> DIY: JDM Tails, with pics ;p
post Aug 11, 2006 - 9:09 PM
Deezz_Nuttz
Joined Feb 26, '06
From CA
Tools:
Flathead Screwdriver
10mm Socket & Ratchet
1.) Pop Trunk Open
2.) Pop open the covers (they are marked with a picture of a light bulb) Use the screwdriver to remove
3.) There are only 3 that you need to remove
4.)Use the 10mm Socket to unscrew the bolts holding the tails on
5.) TIP: Once it comes loose, use the socket without the ratchet to manually turn and remove the nuts
6.) Carefully wedge loose the tails using the screwdriver
7.) Remove Tails
8.) Bulb Layout for OEM tails (the JDM tails are on the bottom)
9.) Remove bulbs
10.) JDM Tails with bulbs placed (The bulbs really only go in at certain spots so you really can't "mix" the bulbs
11.) There is one bulb that is not used on the JDM Tails, I just removed the bulb
12.) Place the tails back... Insert nuts into socket. Re-screw tails in.
13.) Place the covers back, and your done
'99 GT & '06 GTI
post Aug 11, 2006 - 9:20 PM
94_st_hatchback
Joined Mar 15, '06
From Long Beach
nice write up!
" i don't work for toyota, i work for my toyota. "
post Aug 11, 2006 - 9:38 PM
XS4lv1Truch0x
Joined Dec 9, '05
From Long Beach
sticky this! lol
do one for the coupes/verts now biggrin.gif
Is this good enuff 4 ya? :D
post Aug 12, 2006 - 6:41 AM
nice write up!
moved to exterior forum, and added to the sticky!
post Aug 12, 2006 - 8:09 AM
vincent_doggy
Joined May 25, '06
From Hong Kong
Good Job!!
Nice and neat!!
post Aug 12, 2006 - 9:41 AM
b1gr3d
Joined Feb 25, '03
From Springfield, MO
step 6 is a no-no
Coming in 2010
post Aug 12, 2006 - 10:07 AM
Valo666
Joined May 15, '05
From Toronto
nice write up. seems simple enough. LOL. my gf has that same Keroppi thing on the back of her celica but she has the pink one.
post Aug 12, 2006 - 2:17 PM
Deezz_Nuttz
Joined Feb 26, '06
From CA
QUOTE(b1gr3d @ Aug 12, 2006 - 9:41 AM) [snapback]468158[/snapback]
step 6 is a no-no
I had a hard time trying to remove the OEM tails with out trying to "pry" it loose, if you want to be more careful, you can use a plastic knife.
'99 GT & '06 GTI
post Aug 12, 2006 - 2:22 PM
gt_driFFter
Joined Nov 29, '04
Awesome write-up man!
post Aug 12, 2006 - 2:29 PM
JFrost9
Joined Aug 27, '05
From Texas
I dont get it...what is this write up doing? Is it just installing JDM tails?
post Aug 13, 2006 - 4:57 PM
trdproven
Joined Aug 2, '05
From Guam
I think so. More stickies, the merrier.
This post has been edited by trdproven: Aug 13, 2006 - 4:57 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 13, 2006 - 5:47 PM
celicurr
Joined Jan 29, '06
From Kitchener, ON, CA
post Aug 13, 2006 - 8:28 PM
FlamingCelica
Joined Apr 16, '06
From Jackson, MS
~FlamingCelica
94 Red Celica ST
post Aug 13, 2006 - 8:54 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
i did the same thing with my extra bulb i was like what the heck htey all dont plug in and its in the way, snip its gone lil electric tape and we were good to go, now i know htat s not the best or safest thing to do but it was strating to rain, and i wanted to get done, man these tails look so sweet!
post Aug 13, 2006 - 11:43 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(JFrost9 @ Aug 12, 2006 - 2:29 PM) [snapback]468233[/snapback]
it seems like he decided to do the write up after having the tails already installed.
nice write up btw. i took off the rear plastic panel (and loosened the rear corner panels) and for step 6, i pushed the metal threading to help push the old tails out.
also, i pulled out the usdm ones and kept the jdm ones.
post Aug 14, 2006 - 12:30 AM
pure_dx
Joined Dec 28, '05
From USA
why are there no altezzas for these celicas? :S i've never seen altezzas on a 6gc before :S
post Aug 15, 2006 - 12:16 PM
JFrost9
Joined Aug 27, '05
From Texas
QUOTE(pure_dx @ Aug 14, 2006 - 12:30 AM) [snapback]468735[/snapback]
I would like to keep it that way =/.
I think him having the JDM tails already on kinda threw me off...
post Sep 20, 2006 - 2:21 AM
JACSSX
Joined Aug 3, '06
From Sydney, Australia
Thanks so much, this DIY helped me understand what i had to do before doing it, n then gettin stuck etc. !!
post Jul 5, 2009 - 1:14 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (illneversellmycelli @ Aug 13, 2006 - 6:54 PM) *
What was the bulb that you took out? what was it for? reverse ? thanks
God made man....
Everything else...
Made in China
post May 4, 2011 - 11:43 PM
Zake
Joined Mar 7, '10
From Ft. Lauderdale
QUOTE (Deezz_Nuttz @ Aug 12, 2006 - 2:17 PM) *
QUOTE (b1gr3d @ Aug 12, 2006 - 9:41 AM) *
step 6 is a no-no
or you could just push on the metal studs the nuts were on in the back of the taillight housing like i did when ever i change my lights. that way you eliminate all risk of scratching your paint, or chipping the plastic on the taillight housing. biggrin.gif
Lo-Fi Version Time is now: April 23rd, 2025 - 2:57 PM
