![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) ![]() |
woul a pair of st205 axles work with a 3sgte and a e153 and the stock gt spindles?? what axle combo if any would i neeed
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(urbandork @ Jul 26, 2006 - 7:54 PM) [snapback]461670[/snapback] woul a pair of st205 axles work with a 3sgte and a e153 and the stock gt spindles?? what axle combo if any would i neeed ST205 Axles have the wrong inner splines for the E153 tranny and don't unbolt like ST185 axles. The side that goes behind the motor is also WAYYYY to short without a transfer case. The outer splines would be fine in your hubs, but that doesn't matter so much... -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
I'm pretty sure you need the MR2 inners and either the Camry V6 from ~90~94 or ST185 outers.
I'll be looking the part numbers up for team_omega later tonight so I'll go ahead and post them up here too. EDIT: yup, that's what you need plus a spacer: http://www.6gc.net/forums/index.php?showtopic=32626 Jay, Super, and Burneed both used a section of another axel I belive... celica3sgte had a spacer machined if I'm not mistaken. This post has been edited by WannabeGT4: Jul 27, 2006 - 1:36 PM -------------------- ![]() Project ST204.5 99.88946% complete... |
QUOTE(WannabeGT4 @ Jul 27, 2006 - 11:19 AM) [snapback]461878[/snapback] I'm pretty sure you need the MR2 inners and either the Camry V6 from ~90~94 or ST185 outers. I'll be looking the part numbers up for team_omega later tonight so I'll go ahead and post them up here too. EDIT: yup, that's what you need plus a spacer: http://www.6gc.net/forums/index.php?showtopic=32626 Jay, Super, and Burneed both used a section of another axel I belive... celica3sgte had a spacer machined if I'm not mistaken. Camry V6 and MR2 non-LSD inner axles are the same, other than a possible slight difference where the carrier bearing is on the axle (1/4" to 1/2" depending on year). I was able to use complete '90 auto V6 Camry axles on my E153 tranny. You may still need a spacer since the 6GC might be wider than my Camry... -Charlie -------------------- 2003 Subaru WRX Wagon
Enthusiast ![]() ![]() ![]() Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) ![]() |
i used mr2 inners/st185 outers and i had to make a spacer to make the passenger side work.
-------------------- BANNED!
lol to much work ill jsut got all wheel drive lol maybe
QUOTE(urbandork @ Jul 27, 2006 - 11:45 PM) [snapback]462308[/snapback] lol to much work ill jsut got all wheel drive lol maybe Give me a call... maybe we can work something out. ![]() -Charlie -------------------- 2003 Subaru WRX Wagon
Enthusiast Joined May 17, '08 From STP Currently Offline Reputation: 0 (0%) ![]() |
What year mr2 inner did u guys use for passangeer side?
Enthusiast ![]() Joined Dec 3, '08 From Summerville, SC Currently Offline Reputation: 0 (0%) ![]() |
MR2 inners, and 88 All-Trac outters, no spacer needed. I've done this. it's flawless, plus you can get the All-Trac outters at Advance for $30 with a lifetime warranty. Need I really explain more?
-------------------- www.tweakdperformance.com
sales@tweakdperformance.com |
Lo-Fi Version | Time is now: February 13th, 2025 - 6:10 PM |
