![]() Enthusiast ![]() Joined Apr 18, '05 From Atlanta, Georgia Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(b1gr3d @ Jul 26, 2006 - 11:55 PM) [snapback]461695[/snapback] CONCLUSION: t03= smaller than ct26 which to everyone here seems too small to even be useful. BUT the fact is that it still pushes air and i am NOT looking to try to get the maximum amount of power out of it and the engine. AND using a paerformance calculator all i need to do for better performance(with this turbo) is get a compressor with 60 or super 60 trim, and even with the 45 trim i will go straight through the center 74% island and at 4500RPM i will just barely cross into the 70%(both at 7psi at 10psi it will go farther into 70%) and with the super 60 i will be just shy of the middle of the sweet spot.....so I will say it now. I will make this turbo work. It won't break any records, it won't be the most powerful, and you all might not agree with it..........BUT there is more than just a ct-26 Go for it man! Thats awesome! Screw all these naysayers here. Do what you want and be different from everyone else out there. Who cares if its not the fastest? Whats better... being just like everyone else and being fast, or doing something totally out of the ordinary (such as piggybacking 2 of those turbos together!) and learning alot by it and getting a good bit of power out of it too??? Id say go buy another one and just go crazy, engineer that beast to work! |
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) ![]() |
eh, i made a big push in the 7a turbo back in the day.. should have just went 3s and called it a day. hope your pockets are deep and dont mind the down time. good luck
Enthusiast ![]() ![]() ![]() Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
CT26 sucks. The only advantage it has is simple installation with the stock manifold. Switch over to the mitsu style turbos - more efficiant, faster spool, more boost.
-------------------- Scott
West Michigan |
are you refering to the 1.8 or 2.2????
![]() Enthusiast ![]() ![]() ![]() Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(scothaniel @ Jul 27, 2006 - 1:57 PM) [snapback]461923[/snapback] CT26 sucks. The only advantage it has is simple installation with the stock manifold. Switch over to the mitsu style turbos - more efficiant, faster spool, more boost. THANK YOU finally someone said it -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
Enthusiast ![]() ![]() ![]() Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(b1gr3d @ Jul 27, 2006 - 6:58 PM) [snapback]462091[/snapback] QUOTE(scothaniel @ Jul 27, 2006 - 1:57 PM) [snapback]461923[/snapback] CT26 sucks. The only advantage it has is simple installation with the stock manifold. Switch over to the mitsu style turbos - more efficiant, faster spool, more boost. THANK YOU finally someone said it yah it does suck.... but I would take a ct26 over some junkyard hood rigged turbo setup. and why would you care if your not looking for much power? cheep turbo = cheep performance.... -------------------- BANNED!
QUOTE(burneeed @ Jul 27, 2006 - 7:08 PM) [snapback]462132[/snapback] QUOTE(b1gr3d @ Jul 27, 2006 - 6:58 PM) [snapback]462091[/snapback] QUOTE(scothaniel @ Jul 27, 2006 - 1:57 PM) [snapback]461923[/snapback] CT26 sucks. The only advantage it has is simple installation with the stock manifold. Switch over to the mitsu style turbos - more efficiant, faster spool, more boost. THANK YOU finally someone said it yah it does suck.... but I would take a ct26 over some junkyard hood rigged turbo setup. and why would you care if your not looking for much power? cheep turbo = cheep performance.... LMAO. i just got a PM from dr tweak taht said i could get 200 out of this turbo with a 5s.......... This post has been edited by b1gr3d: Jul 27, 2006 - 8:49 PM -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
^ go for it...... junkyard turbos are.... well junkyard turbos
![]() This post has been edited by burneeed: Jul 27, 2006 - 11:59 PM -------------------- BANNED!
QUOTE(burneeed @ Jul 27, 2006 - 10:59 PM) [snapback]462263[/snapback] ^ go for it...... junkyard turbos are.... well junkyard turbos ![]() until they are rebuilt ![]() -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
QUOTE(b1gr3d @ Jul 29, 2006 - 8:29 AM) [snapback]462834[/snapback] QUOTE(burneeed @ Jul 27, 2006 - 10:59 PM) [snapback]462263[/snapback] ^ go for it...... junkyard turbos are.... well junkyard turbos ![]() until they are rebuilt ![]() your going to laugh when you see the rebuild for that turbo. -------------------- BANNED!
Who cares?? Let him do what he wants, its his money and his time. Why discourage?? If he wants to make a project out of it and learn something new why try to stop him?
![]() Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Plantation, FL Currently Offline Reputation: 0 (0%) ![]() |
Twin turbo it
i'm just gonna make a hybrid
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) ![]() |
QUOTE(JoeyIsFunny @ Jul 29, 2006 - 9:15 PM) [snapback]463038[/snapback] Who cares?? Let him do what he wants, its his money and his time. Why discourage?? If he wants to make a project out of it and learn something new why try to stop him? Agreed, it will be interesting, and you will learn alot. If it doesn't work just get the CtT26 next. I like crazy stuff like that. ![]() This post has been edited by madmods: Aug 13, 2006 - 11:09 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) ![]() |
I know that I'm a little late on this but... Good for you! I encourage pioneering of all different types of motor setups... I can also really appreciate the fact that you have not once said that it will be the fastest car on the road, or anything stupid like that. Of course you are going to get people who are critical or your ideas. The important thing is that you are happy with the way that your car turns out... Remember, that's the best part, It's your car! at the end of the day who cares what anyone else says... If you are proud to drive it, then that's all that matters.
![]() -------------------- ~bloodMoney
Lo-Fi Version | Time is now: February 24th, 2025 - 3:31 PM |
