Enthusiast ![]() ![]() ![]() Joined May 5, '05 From mattoon, IL Currently Offline Reputation: 2 (100%) ![]() |
Hey im still workin on my 7afte project, and i need some help,, whats the best way to connect the turbo oil line, to the oil pan?? cant weld cause the fitings are brass, which are to soft to weld.
tap the pan and use a nut on the inside with some washers and gasket material?
what if i were to drill the hole just big enough so you can kind of screw the fitting in, and just put like sealant around it, like JB cold weld on both sides, along with a nut and washer??
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
spend the extra time and money dont try and jimmy rig it
-------------------- yea your 3sgte is cool but ill stick to my 7agte
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(nik @ Aug 14, 2006 - 7:13 PM) [snapback]469031[/snapback] spend the extra time and money dont try and jimmy rig it i agree i tried the brass fittings and cold weld all u r going to do is make a oil leak and if u are not using a big enough fitting u will blow the seals ![]() ![]() -------------------- ![]() |
![]() Enthusiast ![]() Joined Mar 17, '06 Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(nate95 @ Aug 14, 2006 - 6:26 PM) [snapback]468994[/snapback] Hey im still workin on my 7afte project, and i need some help,, whats the best way to connect the turbo oil line, to the oil pan?? cant weld cause the fitings are brass, which are to soft to weld. I'm not really familar with turbo oil return lines. Why can't you weld on a steel fitting of the proper diameter and thread pitch? You could install your lines into the fitting that's been welded to the pan. Yellow94GT |
Lo-Fi Version | Time is now: February 25th, 2025 - 2:35 PM |
