Airbag Light still on..., I need help. I'm confused. |
Jul 26, 2006 - 4:23 PM |
Enthusiast Joined Apr 17, '06 From under your bed. Currently Offline Reputation: 4 (100%) |
Hey guys. I really need help. Ok, I just finished installing both my Air Bags. I unbolted and rebolted everything and plugged in all sensors. Both of the sensors for both of the Air bags are plugged in. For some reason, the air bag light is still on? I don't know why. Anybody can tell me if I did anything wrong?
Jul 26, 2006 - 5:06 PM |
did you change the SRS ECU ? did you reset the system completely (remove the negative battery cable for about a min) ?
Jul 26, 2006 - 5:13 PM |
here is a link with all of the info you will need to check the codes
http://www.6gc.net/forums/index.php?showtopic=29856 -------------------- |
Jul 26, 2006 - 5:58 PM |
Yeah I already disconnected negative battery terminal for about 2 minutes and reconnected it. But it still has the air bag light on. SRS ecu???!?
Jul 26, 2006 - 7:17 PM |
you didn't replace the SRS ECU ....? that is your problem right there. Once the bags have been deployed, the unit must be replaced or the system will not work properly. Check the codes asap and see what you get.
Jul 26, 2006 - 8:27 PM |
My light has been on sence my alarm was installed, the guy probed the wrong wire, and the light came on, no idea why.. but its still on.. |
Oct 5, 2006 - 3:26 AM |
Hey, sorry for bringing up an old post. I still haven't gotten my SRS ECU in yet. LoL. But yeah, anyways, will this work??? >>> http://cgi.ebay.com/ebaymotors/1995-Toyota...1QQcmdZViewItem
Lo-Fi Version | Time is now: December 2nd, 2024 - 7:47 PM |
