![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) ![]() |
Sorry to bring up an old topic but even after reading the sticky im still confused about offset and fitment. I promise to study more on it.
![]() ps. and yes this guy is local (stupid paypal) ...ranting, sorry |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) ![]() |
With 8,5 width I dont think you would clear the shocks. I think a 15mm spacer would be sufficient.
Check the next site where you can calculate the difference between your current setup and what you want to place. http://marksink.com/tire_wheel_offset/offset.html With a 15mm spacer (effective 33mm offset) it would be The clearance from stut housing to the inside of the wheel will be 17mm LESS The outside edge of the wheel will EXTEND an extra 21mm -------------------- JDM Powerplant installed, BPU coming very soon!
QUOTE(Kadett @ Aug 10, 2006 - 5:45 PM) [snapback]467448[/snapback] With 8,5 width I dont think you would clear the shocks. I think a 15mm spacer would be sufficient. Check the next site where you can calculate the difference between your current setup and what you want to place. http://marksink.com/tire_wheel_offset/offset.html With a 15mm spacer (effective 33mm offset) it would be The clearance from stut housing to the inside of the wheel will be 17mm LESS The outside edge of the wheel will EXTEND an extra 21mm thanks for the help kadet, this will help for sure. This post has been edited by eggman40: Aug 10, 2006 - 1:01 PM |
![]() Enthusiast ![]() ![]() Joined May 24, '03 From Andrews TX Currently Offline Reputation: 1 (100%) ![]() |
I don't know if it will help any but I have some Axis Hiro 19x8.5" rims with 245/35/19 toyo T1-S Proxes with a 35mm offset and Tein S-techs
and when I hit a dip of a low slope in the road going over 45 mph my tire rubs on the inside of the wheel well in the rear, and on the outsid eof the tire(rear) I can barely even put a finger(pinky) between the tire and fender. So I thyink that 35mm offset is perfect. if you go 33 I think you would be hitting alot worse, and 38mm would rub on the fender. I know that there is alot of difference between a 19 and a 17, but they are the same width and I thought that this might help -Daniel -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Lo-Fi Version | Time is now: February 22nd, 2025 - 2:06 PM |
