> Belt Change, messed up my car little bit
post Aug 2, 2006 - 2:53 PM
alx22ua
Joined Jan 31, '06
From NJ
I have a little problem with my top speed, and how the car accelerates. I had my timing belt changed just resently, the damn thing snapped when I was going on a highway, thank God the valves weren't bent, so I payed about 400 dollars for the repair.
Now however when the car accelerates and reaches 4500rpms, the motor does not go any further, and it feel like it brakes the car (you know like when you go downheel, when your car is still in gear, you dont give your car anough gas, so the engine brakes the car), it feels exactly like that, only much stronger.
I've been thinking about it, and I think when they put in a new timing belt they put it on too tight or something, so it does not allow the car go above 4500rpms, also I remember they were messing around with ignition timing, that could also be a problem. What do you guys think?
post Aug 2, 2006 - 3:48 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
they dont need to be touching the ignition timing when doing a timing belt, vavle timing and ignition timing are different. it sounds like maybe they didnt get the cam and crank aligned correctly.
post Aug 2, 2006 - 11:23 PM
alx22ua
Joined Jan 31, '06
From NJ
QUOTE(Bitter @ Aug 2, 2006 - 3:48 PM) [snapback]464631[/snapback]
I really hope they did aligned everything correctly, because that sounds like I wont be able to fix anything without emptying my wallet.
I also talked to another mechanic, who said that it might be the timing problem...
Lo-Fi Version Time is now: November 28th, 2024 - 9:16 AM
