> i didnt know an air/water intercooler setup could be so cheap?!, think this will be fine?
post Aug 5, 2006 - 2:25 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
The Intercooler $150 shipped
Intercooler link
* Supports over 600hp
* Core - 4.5" x 10.125" x 4.5 "
*3" inlet / 3" outlet
How can you screw somthing like this up, its a box with holes. so i dont mind it being ebay.
The Pump $92 shipped
ebay link
M-8501-L54**
* Production 2003 F-150 Lightning intercooler coolant circulation pump
* Inlet and outlet hose connection diameter is 19mm/3/4"
* Can be used in many coolant pumping applications
If its a part made for a huge v8 i bet it will work fine for my little 4 banger.
The Heat exchanger $???-175
I personally was thinking of cheap alternatives to buying one using:
* stock air/air 3sgte interheater.
* stock AC heat exchanger mounted infront of the Radiator.
(my ac isnt hooked up and never will be so i dont mind)
* Filling up my current front mount. < which i think will workout.
The extras Roughly under $100
Proper clamps an silicone couplers,
shouldnt be too much since there are few places needing a coupler.
Total $342, now what, like 20 bucks in hardware store fittings and hoses?
and maybe a couple bucks more for wires and switches for the pump?
I can have a pretty nice setup not buying a heat exhanger, which are only $100-$200 for under $350 bucks.(more)
Thats cheaper than a Good air/air setup and will probly out perform it in Flow, Temps, and Lag/Piping.
got any input?
post Aug 5, 2006 - 11:43 AM
CilverSeliST205
Joined Nov 3, '05
From Chicago Suburbs
QUOTE(x_itchy_b_x @ Aug 5, 2006 - 3:25 AM) [snapback]465688[/snapback]
Intercooler link
Looks like a copy of sparco... 3" inlet/outlet seem little too big...
do not use your intercooler for that its not going to be efficient for cooling water at all because of end-tank and inlet/outlet design
A good idea is to look for motorcycle radiator, i got one off ebay for my buddys turbod rsx, brand new 14"x5" paid $60 shipped
otherwise go on ebaymotors and look for an oil cooler, or order HE from summit they got them for like $180
Consider getting water reservoir thats can sustain/isolate from engine bay temps.
got any input?
Keep in mind, the more water you have in your system (bigger reservoir) the longer it will take to reach heat soak and lesser need for efficient heat exchanger. Increasing flow of the pump will maximize efficiency of IC.
Good read on-topic : A/W setup
QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback]
i dont drive fast, i just fly low
post Aug 5, 2006 - 5:28 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
sweet thanks for the info, this is the first time ive really looked into water/air. ive always had the idea it was too expensive for me to bother with it.
post Aug 6, 2006 - 5:49 AM
QUOTE(x_itchy_b_x @ Aug 5, 2006 - 6:28 PM) [snapback]465845[/snapback]
the only thing i will say john, is cheap WILL bite you in the ass on these setups.
comeon man, your not messing with the kids toy anymore, put some $$ into that thing!! wink.gif laugh.gif
post Aug 6, 2006 - 3:35 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
check out my sweet new setup.
im not that ghetto... close. but.
i found a box and made it to spec with the water/air average size unit. good for 1200hp they say.
made a 3inch turbo intake pipe with nipples for ventalation, to move the air filter.
im think im gunna go this route. probly just as effective as the st205 if not more?
also away from the hot manifold (with no cracks yet... knock on wood).
dont worry manny ive learned from day one with the 5sfte till now.
i know not to do things cheap, but i think that these products are fine.
aslong as the welds on tank are good and it doesnt leak i dont mind it only being 150 bucks lol
and the pump is on a factory ford that they have sold thousands of.
i grabbed a nice heat exchanger from a household AC unit, pretty large.
the reservoir i can use my stock washer fluid unit and fill that with ice.
i think its going to turn out to a pretty nice preforming system.
This post has been edited by x_itchy_b_x: Aug 6, 2006 - 3:43 PM
post Aug 6, 2006 - 4:02 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
I'll be interested to see how this turns out. I've wanted to do a water/air setup like this for some time and this is the first time I've seen the parts even close to affordable.
Personally, unless you can find out what brand the core is, I doubt that it's efficient enough for 800hp though.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Aug 6, 2006 - 4:36 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
my goals are never gunna be more than 400 so i dont mind it being able to not support 1200 800 w/e aslong as it out performs my current setup im happy.
post Aug 7, 2006 - 2:28 AM
phattyduck
Joined Dec 5, '05
From LA, CA
I would suggest you get a real Spearco core - I've seen those eBay cores in person... there is a difference.
The water inlet and outlets do not have enough room to allow the water to spread through the core, and the way they are layed out doesn't allow the whole core to fill with water.
You'll probably also find that the fins inside the core are not as good at transferring heat from the charge air compared to a quality core.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Aug 7, 2006 - 10:01 AM
Kadett
Joined Mar 17, '05
From The Netherlands
The intercooler you want to use is way off from what is used on the real thing. Isn't it easier to find a real radiator as used on the ST205/ST185RC Okay doubt you can find one in the US but still you could use a radiator from a smaller vehicle and put that in the front.
post Aug 8, 2006 - 8:40 AM
CilverSeliST205
Joined Nov 3, '05
QUOTE(phattyduck @ Aug 7, 2006 - 2:28 AM) [snapback]466236[/snapback]
Water will fill out the whole core, but only if the IC is positioned so water inlet is on the bottom and outlet is on the top... but generally I agree for this price you can have some OEM water IC(ebay link)
This post has been edited by CilverSeliST205: Aug 8, 2006 - 8:41 AM
post Aug 9, 2006 - 10:04 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(CilverSeliST205 @ Aug 5, 2006 - 11:43 AM) [snapback]465752[/snapback]
That's really a bit small for a heat exchanger.....
Especially for a CT26.
A good one to get is a Cobra upgrade.
post Aug 9, 2006 - 10:50 PM
jgreening
Joined Jan 17, '04
From Illinois
If you are going for 400 whp, you should invest in cams, oversize valves, BFT, injectors and an EMS first. A good FMIC on a FF car will get you there easy. You can always upgrade to W/A later - if you would even want to.
post Aug 10, 2006 - 12:32 AM
CilverSeliST205
Joined Nov 3, '05
QUOTE(alltracman78 @ Aug 9, 2006 - 11:04 PM) [snapback]467254[/snapback]
Especiall y for a CT26.
like i said before ammount of water circulated in an a/w system is proportional to requirement for heat exchange efficiency almost any motorcycle radiator will support sub-400 hp that circulates 2-4 gallons
post Aug 10, 2006 - 6:53 PM
alltracman78
Joined Aug 9, '06
From Ma
It might "support" it, but it's not going to do a tremendous job doing it.
Ever seen how big a RC heat exchanger is?
Or a ST205 one?
Even a stock Cobra/Lightning one is larger than that.
It will work, but you are MUCH better off getting one larger than that.
Lo-Fi Version Time is now: November 26th, 2024 - 9:49 AM
