20v 7afe |
20v 7afe |
Jul 28, 2006 - 5:03 AM |
Enthusiast Joined Apr 23, '06 From Cape Town South Africa Currently Offline Reputation: 0 (0%) |
hi folks does any one know how reliable such a setup is.
Jul 28, 2006 - 11:32 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(Toynado @ Jul 28, 2006 - 10:03 AM) [snapback]462340[/snapback] hi folks does any one know how reliable such a setup is. Properly built it would be plenty reliable. The recommendation that I would make, if someone asked me to do it, is to just go for a better engine though. By the time you buy the 20v, then rebuild everything with new parts and all the machine work and so on, you could have a 3SGTE in there. ESPECIALLY with a Celica. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Enthusiast Joined Nov 14, '04 Currently Offline Reputation: 0 (0%) |
Not really since you would still have to modify mounts for a st. If someone wanted to do all the work they could put it together themselves, but a 3sgte would require skills alot of us dont have.
Jul 28, 2006 - 11:45 AM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
if you can turn a wrench, you can work on your own car. i completed my swap, got some help with the wireing, and figured out the rest with the help of the site. youd be suprised what you can do
Jul 28, 2006 - 12:44 PM |
QUOTE(SinisterWhisper @ Jul 28, 2006 - 12:32 PM) [snapback]462433[/snapback] Not really since you would still have to modify mounts for a st. If someone wanted to do all the work they could put it together themselves, but a 3sgte would require skills alot of us dont have. that motor mount modification is a joke. you get a drill and drill a hole in the exact spot thats already premarked for you. people make it out to seem like its harder then it really is. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 28, 2006 - 1:27 PM |
search 7age......4age 20v head on a 7afe block
Jul 28, 2006 - 1:38 PM |
QUOTE(SinisterWhisper @ Jul 28, 2006 - 4:32 PM) [snapback]462433[/snapback] Not really since you would still have to modify mounts for a st. If someone wanted to do all the work they could put it together themselves, but a 3sgte would require skills alot of us dont have. Doing a 3SGTE swap into an ST is LOT easier and less work then rebuilding and putting together two different engines. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jul 28, 2006 - 2:18 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
all i wanted to add is that with any engine there can be hidden problems like example getting a 3sgte getting it just to find out that a 10 year old (depending on gen) engine is on its last leg
the 3sgte is a proven power plant but not many guys on here take it much further than just a swap 7age or 7age 16v or 20v is a fun motor if your staying n/a is not a huge power gain but you do gain ok we will break it down like this a st celica and a guy or girl with some automotive knowledge 3sgte motor 20v 4age gt tranny use the c52 no cost wiring harness wiring harness custom shafts use stock c52 shaft no cost but on the 7age you have to tear apart the 20v take the head pistons and a few other items. then put them in a 7afe block 7afe rods with 20v pistons new head gasket and adjustable gears to get your timing right all in all (of how hard it is to build) i think a 7age project on a scale of 1 -10 is an 8 where as the 3sgte is a 5 or 6 -------------------- yea your 3sgte is cool but ill stick to my 7agte
Lo-Fi Version | Time is now: November 28th, 2024 - 4:50 AM |
