edited by Charlie97L: Jun 18, 2003 - 9:39 AM -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Jun 19, 2003 - 10:55 PM |
Enthusiast Joined Feb 11, '03 From Phila, PA Currently Offline Reputation: 0 (0%) |
Im not 100% sure but you might be able to disable the airbags with the control unit. I had to mess with this when I installed my quickshifter, its under the center armrest. Just unscrew the bolts inside the armrest and unplug the control unit. You can see this if you look at the quickshifter how-to that coomer did. I dont know if this will absolutly disable it, but its a start.
Jun 22, 2003 - 12:46 PM |
Enthusiast Joined Apr 8, '03 From New York City Currently Offline Reputation: 0 (0%) |
ok.. lve swapped steering wheel myself..
tools: small socket wrench with torx bits (you do know what they are right??) steering wheel puller (you can find them in sears or autozone or whatever) socket for the center nut of the steering wheel big ass socket wrench with and extension steps: 1) remove airbag right behind the steering wheel are TWO HOLES on either side of the steering wheel housing at about 4 o'clock and 8 o'clock there is one torx screw in each of them, unscrew them using the torx wrench, unscrew them until you hear a click. the screws do not come out but got "snapped" into place at the upper-end of their travel. now without the screwing hold the bag in place, you can lift the bag right out.. there is a connector from the bag going into the steering column, disconnect the connector. when you put the airbag aside.. always put it FACE DOWN!!! 2) remove wheel now you see there are two big screw holes on either side of the steering wheel nut.. wheel nut is big so you need a big ass wrench with the right socket to loosen that. but its not bad at all. just make sure to use decent tools that dont slip cus you dont wanna hurt yourself. and remember to LOOSEN THE NUT a few turns AND NOT TAKING THE NUT OFF.. now with the wheel nut loose.. all you need to do is to loosen the steering wheel from the steering shaft. here's where you need the steering wheel puller a steering wheel puller is a block of metal with three long screws. the outter two screws go into the screw holes on either side of the steering shaft. and you then turn the center screw using a socket wrench to apply fource to the shaft life the wheel out. now this is the hardest part because the freaking wheel is on really really tight. but with a little resolve you will eventually POP the wheel out.. since the nut is still in place the wheel would fly out and hit your face or anything.. now you can disconnect the cruise control cable if you had one that THAT'S IT!!! oh, btw, when you put the wheel nut back in .. the torque is 25 ft-lbf.. that's why its so tight.. might wanna barrow a torque wrench cus I dont want your wheel comes loose while you drive! This post has been edited by pflau: Jun 22, 2003 - 12:50 PM |
Jun 23, 2003 - 1:53 PM |
so ya can just unplug the airbag without it goin off?
Jun 24, 2003 - 1:28 PM |
Enthusiast Joined Apr 24, '03 From NYC Currently Offline Reputation: 0 (0%) |
You'll need to disconnect the battery first, wait a few minutes, before doing the steps above. Normally, I don't really need a steering wheel puller. After you've loosen the nut holding the steering wheel to the column, use your hands and whack the steering wheel from behind a few times and it should come loose. But......I would not recommend even attempting to hook up the 7gen airbag to the 6gen. |
Lo-Fi Version | Time is now: November 28th, 2024 - 1:45 AM |
