Oil smoke when I start the engine ........ |
Sep 30, 2006 - 5:35 PM |
Enthusiast Joined Dec 9, '05 From Long Beach Currently Offline Reputation: 1 (100%) |
lol okay next person!
my car blows out more smoke than a fog machine when its cold lol its not dark smoke, its white and it smells like steam. it dosent go to the floor, it expands in the air. when its warmed up it dosent blow smoke. -------------------- Is this good enuff 4 ya? :D
Oct 1, 2006 - 12:22 PM |
Enthusiast Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) |
QUOTE(carma4 @ Sep 29, 2006 - 8:31 AM) [snapback]485265[/snapback] Wow! Thanks to everyone for the help! Now that I know better and since I really love my car, the oil will be changed way before 6K miles. I'm thinking 3K to 4K would be ok. The smoke that I see when it first starts up is a small cloud of bluish smoke that lingers in the air around my car for about a minute. I'll check the plugs to see if there's oil leakage. The car has about 150K miles on it, so it stands to reason that it's going to need some type of major work in the near future. I'm curious about the AFT thing. I don't know as much as the rest of you so I don't know what it is but it sounds like it might be worth trying. Can someone please explain this to me? What is AFT and what should I do with it?? The automatic transmission fluid soaks into the seals and allows them to expand a little. It is an easy fix instead of having the head rebuilt. Just like Bitter said just add it to the oil a little bit before changing it and pull a vacuum line and suck some up. I'm sure Bitter could explain it better as he is one of the users. I am going to try adding it to the oil in mine I think. QUOTE(XS4lv1Truch0x @ Sep 30, 2006 - 3:35 PM) [snapback]485791[/snapback] lol okay next person! my car blows out more smoke than a fog machine when its cold lol its not dark smoke, its white and it smells like steam. it dosent go to the floor, it expands in the air. when its warmed up it dosent blow smoke. Could be a bad gasket that when the car warms up it reseals. Also it could just be bad gas. The first depends on the temp outside when you started it and the last just on how shady the gas station is that you go to. A clue to bad gas is if they are selling it for an insanely low price compared to other stations. This post has been edited by bindertch: Oct 1, 2006 - 12:24 PM |
Oct 1, 2006 - 8:36 PM |
QUOTE(bindertch @ Oct 1, 2006 - 10:22 AM) [snapback]485996[/snapback] QUOTE(carma4 @ Sep 29, 2006 - 8:31 AM) [snapback]485265[/snapback] Wow! Thanks to everyone for the help! Now that I know better and since I really love my car, the oil will be changed way before 6K miles. I'm thinking 3K to 4K would be ok. The smoke that I see when it first starts up is a small cloud of bluish smoke that lingers in the air around my car for about a minute. I'll check the plugs to see if there's oil leakage. The car has about 150K miles on it, so it stands to reason that it's going to need some type of major work in the near future. I'm curious about the AFT thing. I don't know as much as the rest of you so I don't know what it is but it sounds like it might be worth trying. Can someone please explain this to me? What is AFT and what should I do with it?? The automatic transmission fluid soaks into the seals and allows them to expand a little. It is an easy fix instead of having the head rebuilt. Just like Bitter said just add it to the oil a little bit before changing it and pull a vacuum line and suck some up. I'm sure Bitter could explain it better as he is one of the users. I am going to try adding it to the oil in mine I think. QUOTE(XS4lv1Truch0x @ Sep 30, 2006 - 3:35 PM) [snapback]485791[/snapback] lol okay next person! my car blows out more smoke than a fog machine when its cold lol its not dark smoke, its white and it smells like steam. it dosent go to the floor, it expands in the air. when its warmed up it dosent blow smoke. Could be a bad gasket that when the car warms up it reseals. Also it could just be bad gas. The first depends on the temp outside when you started it and the last just on how shady the gas station is that you go to. A clue to bad gas is if they are selling it for an insanely low price compared to other stations. i get my gass at the ARCO down my block, its around 2.60 a gallon, i pump 87 only. it could be any temperature and it will still blow out white smoke just when you start it. This post has been edited by XS4lv1Truch0x: Oct 1, 2006 - 8:57 PM -------------------- Is this good enuff 4 ya? :D
Oct 1, 2006 - 11:50 PM |
does the white smoke smell a little sweet?
Oct 9, 2006 - 11:42 AM |
Enthusiast Joined Mar 30, '05 From Wisconsin Currently Offline Reputation: 0 (0%) |
i got a problem too, i put a metal headgasket on it, why does i still have whitesmoke comming from my exhast, and there is a black oil leaking on my header gasket, so what can be wrong!!!
Oct 9, 2006 - 12:19 PM |
Enthusiast Joined Aug 12, '06 From El Cerrito, CA Currently Offline Reputation: 0 (0%) |
After sorting through the responses (thanks everyone), I think it's probably valve seals. My car has 150K. With Celicas, that's equal to 45 in human years. I also tend to drive at high RPM as a rule. I don't know if that makes it worse but probably. Could put more pressure on the seals and shorten their life. But it's easier to replace the valve seals (or almost anything else) than change how I drive! I love drivin' my car!
By the way, my eyes were playin' tricks with the AFT "what?". I re-read it and retrack the question. ATF....lol |
Lo-Fi Version | Time is now: November 29th, 2024 - 10:42 PM |
