> How do you change the TPS?, How do you change the TPS?
post Jul 24, 2006 - 9:26 PM
jordo
Joined Jul 17, '06
From Saskatoon, Saskatchewan, Canada
Hey, I'm new to the board. I just bought my 6gc about 3 weeks ago. I used to drive a 85 mr2. I'm just starting with some maintenance on my 6gc before I start with some mods.
I was driving yesterday when my check engine light came on. Diagnostics has given me a error code #41 (Throttle Position Sensor). My Hanes manual says I should have the TPS replaced by a shop, but I really don't want to spend the $$ if I don't have to. I can buy a new TPS online for $80 but I don't know how to install it.
Anyone know how or have done this?
-Jordo
post Jul 24, 2006 - 9:42 PM
jordo
Joined Jul 17, '06
Also I noticed that the TPS is located right behind the air intake... One of the first things I noticed when I bought the car was that the previous owner was driving around with the air intake hose unclamped from the air filter, leaving the open side wide out in the open. Would the dust or anything being drawn in cause any problems with the TPS, or any other problems in general?
-Jordo
post Jul 25, 2006 - 1:40 AM
puretone
Joined Jun 18, '06
From Aruba
open intake? horrible, it could possibly have messed with the TPS. I do not think its that much of a pain to replace, do it yourself.....
Toyo'd, Eibach'd, Kayaba'd & BEAMS'd :D
post Jul 27, 2006 - 2:04 PM
trey_135
Joined Jul 10, '05
From OTtawa Kansas
Hey if you do change your TPS take the the whole unit off butterfly and all its a bitch to get the botton screwww on those thiings especially if its a philips bolt like mine was just make sure you put that seal back on right and understand that that TPS is very sensitive it can raise and lower your idle with the littlest nudge u might have to toy with it to get your idle back in place good luck
post Jul 27, 2006 - 2:13 PM
Tech9ine
Joined Jun 28, '05
From MB, Canada
Whats this i here about your TPS reports? didn't you get the memo.
post Jul 27, 2006 - 5:30 PM
puretone
Joined Jun 18, '06
From Aruba
QUOTE(Tech9ine @ Jul 27, 2006 - 2:13 PM) [snapback]461902[/snapback]
i want my red stapler back!
Lo-Fi Version Time is now: November 24th, 2024 - 1:05 AM
