Car not starting, trouble shooting help needed |
Aug 4, 2006 - 2:48 AM |
Enthusiast Joined Aug 14, '04 Currently Offline Reputation: 0 (0%) |
For all you car savvy people- Here's the details:
-The car cranks, but cannot start. - The car has spark. -Battery level is normal. -Igniter is working. -The timing and timing belt is fine, it did not jump teeths. - When I connected the terminals FP and +B on the diagnostics, There was pressure in the hose running to the delivery pipe. I don't know how to tell if the fuel pump is working, or if the EFI relay or other fuses are messed up. Does the fuel pump make any noise or anything when the key is on the ON switch only? Please help me with some advice on what could be wrong and how to check if the fuel pump is still good. Also, would it be safe to try to start the car while the terminals FP and +B are connected with a paper clip? Or would that be a bad idea? This post has been edited by gnetik: Aug 4, 2006 - 2:51 AM |
Lo-Fi Version | Time is now: November 30th, 2024 - 11:23 PM |
