> Wheel Has Play, I Jaked up my car to see why i feel shaking when i drive. and my rime
post Aug 13, 2006 - 2:28 AM
ed_celica94
Joined Jul 13, '06
From san antonio .tx
can anybody tell me if its the bearrings.
This post has been edited by Coomer: Aug 16, 2006 - 1:43 AM
post Aug 13, 2006 - 9:01 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Currently Online
spelling argh!
your WHEEL may have play back and forth if the lugnuts are loose, make sure everything is tight. generally with a bad wheel BEARING you'll hear a bad growling/grinding sound for a long time before the wheel gets really loose and wobbly, but thats not always the case. remove the wheel and brake rotor and feel if the hub is wiggling like the wheel.
post Aug 13, 2006 - 11:39 AM
Culpable04
Joined Apr 17, '06
From New Jersey
make sure the nuts you are using don't top out before get to the rim. sometimes you tight the nut but It's not in full contact with the wheel so you feel it loose. that happen to me and problem went away when I change the nuts.
post Aug 13, 2006 - 5:12 PM
ed_celica94
Joined Jul 13, '06
well the lugnuts on tight. i also hear screching and a taping noise. i cant figure it out please help me out.
post Aug 13, 2006 - 10:01 PM
uberschall
Joined Jul 29, '03
From north of detroit
if your lugnuts are all tight (to torque specs) and you can move the wheel by grabbing the top and bottom edge and pulling/pushing, it's gonna be a balljoint. like bitter said, a bearing will be noisy. VERY noisy.
do you know who i am, mr. worley?
post Aug 13, 2006 - 10:19 PM
Bitter
Joined Mar 11, '06
Currently Online
yea, definatly a balljoint can cause a wiggle. in the steering it can cause the steering to feel erratic since that one wheel is cambering back and forth.
post Aug 14, 2006 - 9:05 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(uberschall @ Aug 13, 2006 - 10:01 PM) [snapback]468692[/snapback]
A wheel bearing can have play and make absolutely no noise.
The noise comes from either the race being out of round or one or more of the bearings damaged.
If there is play, it's time to replace it though.
Look behind the wheel and see where it's wiggling at.
It could be the ball joint.
It could be the outer tie rod joint.
Could be the wheel bearing.
post Aug 15, 2006 - 1:48 AM
ball joints connect the control arms to the steering knuckle, this does not cause the wheel to wobble...
if you jack up your car and with the lug nuts tight move you wheel in and out (grab the wheel at 9 and 3 and push in and out) if it moves your wheel (in relation to the steering knuckle) bearings ARE BAD....i've replaced 2 sets of bearings because of this
if you let it go on for too long it will destroy your hub too and you'll have to get a new one
This post has been edited by playr158: Aug 15, 2006 - 1:50 AM
post Aug 15, 2006 - 8:51 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE(uberschall @ Aug 13, 2006 - 11:01 PM) [snapback]468692[/snapback]
Um, correction, no they wont, unless there about to go.. as in melt to the inner baring.. I have had a bad wheel baring for 1/2 a year, and didnt make any noise..
Its most likly the wheel baring. Take it to mr-tire and they will tell you. THEN Take it to a more reliable mechanic that wont rape you.
post Aug 15, 2006 - 12:37 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Check Tie rod end and balljoint... probably the tie rod end though
post Aug 15, 2006 - 7:59 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(playr158 @ Aug 15, 2006 - 1:48 AM) [snapback]469150[/snapback]
They secure the knuckle/carrier to the A arm.
Through this the wheel is secured.
If there is play in the joint, the wheel will wobble.....
It can either have up and down OR side to side, or both.
There are 4 things holding the axle carrier/knuckle to the car.
The CV shaft via the nut [the wheel/hub is held to the carrier through the wheel bearing].
The outer tie rod joint.
The 2 bolts holding it to the strut.
The lower ball joint.
The cv shaft and 2 bolts will almost never be a problem. If they are, it is usually because one is loose, not broke.
ANY ONE of the other 3, if it is worn WILL allow play.
post Aug 16, 2006 - 1:25 AM
Bitter
Joined Mar 11, '06
Currently Online
laugh.gif when i slid on ice into a curb and BROKE my balljoint and bent the control arm the wheel cambered back and forth wildly, the balljoint is the lower pivot for the wheel. it allows the wheel to camber + and - as well as turn in and out. camber on a single front wheel will pull the car back and forth, camber will pull towards the direction the top of the wheel points.
post Aug 16, 2006 - 1:42 AM
My driver's side wheel bearing went bad and was silent except it'd make a grinding noise when I turned at slow speeds, but the wheel would move back and forth a ton when we jacked it up. I just replaced the whole hub.
post Sep 8, 2007 - 9:53 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
i can shake my wheel too. but only a lil. this is bad. i hope this is the answer. to my problem. kindasad.gif
post Sep 11, 2007 - 3:17 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
mine has the same weird problem, but mine doesnt vibrate or make ne noise!....
btw im post whoring too.
Lo-Fi Version Time is now: November 23rd, 2024 - 12:00 PM
