> Diagnostic Tools, Anyone have one?
post Aug 6, 2006 - 10:51 AM
sapperk
Joined Mar 9, '03
From Orting, WA
Does any one have an Engine Diagnostic Tool to scan trouble codes?
If so, what kind do you have and how does it work. I found some online for less then $100 but are they all compatible with our cars?
post Aug 6, 2006 - 12:17 PM
laff09
Joined Jul 28, '06
From Delaware
post June 1995 produced toyota's have OBD II, goto Autozone and they'll hook it up for free. I found this out when my May produced Camry had OBD I lol
This post has been edited by laff09: Aug 6, 2006 - 12:17 PM
post Aug 6, 2006 - 1:58 PM
sapperk
Joined Mar 9, '03
From Orting, WA
I know they hook it up for free, but if can get one for less then $100 or so, its worth haveing i think. One more thing to through in the garage...
post Aug 6, 2006 - 6:24 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
QUOTE(sapperk @ Aug 6, 2006 - 2:58 PM) [snapback]466051[/snapback]
Good luck with that. A generic OBDII scanner with real time capability will cost a couple hundred. If you get one like the Auto X-Ray that comes with multiple cables for different manufacturers OBDI vehicles in addition to OBDII, those go for about $350 to well over $1K depending on where and what.
post Aug 7, 2006 - 12:39 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Snap-on tools Solus scanner... $$$$ =O
post Aug 8, 2006 - 5:59 PM
toyotatech
Joined Jun 14, '05
From colorado
i just use toyota's scan tool, i was going to buy one for about $900, but toyota is coming out with a new one and they go for about $6000. so i don't think i'll be buying my own scan tool!
post Aug 10, 2006 - 7:32 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
I use the elm based "allinone" code reader. It works on PC so you need a laptop or a PC at proximity.
In my case I'm using my carPC so the code reader is pretty much built into my car
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Aug 10, 2006 - 8:32 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I seen the same tool that AutoZone uses at Advanced Auto for $140. And I see a cheaper one at Walmart for $100. They really aren't that bad. It's a lot cheaper to make a switch to flip to check codes via check engine light.
Live Free, Be Happy
post Sep 22, 2006 - 11:23 PM
Jaws4God
Joined Mar 27, '04
so what can be done for a 95? mine is on.. i reset the ECU thursday and today (Friday) it came back on..
Lo-Fi Version Time is now: February 25th, 2025 - 1:43 PM
