> Hatch Squeaking CONSTANTLY!, Driving me insane.
post Aug 11, 2006 - 11:32 AM
hitcachi
Joined Jun 19, '05
From Nebraska
Well I've tried to fix this by tightening everything down and making sure the hatch isnt twisted or anything, but it just wont stop. My hatch rattles all the freakin time. I dont have subs or anything and never have. But with my stiff ride due to many suspension upgrades the latch just sqeaks on every single bump in the road. And there is alot of bumps in the road. If anyone has any suggestions, im open.
post Aug 11, 2006 - 2:09 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
There are 2 rubber bump stops on the back of the hatch...take the ones off that are bolted to the hatch and put a metal washer behind them and put them back on...should fill in some gap and put pressure on the hatch when its closed. Might have to try different thickness washers or a few to get it right.
post Aug 11, 2006 - 3:18 PM
Chanh55
Joined Jun 29, '03
QUOTE(bufferdan @ Aug 11, 2006 - 12:09 PM) [snapback]467908[/snapback]
x2
post Aug 12, 2006 - 2:03 AM
hitcachi
Joined Jun 19, '05
From Nebraska
it worked. wow, that was easy.
post Aug 12, 2006 - 6:51 AM
hrmmm...imma have to try that as well!
post Aug 14, 2006 - 9:18 PM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
What spot exactly are you describing? The lifter end that has the inner metallic shaft? Or the thicker outter end? A pic of where to add the washers would be great. smile.gif
QUOTE(bufferdan @ Aug 11, 2006 - 2:09 PM) [snapback]467908[/snapback]
post Aug 14, 2006 - 10:50 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(presure2 @ Aug 12, 2006 - 6:51 AM) [snapback]468139[/snapback]
same here!
post Aug 15, 2006 - 6:37 PM
Starcraftjunkie
Joined Nov 21, '05
Just did it today. Took off the screws and popped 3 washers (1/4" sized) in. One in each of the screw holes and one in the centre plastic nub part. Tried to have a stack of 2 instead of just 1, but it's too troublesome to the 2nd set in place while screwing it in.
O ya.. if any of you are going to try it, be careful after removing the screws.. the gas strut popped fully when I was getting it out, and since one end was still attached, it came outside the trench and scratched the side of my car on its way down kindasad.gif
Hopefully one set of washers will do the trick.. will update after I test it out this week.
uh oh.. I just read this a few more times and wondered if I added the washers to the rigth place... lol... the more I read it, the most it seems I did it wrong.
post Aug 15, 2006 - 11:13 PM
tim86
Joined Oct 31, '03
From Orlando, Florida
maybe a few pics for clarity? i have the same problem, dunno if its from suspension or subs... just bothers me when i dont have the subs on though tongue.gif
post Aug 15, 2006 - 11:32 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i'm assuming you mean these bump stops right?
i'm guessing these are the only ones on the hatch anyway...
post Aug 16, 2006 - 8:43 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
QUOTE(azian_advanced @ Aug 16, 2006 - 4:32 AM) [snapback]469476[/snapback]
Yes...those are the ones to add washers underneith. If you add too much the hatch wont want to "lock down" so just mess around till you get the mounts pressing up against each other tight enough to stop the hatch from banging around smile.gif
post Aug 16, 2006 - 10:30 AM
tomazws
Joined Oct 30, '04
From So Cal
Wow, I need to try this too!
post Sep 19, 2006 - 3:13 PM
vozizm
Joined Sep 18, '06
From North Carolina
very kewl idea!!
VOZ™
Lo-Fi Version Time is now: November 26th, 2024 - 3:31 PM
