![]() Enthusiast ![]() ![]() Joined Apr 18, '03 From milwaukee, wisconsin Currently Offline Reputation: 0 (0%) ![]() |
it seems that the problem is that when it is raining and the car has collected water that something that is suppose to drain out excess water is backed up and that it causes the cars interior lights and air conditioning to turn on by itself without the key in the ignition. where should i look to find out where this backup is being caused. my guess is that it is where the drivers side door is or where the below the wipers are the drainage for that could possible be clogged and i need to find out where it is. has this happened to anyone else ever since they had their celica.
![]() Enthusiast ![]() Joined Mar 28, '05 From Dunedin, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
I had the problem with water flowing into the drivers footwell past a large group of relays, the problem could well be amongst them, turns out the water was getting in where the bonnet release cable goes thru into the space behind the front guards. To check it just take off the plastic guard above the wheel hand have a look. Hope this helps
Lo-Fi Version | Time is now: February 22nd, 2025 - 10:33 AM |
