> Engine Temperature problem
post Jul 24, 2006 - 9:55 PM
xxdejavuxx
Joined May 24, '06
From sydney
Hey guys.
My car takes quite a while to warm up, and even when it does... it only reaches a quarter... (i guess half of where normal operating temperature is. Its winter here in australia, not freezing, but quite cold.
Can anyone give me some advice on what to check for?
post Jul 24, 2006 - 10:15 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
check your thermostate..that might be the problem...but yeah check that if its not that then what i would do is change your fluids..
post Jul 24, 2006 - 10:21 PM
Steevo
Joined Jul 19, '06
From Colorado
True. ^
Those are exact symptoms of a thermostat failing-and or being held open by something.
Don't just take it out, it is there for a reason. Plus during the winter the heater will really suck.
post Jul 24, 2006 - 10:26 PM
xxdejavuxx
Joined May 24, '06
From sydney
So the engine is running at normal temps and the thermostat is just off? nothing serious right?>
post Jul 24, 2006 - 11:05 PM
Steevo
Joined Jul 19, '06
From Colorado
NO, it needs to be changed.
post Jul 25, 2006 - 6:42 PM
xxdejavuxx
Joined May 24, '06
From sydney
How do i change the thermostat??
Is there a how-to anywhere?
post Jul 25, 2006 - 7:19 PM
Steevo
Joined Jul 19, '06
From Colorado
A Haynes-Chilton manula can be had for a few dollars and will tell you all you need to know.
I picked mine up at Autozone here, but any parts store should have them or be able to get them.
post Jul 25, 2006 - 8:31 PM
ExSane
Joined Apr 17, '06
From under your bed.
Water pump might be broken?
Lo-Fi Version Time is now: November 30th, 2024 - 9:13 PM
