![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) ![]() |
Hey whats up Doau, Hows that turbo working anyway? It was intended to go on my civic, but ended up selling the car and parted all the turbo parts I worked so hard to get. BTW when are you going to Rock Falls? Since school is almost over I'm going to be ready to work my arse off to get that swap done before next semester. Oh I'll be running stock if I go.
This post has been edited by bccentaur3: Apr 4, 2007 - 8:13 PM -------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Enthusiast ![]() Joined May 13, '06 From Superior, WI Currently Offline Reputation: 1 (100%) ![]() |
yo, Will, its going good man, i'm gunna be running my GT with headers, and stage two clutch at the track. hopefully i'll break into the 15's cuz last time i ran i hit a 16.4 stock. thats with a .002 reaction time too. haha. well, i'll be going to St. Paul on sat the 14th to my bros house then i'll be heading out on sun the 15th like early. haha. not too sure but i'll be there on opening day. hopeing to see more 6g's this time. oh yea if i get my 3s powered rolla running in time i might bring that to the track as well. but well see. Oh and as for the turbo i ended up selling the turbo to my buddy and he put it on his civic now. I was suppose to get a t3/t4 but then the guy ended up keeping it so now i'm looking for another t3/t4.
I always wondered, how many miles does your celi have?
my celi now has 152k on it. its getting old. haha. well when bought it, it had so many problems with it but now its running pretty good.
Doua, I know I went down to your uncles shop about the 3s swap, but now I am actually thinking about a 5s build for boost. I've been thinking a lot and I'm going to Mankato for Automotive Engineering. Even though engineering is irrelevant to the build, but how much do you think it would cost for the 5s build?
Okay, any help from you turbo guys would greatly be appreciated. I am closing in on 200,000 miles on the 5s now. I know I can always do a 3s swap, but don't want to jump on the 3s bandwagon. Some of you might say just go to the junkyard and get a low mileage 5s, but what about rebuilding the 5s? What parts do I need for the motor to run about 10 psi daily? such as pistons, cams, rods ect. Again any help would greatly be appreciated.
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From St. Paul, MN(USA) Currently Offline Reputation: 8 (100%) ![]() |
QUOTE(bccentaur3 @ Apr 5, 2007 - 7:19 PM) [snapback]543665[/snapback] Okay, any help from you turbo guys would greatly be appreciated. I am closing in on 200,000 miles on the 5s now. I know I can always do a 3s swap, but don't want to jump on the 3s bandwagon. Some of you might say just go to the junkyard and get a low mileage 5s, but what about rebuilding the 5s? What parts do I need for the motor to run about 10 psi daily? such as pistons, cams, rods ect. Again any help would greatly be appreciated. to rebuild a 5s, what are you planning to do??? a 5sfte??? or a hybrid??? 5sfte you will need some parts from the 3s such as 2bar map sensor, oil return lines, the turbo (of course), i think the oil pump(not sure),pistons and rods, and the intake manifold(but you could run the 5s too). I think thats it. |
Yeah the 5sfte. I am really concerned about the high mileage on the motor and I just wanted to know what to replace internally to better suit the turbo. Are you sure all thats needed are pistons and rods?
QUOTE(bccentaur3 @ Apr 6, 2007 - 12:59 AM) [snapback]543833[/snapback] Yeah the 5sfte. I am really concerned about the high mileage on the motor and I just wanted to know what to replace internally to better suit the turbo. Are you sure all thats needed are pistons and rods? to boost 10psi..yes..but to be on the safe side -> pistons, rods, cam shaft, cam gears, retainers, valves, valve springs, and get all new seals, gaskets, and rings. That should do the job. |
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) ![]() |
Do a comp test on your motor. Get new gaskets and seals, basically replace everything rubber. Get it up to par on maintenance. Then your good.
Pressure2 5SFTE GOD! Running like 270 hp and 310tq IIRC on stock Internals! 3SGTE Exhaust Manifold 3SGTE CT-26 dual 3SGTE Down pipe 3SGTE Oil pan 3SGTE Oil drain line 3SGTE 2Bar MAP Sensor Then other stuff like fittings and crap... I've decided to go the 5sfte route because my motor only has 60,000 miles on it. |
Man you're lucky. I'm stuck with a piece of crap 200,000 mile motor. I was thinking about oprdering one of those rebuild kits that come with pistons, seals and all that stuff. The only thing that I am afraid of is that it won't do as well, because its oem stuff. I figured order the kit and get low comp. pistons. I'm not looking for 300 horses, I just want around 240.
You know how it is... prepare! haha you might want more later on.
Yes, I know i'd probably be sick of a 240 horse power car after a while, but I just want to feel the boost. It's been awhile since I've felt boost. Even having 200 horses will satisfy me as of right now as long as I cam hear the turbo spool up.
I hear you man... I sold both my 1g awd dsm and like ugh... haha now 5SFTE in progess!
so did anyone run at rockfalls?? If so, how yall do?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 11, '04 From Oakdale, MN Currently Offline Reputation: 3 (100%) ![]() |
I think the Rock falls opener is this upcoming weekend, 4/15. But yea I wanna hear some times from the guys that do run
-------------------- -Brad
95 GSX: Stock motor, fp3065, corn = 10.9 @ 140 06 R6: Strappd and sprocketed = 11.0 @ 127 01 a4: daily 94 Celica: totaled - someday have another celica thats fast instead of looks cool |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) ![]() |
i ran alot before i was turbo i could never get anything better than 16.4.....i would try and try and still nothing. but now with boost we'll see....i won't be running this time though....i'll be wearing Demized concepts sweatshirts with a small group of us...i'll be the one wearing the demized concepts baseball hat? so who's all goin so far if the snow doesn't cancel us!!!
QUOTE(Celiracer18 @ Apr 5, 2007 - 12:59 AM) [snapback]543249[/snapback] woot i got my 2 BAR MAP sensor on the way now........just a bunch more things to get in and ill be ready to start my long awaited boostfest. rick i wanna race you when im done. im curious to see how well this setup will do against a 5sfte. definately have to... who's doing your piperwork? i need some piping down and a FMIC as well. i'm probably just gonna order the IC offa ebay and also the pipe kit...but i need it fitted and i can't weld aluminum -------------------- ![]() |
rjbibeau, I'm having Boost Factory to do me my intercooler pipings. $350 for Alumunized Steel for the same exact setup as Pressure2. I showed him some pics and he can do it. Very few silicone couplers and such. I've seen his work and they're pretty good.
I might have him make me all aluminum which will be more. Stainless steel for my 3" Turboback with 70/120 HKS Carbon Ti. He won't quote on that until he looks at my car. Very nice and patient guy. |
haha that's funny chuck made me my stainless steel downpipe and my charge pipe in aluminized steel. he does good work his welds are mint. when are you plannign on getting it done? is he making you a custom intercooler with the end tanks as well or are you using ebay style?
I'm going to have him do it all. I don't stunt ebay! Haha
Lo-Fi Version | Time is now: February 13th, 2025 - 4:39 PM |
