> Head Gasket Leak..., ...again...
post Aug 8, 2006 - 4:54 PM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
Has anyone had any repeat issues with a head gasket leak? I was told by Toyota today that it's leaking, but I know I replaced it roughly 6 months ago! Any thoughts? Thanks in advance.
1998 Toyota Celica GT
2007 Subaru Impreza WRX STi
2007 Toyota Tacoma 4x4
1974 Datsun 260Z
1997 Subaru Legacy L Wagon
post Aug 11, 2006 - 6:32 AM
Toynado
Joined Apr 23, '06
From Cape Town South Africa
first off did your car run hot?
there can be a couple of reasons, either your head or block is warped
your headbolts can be stretched,
post Aug 11, 2006 - 6:43 AM
when you replaced it the first time, did you check the head and or block for warpage?
who did the work?
post Aug 11, 2006 - 7:21 AM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
QUOTE(presure2 @ Aug 11, 2006 - 6:43 AM) [snapback]467783[/snapback]
who did the work?
no i didn't check, but i just had a shop swap the engine. what kind of signs should i look for?
1974 Datsun 260Z
post Aug 11, 2006 - 7:31 AM
well, you need to make sure the 2 surfaces are truly flat, and smooth for the gasket to seal properly.
post Aug 11, 2006 - 7:50 PM
alltracman78
Joined Aug 9, '06
From Ma
What is the actual problem?
Are they saying it's leaking in the cylinders or outside?
Lo-Fi Version Time is now: February 18th, 2025 - 5:32 PM
