Aftermarket Springs:, Breaking ABS Sensors? |
Aug 8, 2006 - 6:20 PM |
Enthusiast Joined Jan 30, '06 From Augusta, GA Currently Offline Reputation: 4 (100%) |
As anyone ever had this issue? Anyone ever heard of this? Thanks for your time.
-Triscuit -------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
Aug 8, 2006 - 8:49 PM |
Enthusiast Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
Never heard of it happening, and based on where the wheel speed sensors are in relation to the strut, it seems unlikely in most conditions. I could be wrong, and would like to hear exactly what happened if someone did have issues.
Aug 8, 2006 - 9:03 PM |
The only way I can describe is this: My cousin and I installed all 4 Eibach Pro-Kit Springs at the dealership we used to work at, and afterwards, the light came on. That was forever ago, being the first mod I did and all when I bought the car last year July-August-ish. About 4 months ago I took my Celica to Toyota and they said all 4 ABS sensors were broken, that's why the light was on. Hope this helps! Thanks for you time.
Aug 8, 2006 - 11:54 PM |
Enthusiast Joined Jun 15, '06 From NJ Currently Offline Reputation: 1 (100%) |
that sounds odd, get a second opinion
Aug 9, 2006 - 9:25 AM |
either you did somthing to the wireing during the install, or the sensors, or toyota is mis-diagnosing the problem.
in no way should the springs affect the ABS system. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Aug 9, 2006 - 9:52 PM |
There is no way those springs would damage the sensors.
Period. Other than if the springs fell off and hit the sensor on the way down. Did you remove the sensor from the knuckle when you installed the springs? If so, you probably damaged them. It is next to impossible to remove them without damaging once they are more than a few years old. It's better to disconnect the wire connector. Or did/is the wire cut/damaged? -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:37 AM |
