> 3sgte wiring harness, so is this it....
post Jun 19, 2003 - 10:18 PM
ToYCeLi8
Joined Mar 6, '03
From South Central Los Angeles and Long Beach, CA
k i found this pic of a 3sgte wiring harness for an mr2/celica. But when i saw it i couldnt believe this was one of the HUGE things one would need to make the swap. So if i need this for my 95 GT, will it just connect right on to my car? Or if its the wiring harness for the mr2 3sgte does it have to be extended??
What do you guys think is it in good condition??
post Jun 19, 2003 - 10:38 PM
freestyler121
Joined Sep 28, '02
From Lancaster Ca
yes it has to be extended, i ran into this problem. very long process also you need to make 3 plugs fit,otherwise the duel pump and some relays wont work
post Jun 20, 2003 - 2:14 AM
Oh yeah no problem, u just gotta extend, it, solder the other ends from the other harness, on, and BOOM ur done...
...i need a drink
post Jun 20, 2003 - 3:12 AM
ToYCeLi8
Joined Mar 6, '03
QUOTE (Supersprynt @ Jun 19, 2003 - 11:28 PM)
...i need a drink
Honestly thanx a lot, Supersprynt. Well now i know what i have to do. And you guys are saying i only have to extend it if its an MR2 3SGTE harness or no matter what i still have to extend it if its a st-185 harness??
post Jun 20, 2003 - 8:30 AM
You gotta extend it if its a JDM harness. Because on jap cars it enters the car on the opposite side, or u can drill a hole wink.gif
I am unsure if the MR2 harness is diferrent, but i kno the ecu is, and ur not going to want to do that. The harness generally comes with the engine, and so does the ecu, if they dont I wouldnt recommend buying it.
post Jun 20, 2003 - 9:02 AM
t96f
Joined Sep 30, '02
From NS Can
This is something I meant to ask about a while ago,,IS there somewheres (possibly someone on here) that makes a wire harness for sale that you can buy to plug and play with a 3sgte and 6th gens. I would rather not get all tied up in wire harness and/or cut my stock one as switch back may happen someday after the inital swap
post Jun 20, 2003 - 12:48 PM
Qatar11 - he didnt do my harness but he helped me out alot. IM him sometime. It'll cost you tho.
This post has been edited by Supersprynt: Jun 20, 2003 - 12:49 PM
Lo-Fi Version Time is now: November 28th, 2024 - 11:40 PM
