5 Pages V  < 1 2 3 4 5 >
> Sway bar end links, need new ones
post Feb 13, 2007 - 2:37 PM
Slick
Joined Jan 10, '06
From Mozambique, Africa
Wow! how much was the whole set?
post Feb 14, 2007 - 12:49 AM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(snapshotgt @ Feb 13, 2007 - 7:32 PM) [snapback]526499[/snapback]
here is a teaser cell phone picture:
on their site its said that they only have the rear links how did u get the fronts. I am confident that the st185 fronts will also work for us as they look to be the exact same length
im going to buy mine this week
This post has been edited by urbandork: Feb 14, 2007 - 12:51 AM
post Feb 14, 2007 - 10:42 AM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(urbandork @ Feb 13, 2007 - 11:49 PM) [snapback]526731[/snapback]
I'm testing st185 fronts out on my celica for them.
post Feb 14, 2007 - 2:52 PM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(snapshotgt @ Feb 14, 2007 - 3:42 PM) [snapback]526791[/snapback]
cool please keep us updated as to how things are going
post Feb 15, 2007 - 12:53 AM
post Feb 15, 2007 - 10:53 AM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(playr158 @ Feb 14, 2007 - 11:53 PM) [snapback]527017[/snapback]
You're right .. but no one knew for sure (100%) if they'd work since they have not been tried out. wink.gif
post Feb 15, 2007 - 10:48 PM
post Feb 16, 2007 - 12:03 AM
azian_advanced
Joined Apr 18, '05
From Calgary
just a quick question about the rear links, i just bought myself two sets (i thought putting 2 in the qty field would give me 2 links, not two pairs).. anyway, it seems that they can be adjusted.
would making them shorter make cornering a little stiffer and improve balance?
This post has been edited by azian_advanced: Feb 16, 2007 - 12:04 AM
post Feb 16, 2007 - 1:00 AM
QUOTE(azian_advanced @ Feb 16, 2007 - 12:03 AM) [snapback]527329[/snapback]
I think it might buyt don't quote me...I also think it would were out the bushing back there much quicker.
and if you want to get rid of one of those sets, I would be happy to take them off your hands smile.gif
post Feb 16, 2007 - 3:09 AM
azian_advanced
Joined Apr 18, '05
From Calgary
bah.. my bushings are probably already done for. i hear clunks nearly every little bump.. one of these days, i'll have it all fixed..
in regards to the extra set of rear links, i was gonna wait and make a huge FS thread with all my spares, but i can let it go early. they're still in the bubble envelope and never touched.
post Feb 16, 2007 - 1:13 PM
i highly doubt making them shorter will change anything.
post Feb 16, 2007 - 4:48 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Ok so I'm just guessing but I would think that changing the size wouldn't be the best idea since we're all trying to see if our OEMs are the same size so that they'll fit? What's the point of making sure they're the same size if you can just get any old size and use it?
This post has been edited by GTS13: Feb 16, 2007 - 4:49 PM
post Feb 16, 2007 - 4:53 PM
well the sway bar rotates up and down so you can make it longer or shorter and it could still very well fit....the performance of the sway bar is really a twisting motion as i see it (could be wrong)
but to gain any performance outta it the mounting point of the endlink has to be moved either farther in (stiffer) on the sway bar or farther out (softer)
up and down = not so much effect
post Feb 16, 2007 - 7:32 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
You are correct sir, twisting is what our sways do which is why we get thicker ones to help reduce the amount they bend. So the only thing I can think of to modify performance would be to make one endlink shorter so that the bar is somewhat bent and then you would have a little stiffer turning when trying to bend it more? or the other way? I think my logic might be a bit off, I've been working too long. lol. I'm gonna shut up now. laugh.gif
This post has been edited by GTS13: Feb 16, 2007 - 7:32 PM
post Feb 19, 2007 - 11:31 AM
i don't think you would want to offset the endlinks in length as the sway bar is designed to be level at normal ride..."preloading" it could cause adverse effects and potential tire wear possibly?
post Feb 20, 2007 - 6:01 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
is there any noticeable change in the aftermarket ones? or is it just like the if your gonna lower your car you mid as well throw these in and do it right type deal.
post Feb 20, 2007 - 7:28 PM
azian_advanced
Joined Apr 18, '05
From Calgary
maybe if you get aftermarket sway bars, you may as well change the links for these aftermarket ones while you're at it. these are so easy to install and remove.
post Feb 20, 2007 - 10:28 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
well im going to be lowering my car soon and i was thinking about buying these, but i dont really wanna just throw away 150$ bucks if i wont notice anything at all, but im pretty sure just by looking at them that it would show minor improvements in overall suspension feel.
post Feb 21, 2007 - 12:58 AM
azian_advanced
Joined Apr 18, '05
From Calgary
actually i haven't felt any noticeable difference.. i bought these links thinking that my old ones were the cause of my rear clunking all the time.. i guess i need new suspension arms.
btw, i don't think these endlinks create a noticeable increase in handling and stability.. as previously mentioned, they're just aftermarket OEM replacements. imo, you're better off putting that money for strut/sway bars if you're looking to stiffen your suspension.
post Feb 21, 2007 - 1:14 AM
if you're getting clunking when going over any bumps (like something is knocking around back there) then it's more than likely the sway bar bushings, about $6 each from the dealer.
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 22nd, 2025 - 1:10 AM
