Six Speed in a 6GC |
Aug 15, 2006 - 12:34 PM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
QUOTE(celicaST @ Aug 15, 2006 - 4:38 PM) [snapback]469212[/snapback] QUOTE(Fastbird @ Aug 15, 2006 - 6:44 AM) [snapback]469195[/snapback] Does anyone have the gear ratios and final drive ratios of the 5S-FE 5 Speed and the E153 transmissions handy for comparison?? here you go, s54: 3.285, 1.960, 1.322, 1.028, 0.820 / FD: e153: 3.230, 1.913, 1.258, 0.918, 0.731 / FD: 3.933, 4.285 the final drive ratio differed based on application, the bold are 6gc (i think) and mr2 sw20 turbo. US spec GT have the 4.176 Final Drive EU/JDM spec GT (3S-GE) have the 3.944 Final Drive. The 7th gen gearbox is really weak and cant sustain to much horsepower. Going to 250 bhp is already pushing it. Getting a LSD + Radials with 250 bhp = bye bye tranny. With my car I drive 75 mph @ 3200-3300 rpm. On the 7th gen it would be 2800 rpm. Friend of mine got one. For gas consumption it would be benifitial but in terms of power you would be better of with the GT or MR2T tranny. Best option would be the GT4 gearbox converted to 2WD but I only know of 2-3 cases that have succesfully done this. Theorotical top speed of my car with a 225/40/18 tyre would be 160-163 mph. I speed that I will never reach or want to reach with my Celica because its not meant for it (2wd plateau, different weight balance etc etc) -------------------- JDM Powerplant installed, BPU coming very soon!
Aug 15, 2006 - 5:14 PM |
Enthusiast Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) |
QUOTE(playr158 @ Aug 15, 2006 - 1:41 AM) [snapback]469143[/snapback] like i already said someone needs to take the OEM gear ratio #s outta an E153 or S54 (both would be nice) and start talking to a shop that cuts gears..and discuss about making LONGER gear ratios..in theory it should be a bolt in application and all you need to do is swap out your gears in the existing bell housing (yes this has been done before) i'm not sure if you could fit a 6th gear...but lengthening gears 2-5 is doable probably at the cost of a few hundred dollars man whata mess that would be honestly.... It would be nice if they made the s series trans in a 6th gear. The damn gearing is so short a 3sgte swapped celica with a s trans doesnt make it real good economy wise when your crusing around on the highway at 4k rpms.. compares to when I swapped he e153 I was at 65mph in 2500-2700 rpms -------------------- BANNED!
Jun 28, 2007 - 4:41 PM |
Enthusiast Joined Jun 28, '07 Currently Offline Reputation: 0 (0%) |
Could you put the e153 5th gear in the ST's C52 tranny or would that cause problems with the synchro?
Would you need to make a custom synhro? Would love to get the revs down for highway driving. You may be able to tell that I don't know a lot, just what I want to do |
Oct 10, 2007 - 2:34 AM |
Enthusiast Joined May 4, '05 From western MD/NOVA Currently Offline Reputation: 2 (100%) |
im quite curiouse about this too.. is it not posible to just swap out the fith gear??
