> Viper 791xv----Alarm help, I Need It
post Aug 18, 2006 - 12:15 PM
Fate
Joined Nov 30, '04
From Atlantic City
ok so i bought the alarm and rather then doing it myself, i had a shop put it in. the shop told me that they can't put in the remote start because it's a big liability. i want to hook up the remote start, i never leave the car in gear so i have nothing to worry about. is there anyone in the area that can help me out and maybe come down to Atlantic City area? i really want it in for the winter and since it's going to be already hooked up (the actual alarm) then it should be easy to connect the "start" right? woudn't it be just a matter of wires? please help me out, someone or people. thanks.
-Americo
the alarm:
Viper 791XV (p/n 564V)
2-Way Security System / Remote Start System with Responder Technology
6 channel remote start/security/keyless entry system
Confirms commands and system triggers on the transceiver LCD screen
Clone-Safe® Code-Hopping®
Parking Light Flash
Failsafe® Starter Kill
Anti-Grind
Stinger® DoubleGuard® Shock Sensor
Revenger® Six-Tone Siren
Bright Blue LED Status Indicator
Miniature XCRS (Extreme Capacity Relay Satellite)
Defroster Output
Built-in Turbo Timer
3 Auxiliary outputs
Dome Light Supervision
Comfort Closure
4 Auxiliary Outputs
Horn Honk
Includes One 2-way Responder Transceiver
This post has been edited by Fate: Aug 18, 2006 - 12:16 PM
post Aug 18, 2006 - 7:45 PM
Velliety
Joined Jul 10, '06
From South Carolina
Man, that sucks that they wouldn't hook up your remote start. I've got the exact same system in my Celi - love it! I had it installed at Best Buy - they didn't have any qualms about hooking up the remote start.
Samantha
post Aug 18, 2006 - 10:43 PM
Fate
Joined Nov 30, '04
From Atlantic City
can anyone help me?
post Aug 18, 2006 - 10:46 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
remote start up for a standard transmission is illegal for obvious reasons. but ya, just take it to another place and be like heres $50 hook up my remote start.
To live, is to suffer
post Aug 19, 2006 - 12:09 AM
Fate
Joined Nov 30, '04
From Atlantic City
yeah i figured i could do that but i'm figuring it might be easier to hook it up myself. any other suggestions?
post Aug 19, 2006 - 1:58 PM
laff09
Joined Jul 28, '06
From Delaware
I've had this system for ~2 years, its pretty awesome. However take CARE of your keypad, those little things are $150 to replace.
post Aug 19, 2006 - 11:50 PM
Fate
Joined Nov 30, '04
From Atlantic City
do you have the remote start installed?
post Aug 20, 2006 - 12:44 AM
hmongtaejien
Joined Apr 7, '06
From Fontana, CA
do u have diagrams of the alarm? like the cables.. which goes where and such? or wut color wires r left?
post Sep 11, 2006 - 7:15 PM
Kamakaze
Joined Jan 25, '06
From Marlton, NJ
QUOTE(Fate @ Aug 18, 2006 - 12:15 PM) [snapback]470285[/snapback]
-Americo
the alarm:
Parking Light Flash
Anti-Grind
Defroster Output
3 Auxiliary outputs
Comfort Closure
4 Auxiliary Outputs
Horn Honk
you've got to bypass the clutch when you do that. Just use a relay to take care of that. Locate the clutch wire near the pedal, and what you have to do is put those both on constant ground 30 and 87a i believe. wink.gif i work at best buy
JM Exclusive - Car PCs, Custom Fabrications, Mods and More JM Exclusive Facebook
post Sep 12, 2006 - 12:34 PM
TwistedmindZ
Joined Dec 21, '05
From SF Cali
it's actually 87 and 30 to bypass the clutch most likely not all the wires for the remote start are hooked up such as the hoodpin (grey wire) the brake shutdown (brown wire) the tach signal (violet/white wire) for the clutch bypass use blue/wht or blue which ever the status output is (be sure u use the switch that gets contact at the very bottom of the pedal push) 87 goes to 1 wire of the switch 30 goes to other 85 goes to status output and 86 goes to 12V constant (accessory is ok too) I work at circuit city install laugh.gif
Lo-Fi Version Time is now: December 4th, 2024 - 7:48 PM
