Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) ![]() |
i just got them....installed it, but my car shakes like crazy....it shakes very bad at idle and when i drive it flooring it and coming to a stop....the shifting is smoother, but this loud nosy shake is driving me crazy...any one got a solution?
Enthusiast ![]() Joined Apr 11, '06 From Smyrna, TN Currently Offline Reputation: 0 (0%) ![]() |
i just got them....installed it, but my car shakes like crazy....it shakes very bad at idle and when i drive it flooring it and coming to a stop....the shifting is smoother, but this loud nosy shake is driving me crazy...any one got a solution? It seems every car is different. Some experience a lot of vibrations like you have and with others it is minimal. Most of this goes away after the inserts have settled. One thing you can do that seems to help is cut the insert to where the end is domed shape. In the picture below I just smoothed the insert out on a belt sander to make it dome shaped. This keeps the contact surface area between the insert and the motor mount bracket to a minimal. Just don't cut down any of the area around the hold as it needs to be somewhat flush with the center ring of the mount to keep the insert seated in the mount. ![]() This post has been edited by kirkosaurus: Mar 8, 2010 - 1:55 PM -------------------- |
hey kirk, my mechanic said the same tha the motor mounts were too thick...extended out more and touching the metal brackets thus causing the engine to rattle vigorously. He took them off and the rattle disappear, but suggest me to buy a new one since it has begun to crack the rubber. Is there any way i can trade u for a dome set? I don't have the time and money or tools to do it and really want these mounts to fit in the front mounts without the loud noise and rattle. Can i trade u for a set of dome shaved front mounts? The rear is good...it is just the front.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) ![]() |
The vibration does lessen once you break them in.
-------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
hey kirk, my mechanic said the same tha the motor mounts were too thick...extended out more and touching the metal brackets thus causing the engine to rattle vigorously. He took them off and the rattle disappear, but suggest me to buy a new one since it has begun to crack the rubber. Is there any way i can trade u for a dome set? I don't have the time and money or tools to do it and really want these mounts to fit in the front mounts without the loud noise and rattle. Can i trade u for a set of dome shaved front mounts? The rear is good...it is just the front. I didn't make anymore of the domed inserts but I guess if you send yours back to me I can grind them down like I did the insert pictured above. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
got these in
![]() -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
![]() Enthusiast ![]() ![]() ![]() Joined Sep 23, '08 From Hawaii Currently Offline Reputation: 10 (100%) ![]() |
anyone heard from kirk or know if hes still selling. i just ordered a set from his website but didnt get a response yet. i pm'd him also, but i dont think hes that active on this site.
anyone heard from kirk or know if hes still selling. i just ordered a set from his website but didnt get a response yet. i pm'd him also, but i dont think hes that active on this site. Sorry, I'm not on this board that often. If you ordered inserts for the Gen6 (94-99) I'm currently out of stock but should get them within the next 2 days. Sorry for the delay. thanks, -kirk -------------------- |
They settle in after a while, but you will get more vibration than the stock mounts.
One good idea is to only install the front insert and see how you like it. It should help minimize the vibration and keep the engine from rocking as much as the stock mounts. -------------------- 15PSI - 30MPG - Megasquirt Tuned
anyone heard from kirk or know if hes still selling. i just ordered a set from his website but didnt get a response yet. i pm'd him also, but i dont think hes that active on this site. Sorry, I'm not on this board that often. If you ordered inserts for the Gen6 (94-99) I'm currently out of stock but should get them within the next 2 days. Sorry for the delay. thanks, -kirk Thanks kirk. |
hey kirk, my mechanic said the same tha the motor mounts were too thick...extended out more and touching the metal brackets thus causing the engine to rattle vigorously. He took them off and the rattle disappear, but suggest me to buy a new one since it has begun to crack the rubber. Is there any way i can trade u for a dome set? I don't have the time and money or tools to do it and really want these mounts to fit in the front mounts without the loud noise and rattle. Can i trade u for a set of dome shaved front mounts? The rear is good...it is just the front. Sorry, I missed this post. If you want to send them back I can hit them with the belt sander like I did in the post above. Anyone with a belt sander can do it though. -------------------- |
I dont think the mounts are "too" thick, mine fit just perfectly after i dropped the subframe. massive vibration for 1-2weeks after that everything feels on spot. Any chance for Front (Tbelt side) motor mounts as well as the trans side?? Front left and right do just right, would be grand to have all mounts.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
i got all 4 of my motor mounts done by sending them to a suspension place who presses out the old rubber bushes, and somehow gets a template of them and fills the mounts with polyurethane liquid in the same shape as the stock rubber bushes, even with the 2 dampening holes, takes 4 days to set.
the polyurethane doesnt have a lip around the outsides like the inserts do but on the LH mount (I think it is this one) you still use the rubber shoes that padded the mount. car vibrates, but doesnt shake -------------------- Mike W
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) ![]() |
ordered mine the other day, wondering if anyone else got a tracking number?
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
just ordered a set! it shouldn't be more than two weeks for them to come in...right?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) ![]() |
just ordered a set! it shouldn't be more than two weeks for them to come in...right? i got mines in like a week. -------------------- st205 powered ss3 coupe
![]() Enthusiast ![]() ![]() Joined Feb 20, '08 From Abingdon, Maryland Currently Offline Reputation: 7 (100%) ![]() |
Just bought myself a pair as well, might as well since i'm replacing the engine mounts anyways!
![]() *edit* Holy cow! Mine just got shipped within hours of me ordering! This post has been edited by Rymaster: Jun 12, 2011 - 12:57 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) ![]() |
My front mount is pretty shot, so i ordered a set on tuesday (21st) and they were in my mailbox today (23rd). hope to install within the next couple of days
![]() -------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
Enthusiast ![]() Joined Aug 2, '10 From Melbourne, Australia Currently Offline Reputation: 0 (0%) ![]() |
Is there anyone that has had these in for more than 12 months had any issues with these, or resultant issues from chronic vibration?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) ![]() |
I've had mine in over a year and I love them.
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Lo-Fi Version | Time is now: February 17th, 2025 - 6:45 AM |