Oct 10, 2007 - 8:46 AM |
Enthusiast Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) |
QUOTE(playr158 @ Aug 15, 2006 - 6:41 AM) [snapback]469143[/snapback] like i already said someone needs to take the OEM gear ratio #s outta an E153 or S54 (both would be nice) and start talking to a shop that cuts gears..and discuss about making LONGER gear ratios..in theory it should be a bolt in application and all you need to do is swap out your gears in the existing bell housing (yes this has been done before) i'm not sure if you could fit a 6th gear...but lengthening gears 2-5 is doable probably at the cost of a few hundred dollars The thought of a 6th gear is more for fun, but if I could have gears 2-5 lengthened then I would be content! -------------------- CLOSED on 25 acres! -shop coming soon.... |
Oct 16, 2007 - 7:09 PM |
Enthusiast Joined May 19, '06 From North NJ Currently Offline Reputation: 16 (100%) |
QUOTE(frosty @ Oct 10, 2007 - 8:46 AM) [snapback]603596[/snapback] QUOTE(playr158 @ Aug 15, 2006 - 6:41 AM) [snapback]469143[/snapback] like i already said someone needs to take the OEM gear ratio #s outta an E153 or S54 (both would be nice) and start talking to a shop that cuts gears..and discuss about making LONGER gear ratios..in theory it should be a bolt in application and all you need to do is swap out your gears in the existing bell housing (yes this has been done before) i'm not sure if you could fit a 6th gear...but lengthening gears 2-5 is doable probably at the cost of a few hundred dollars The thought of a 6th gear is more for fun, but if I could have gears 2-5 lengthened then I would be content! frosty your hairs crazy! i like your hood too This post has been edited by twitchh17: Oct 16, 2007 - 7:09 PM |
Sep 27, 2008 - 2:49 PM |
Could you put the e153 5th gear in the ST's C52 tranny or would that cause problems with the synchro? Would you need to make a custom synhro? Would love to get the revs down for highway driving. You may be able to tell that I don't know a lot, just what I want to do Anybody know if you would need a custom synchro if you changed 5th gear? Is the shaft the same size on c52 and e153? What about .706 4th gear from the GT Auto transmission? Could this be used for 5th gear in a manual? Any OEM toyota 5th gears that come under the .713 e153 5th, or .706 GT Auto 4th gear? The e153 gear would drop the RPMs by 375, which is a good start, a 600 RPM drop would be ideal (engine gets loud after 2800 RPM). The ST has so much potential for gas mileage, it's just hampered by the gearing (which I believe was designed for Japanese highways, with a 60MPH speed limit). I am also interested in ride comfort, the engine gets so loud at highway speeds (sometimes I'll wear earplugs!) Would like to improve this factor as well. May be solved by going back to stock airbox w/ the lower resonator box reinstalled. |
Sep 27, 2008 - 3:49 PM |
Man, a 6 speed would be crazy... I'd love to have one. I kinda tend to agree with everyone else on here though, that I'd rather just have all my gears lengthened. INCLUDING 1st. 1st has good acceleration, but it's too short. Has anybody else noticed that, on a GT that first gear is gone before you ever get a chance to get anywhere? Oh well. I'm eventually going to put a 3S-GE BEAMS in my car, after I get some money. I'm leaving everything alone until I get that. Can anybody tell me how the gearing on that is, if I'll be doing any better than my 5S?
Sep 27, 2008 - 3:58 PM |
Enthusiast Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
I believe that the blacktop 4age 6 speed fits right up to the 7afe...only thing I heard though is that tranny is like glass
-------------------- --------------------------------私は銀行に漂う,TRD Inspired |
Sep 28, 2008 - 5:09 AM |
i can only think of trying bigger wheels and a speedometer corrector...
but i'd say the 6 speed in those sort of cars are designed to bring the gears in between first and final gear closer together to aid street acceleration (drivability) of torqueless motors and wont bring your cruising revs down, instead it'll give u a 5th gear which feels like ur old 4th gear. my flatmates bz-r levin revs anywhere between 1 and 2 thou RPM higher than my car does thru its 2nd, 3rd, 4th, 5th gears at street driving speeds but then it's 6th gear brings its revs down to match my 5th gear, eg 3k and a bit at 100 kph. -------------------- Mike W
Sep 28, 2008 - 1:25 PM |
e135 FTMFBBQ win in the celica, with a swap.
100+MPH in 3rd gear, and and a highway cruising rpm of ~3000rpm is where its AT. 6 speed would be a waste of time and money. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 7, 2008 - 5:26 AM |
Enthusiast Joined Sep 13, '08 From Australia Currently Offline Reputation: 0 (0%) |
As some of you may or may not know, I plan to mate the auto trans U660E to my 3S-GTE. Yes, it DOES bolt up with the current bell housing. Unfortuately it's Auto, but I hear that it can handle the torque and can shift fast.
