Enthusiast ![]() Joined Mar 3, '08 From BP, MN Currently Offline Reputation: 0 (0%) ![]() |
for switching to stock springs again. i havent done it to my celica yet, but i've done coilovers and lowering springs multiple times on all types of civic's, accord's, integra's, and crx's and never used a spring compressor once...u just need to make sure to aim the top of the shock at a cement/concrete wall (so u dont shoot ur face off) and stand on the spring (so the back doesnt fly away)...but like i said i have never done it on a celica before, if there is need for one does anyone have one or kno where to rent one becuz im switching to teins pretty soon |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) ![]() |
F that noise. Thats how you get killed lol..... Just go rent on bro. If you want to ghetto rig it just pop the spring off while its still on the car. Just unscrew the center nut and it will pop there.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) ![]() |
I would rather pay $30 bucks for a them then to mess up the car, you or someone else.
Just to double check. Fat ones in the front and skinnier ones in the rear, correct?
Yeah, you'll see when you remove your springs.
Hey Remy. PM me your number.
Enthusiast Joined May 17, '08 From STP Currently Offline Reputation: 0 (0%) ![]() |
Rockfalls
I'm a week away from having my car turn from an st204 to an st204.5 lol.......
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 27, '06 From Soda Currently Offline Reputation: 9 (91%) ![]() |
i recommend the spring compressors. 42.80 at autozone to rent. you get your money back. btw, the rears are a bitch to remove...just dont strip the sway links or else you're doomed! LOL
![]() I'm a week away from having my car turn from an st204 to an st204.5 lol....... ey where did you order your clip from? i think i'm going to order a full clip in late summer to start on a project. im going to order a st205, with body parts ![]() -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) ![]() |
good up bccentaur3 how is the swap coming along does everything look good..have to check the head and the block and all..just want to remind u bro.ooh yeah changing spring is super easy just put 2 tires on top and buttom and turn the nut when it pops the nut and the strut mount should just pop and hit the tire..ive chang my shock like 10000 times and it get old....getting the tein set up in a couple of day and THE HONDA CHROME IS GETTING DONE NEXT WEEK CANT WAIT!!!!!!
ooh yeah the 205 engine is way bigger compare to the 185 engine you will have way more room and what not..damn your right block i forgot about the links...just go get after market ones or just get new one they are a hella a pain to take off.... This post has been edited by RUNNIN-LOW: May 22, 2008 - 9:21 PM -------------------- ![]() |
shoot you better show me your set-up. I didn't get a clip. I got a motor set instead. It came with everything I need for the swap except for the fuel pump rely. I can do without that though.
ahh man i keep on forgetting to tell u to get motor mounts too the stock ones are not going to hold up if u push it too much...fuel pump is a must fullblown has them for pretty cheap and your going to want to get slotted or cross drill brake rotors too.. mines are getting warped from going too fast and tryin to do dead stops hahaha
Got the fronts out.
I sprayed everything with liquid wrench so hopefully it should be good to go tomorrow. |
No, I already have the 255lph fuel fump. I was talking about the fuel pump relay that attatches onto the ecu. I'll upgrade my brakes if my car is running right. And I already did the poly mounts from kirkosaurous. Will they be okay?
BTW joe check out the forced induction thread lol.... -------------------- 98 Celica gt red- totaled deer
ooh that relay got u let me look around i might have one from my buddy swap..and the kirkosaurous are bombing yeah those will work out..yo 99gt if u need help and live around the east side and need help swing my me and my buddys place we can do it for u in a quickness
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) ![]() |
the springs just take a little longer when you dont have a compressor. the fronts suck but the rears are easy if the links go okay. only took 2 hours to put them in when i had access to a compressor. double that to take them out without one.
-------------------- -Brian
well good luck with the rears if your car was originally from minnesota. most likely a bitch to take out.
mine were easy cause i replaced the links last spring when i put the springs on. i got lucky
![]() -------------------- -Brian
F that noise. Thats how you get killed lol..... Just go rent on bro. If you want to ghetto rig it just pop the spring off while its still on the car. Just unscrew the center nut and it will pop there. haha i kno i got freaked out everytime i did it...but i have done it this way 9 times (on 7 different cars and 6 diff models, did mine 3 times) for a grand total of 36 shocks and im not dead or missing any eyes or appendages, so at least on 94 accord's, 89 crx's, 98 integra's, and 89, 94, and 96 civics it works without a spring compressor but like i said never done a celica before..but its the same deal right hex nut and allen wrench on top??? if so i think i should be able to do it the same |
Hey John did you have to grind the mount for the 3rd gen?....
"You're going to have to do some grinding on the passenger side engine mount bracket. you have to grind down the hump thats on this bracket in order for it to fit on the 3sgte." |
Lo-Fi Version | Time is now: February 23rd, 2025 - 4:49 AM |