After the final drive ratios are factored in, here are the gear ratios for the U660E vs S54, U660E: 1st 12.16 2nd 7.00 3rd 5.23 4th 3.68 5th 2.63 6th 2.24 S54: 1st 13.72 2nd 8.18 3rd 5.52 4th 4.29 5th 3.42 Would be great to go on the freeway at around 2000RPM... |
Oct 7, 2008 - 8:55 AM |
and how do you plan on controlling said tranny
Oct 7, 2008 - 8:58 AM |
Enthusiast Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
^Aussie magic ofcourse....kinda like pix dust. but only sold in Australia
the ue6 etc auto tranny is out of what? (i see u showed 6 gear ratios on an auto) edit: ^'07 camry....i want proof it mates. because im calling bologna on this whole "it mates" comment This post has been edited by devilsden97: Oct 7, 2008 - 9:01 AM -------------------- Kawi Love |
Oct 7, 2008 - 9:16 AM |
Enthusiast Joined Apr 17, '07 From Montreal, QC, Canada Currently Offline Reputation: 1 (100%) |
And here comes the solution You are viewing a brand new set C-ONE Sports Final Gear Set. For more enjoyable sports driving experience, first and second gear ratios have been brought closer to third gear, with the fourth and fifth gear ratio closer to third gear. Gear Ratios are as follows: First Gear: 3.231 (OEM 3.384) SHORTER Second Gear: 2.235 (OEM 1.913) LONGER Third Gear: 1.667 (OEM 1.258) LONGER Fourth Gear: 1.250 (4th OEM 0.918) LONGER Fifth Gear: 0.929 (5th OEM 0.731) LONGER Upon purchasing, please specify which of the following vehicles you would like the product for: ST205/ST185 Celica GT-Four SW20 MR2 Now Only : USD 2969.77 This post has been edited by reko: Oct 7, 2008 - 9:23 AM -------------------- |
Oct 7, 2008 - 12:28 PM |
Enthusiast Joined Feb 23, '07 From Albany, NY Currently Offline Reputation: 3 (100%) |
QUOTE Now Only : USD 2969.77 wow |
Oct 7, 2008 - 3:10 PM |
i'm surprised C-ONE isn't bankrupt yet... lol
Oct 7, 2008 - 3:16 PM |
Some day I will have the blacktop w/the 6 speed tranny swapped into my car. It's my long term plan... sigh...
Oct 7, 2008 - 3:28 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Actually the idea of running larger tires would be the easiest way to do it. With the downside that you increase the overall height of the vehicle, and therefore the center of gravity.
and how do you plan on controlling said tranny We carry the PCS standalone transmission controller, he could use that. They work really nice, plus they all kinds of cool features, like you can add in paddle shifters, have different shift maps that you can swap between, control the shift harshness based on various factors, etc. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Oct 8, 2008 - 6:32 AM |
Hi all,
Reco's post regarding the C-ONE is not what I had in mind. The C-ONE conversion for the E153 or E154F will only bring the gear ratios closer together, which is good for racing purposes to keep your RPM in the power-band between gears, but at top gear your RPM will be higher than before the upgrade. I currently have an A140E mated to my 3S-GTE. It's not known for it's strength, so I've had to set my shiftpoints to occur below 5000RPM on full throttle. Yes, i purchased a PCS controller to control my transmission. it cost me almost a grand, so it's a bit more than I like. In theory the controller could also control a U660E. The U660E is from Japan, and has been put in the late model Toyota Aurion and Lexus ES350 here in Australia. OK, i am "pretty sure" U660E bolts up to the 3S-GTE: A 3.5 litre 2GR-FE mates to both the U660E in the Aurion and the U151F in the new Highlander (Kluger). The U151F will mate to the 2GR-FE as well as the 3.3 Litre 3MZ-FE in the old Highlander. The 3MZ-FE mates to both the U151F and also to the A541E in the Camry. The A541E is interchangable with the E153. It is therefore highly likely that the 3SGTE will mate to the U660E. My main concern is actually whether we can create/aquire adequate brackets and mounts to support the trans in the celica engine bay, and also whether the transmission will actually have room to fit inside. Actually the idea of running larger tires would be the easiest way to do it. With the downside that you increase the overall height of the vehicle, and therefore the center of gravity. and how do you plan on controlling said tranny We carry the PCS standalone transmission controller, he could use that. They work really nice, plus they all kinds of cool features, like you can add in paddle shifters, have different shift maps that you can swap between, control the shift harshness based on various factors, etc. -Doc |
Lo-Fi Version | Time is now: November 27th, 2024 - 8:05 PM |
